nels Posted July 11, 2017 Report Posted July 11, 2017 What do you guys use to clean the windshield etc.? I've been using just polish but tried Windex the other day and in doing so those splattered bugs sure came off easy. Is there any problem using any particular detergents when washing the plane and the plexiglass windows?
kevinw Posted July 11, 2017 Report Posted July 11, 2017 At the recommendation of several mooneyspacers I use Plexus. A little spendy...about $15 a can but works very well. A can will last quite a long time. Windex is a no no. Anything with ammonia is not good I was told.
N201MKTurbo Posted July 11, 2017 Report Posted July 11, 2017 DON'T USE WINDEX!!! Anything that contains ammonia will rapidly degrade the Plexiglas and ruin it. Plexus works great but is expensive. Any commercial plastic polish is OK. Some people use furniture polish. I've tried it and it seems to leave too much residue. For the last 15 years or so I've been using spray wax from the Aviation isle at Auto Zone. I don't know what's in it but I have no signs of degradation. I'm sure you will get plenty of opinions.... 1
kmyfm20s Posted July 11, 2017 Report Posted July 11, 2017 Plexus and Lemon Pledge sure seem similar with exception of price.
RLCarter Posted July 11, 2017 Report Posted July 11, 2017 +1 for Plexus, Windex or anything with ammonia is really bad, the plastic actually is a laminate which the ammonia will lift the protective coating (looks like its peeling)
bradp Posted July 11, 2017 Report Posted July 11, 2017 Best thing is wash with mild soap, water, and a clean hand with no rings or anything. Use a soft cotton t shirt or flannel (I get it by the yard at Joann fabric and cut it). Plexus and pledge are good. Pledge is cheap and seems safe after a few years of use but leaves a waxy residue - especially if it's cold outside. Plexus leaves less residues. Its best to wash the window with water to get the pieces of bugs, dirt etc off before you start polishing with plexus. If you have a choice of soapy water followed by rinsing with clean water, water alone, or plexus alone I would go in that order. If you have gritty things on the windshield and put plexus alone on it you will still risk rubbing and scratching with the gritty stuff caught between the window and the cloth despite the foamy bubbles. I bought plexiglass polis from LP aero and that stuff is both safe and works well for a polisher. I guess the moral of my story is cleaning and polishing should be considered separate steps. Never let a line guy come at your windows with anything except 3M aviation wipes that are safe for tranparencies. Any regular paper towel or shop towel or whatever will scratch and degrade your transperancies. 1
rbridges Posted July 11, 2017 Report Posted July 11, 2017 I don't have running water in my hangar, so I will sometimes spray it down really good to get the dirt/dust off the windshield before cleaning. I use pledge. It does leave a residue if you don't wipe it completely, but it hasn't caused any problems to the windshield over the past several years. I use microfiber cloths. Even the cheaper ones seem to clean without leaving any scratches.
markejackson02 Posted July 11, 2017 Report Posted July 11, 2017 I use cotton towels that are sopping wet to get the junk off then use Plexus and AutoZone chamois to polish. I only use a half a can of Plexus per year.
Marauder Posted July 11, 2017 Report Posted July 11, 2017 Someone say glass cleaning? I used the Permatex plexiglass cleaner for years and it was fine. Didn't introduce scratches. I have since switched to Plexus. Plexus seems to help alleviate some of the finer scratches. The important part about using the cleaners is not to try to remove bugs that have been allowed to dry for a few days. If they are caked on, I will water down the glass and use a soap with a microfiber towel. Sent from my iPhone using Tapatalk Pro 1
PMcClure Posted July 11, 2017 Report Posted July 11, 2017 Pledge works great and is cheap. Lemon seems to work best. I find it works best to use one side to polish and the other side to wipe any residue off. It also works great getting the bugs off the leading edge and cowling. Key is to have a soft, clean towel. 1
PTK Posted July 11, 2017 Report Posted July 11, 2017 I use it on the entire exterior and interior except on the leather. Frequent cleaning is key. I clean leading edges and plexi after every flight. "Cleans plexiglass, removes oil smudges and breaks down organic soils like bugs and fingerprints quickly and effortlessly. Leaves behind nothing but a clean shine!.. ...The Zep Commercial Foaming Glass Cleaner is an Ammonia Free formula. Use on glass, windows, mirrors, and Plexiglas. Should you have any other questions, please do not hesitate to contact us at 1-888-805-4357 and a representative will be happy to assist you. Sincerely, Zep Commercial Retail Technical Support." The CB in me refuses to pay 20$ for a 7oz. can of plexus! The ZEP is a 19 oz. can for $2.97 at the local Home Depot. I'd rather pay the 20$ for avgas! 1
Bravoman Posted July 11, 2017 Report Posted July 11, 2017 Plexus is the bomb. Pledge? You guys ain't kiddin when you say you're cheap! 1
Rwsavory Posted July 11, 2017 Report Posted July 11, 2017 Sprayway Glass Cleaner. About $2 a can at Home Depot. No ammonia. Every so often I follow with Mequiars Plastic Cleaner. 1
INA201 Posted July 11, 2017 Report Posted July 11, 2017 3 hours ago, Marauder said: Someone say glass cleaning? I used the Permatex plexiglass cleaner for years and it was fine. Didn't introduce scratches. I have since switched to Plexus. Plexus seems to help alleviate some of the finer scratches. The important part about using the cleaners is not to try to remove bugs that have been allowed to dry for a few days. If they are caked on, I will water down the glass and use a soap with a microfiber towel. Sent from my iPhone using Tapatalk Pro I see Plastx in there. What's it for and do? 1
Marauder Posted July 11, 2017 Report Posted July 11, 2017 Just now, INA201 said: I see Plastx in there. What's it for and do? I was using it for the LED light. Stopped that and am using Plexus on everything. 1
orionflt Posted July 11, 2017 Report Posted July 11, 2017 I use a left over bottle of water and a clean cotton type cloth or lint free wipe. every once in awhile i will use a plastic polish. Brian
201er Posted July 11, 2017 Report Posted July 11, 2017 23 minutes ago, Marauder said: I was using it for the LED light. Stopped that and am using Plexus on everything. The plastx is good for polishing out small scratches out of the windshield but not for regular cleaning. 1
gsxrpilot Posted July 11, 2017 Report Posted July 11, 2017 WashWax and a microfiber towel. I keep a small bottle of WashWax in the plane just for windows, unless the line guy shows up with Plexus, which they sometimes do.
201er Posted July 12, 2017 Report Posted July 12, 2017 When I fly 1300nm+ nonstop legs in my 201er, I use Plexus. Plexus is easier to use than ordinary cleaners. Its convenient aerosol applicator prevents dripping, leaking, evaporating, and coagulating at the tip of the nozzle (as is common with pumps and squeeze bottles). To use Plexus, simply spray and wipe - no buffing, no mess, and no waste. You can tell it's top notch because it has the word Lexus in the name. Of course, there's really only one way to be convinced about the superiority of Plexus: try it yourself. Plexus comes in a variety of sizes for a number of uses. So when you're looking for the most effective cleaner, protectant and polish for any kind of plastic, there's only one clear choice. Plexus. Clearly the Best. ® 3
XXX Posted July 12, 2017 Report Posted July 12, 2017 10 minutes ago, 201er said: When I fly 1300nm+ nonstop legs in my 201er, I use Plexus. Plexus is easier to use than ordinary cleaners. Its convenient aerosol applicator prevents dripping, leaking, evaporating, and coagulating at the tip of the nozzle (as is common with pumps and squeeze bottles). To use Plexus, simply spray and wipe - no buffing, no mess, and no waste. You can tell it's top notch because it has the word Lexus in the name. Of course, there's really only one way to be convinced about the superiority of Plexus: try it yourself. Plexus comes in a variety of sizes for a number of uses. So when you're looking for the most effective cleaner, protectant and polish for any kind of plastic, there's only one clear choice. Plexus. Clearly the Best. ® So in addition to parrot whisperer, you write ad copy for tv commercials? Perfect script, right at 30 seconds. I could even visualize the shots. Excellent job! 1
Andy95W Posted July 12, 2017 Report Posted July 12, 2017 7 hours ago, Danb said: Prist aero window cleaner and Kim wipes I have Prist and my wife's name is Kim. She has yet to wipe bugs off our Mooney. 2
