MIm20c Posted June 20, 2019 Report Posted June 20, 2019 On 6/7/2019 at 9:00 PM, Niko182 said: I got quoted 55 for all of that plus a GNX375. I think for the time being, Ill keep the Stec 30, so no GFC500, and add a gtn750 or 650, and an audio panel. I'm just trying to figure out if its worthwhile to go with the 750 since one, there will already be a gnx375, and two, the G3x can control a lot that the gtn's can so is that spare space really needed. Without a doubt I would install the 750 and a new AP. The 3100 or gfc along with the 750 will be the important parts of the upgrade. The rest is just fluff. The beauty of the g3x is that you can interface with the gdl50r which gives you full adsb in. This allows you to use a $1600 330es or blinker on the wing. I think the 375 would be great if you were keeping both 155’s and not getting a gtn. With the 750 I would never go for the 175/375. Instead I’d pick up a 650/635/430w/420w/430/420 or heck even a 400... 8k list is just under the 10k the upgraded stec will cost you.
Emmet Posted June 20, 2019 Report Posted June 20, 2019 3 hours ago, M20C66Q said: Engine mounted and now the panel install begins! Will report back with panel pics, I think the first Mooney to have the G3X installed Probably not 6
Nippernaper Posted August 16, 2019 Report Posted August 16, 2019 Picked up my plane this week. Soooooooo happy with it. 8
ArtVandelay Posted August 16, 2019 Report Posted August 16, 2019 No GFC 500? If I do G3X, I’m definitely adding the AP.Tom
Nippernaper Posted August 16, 2019 Report Posted August 16, 2019 24 minutes ago, ArtVandelay said: No GFC 500? If I do G3X, I’m definitely adding the AP. Tom You've got to draw the line somewhere. I couldn't justify the extra $15k, especially with the STEC30 performing so well.
gsxrpilot Posted August 16, 2019 Report Posted August 16, 2019 4 minutes ago, Nippernaper said: You've got to draw the line somewhere. I couldn't justify the extra $15k, especially with the STEC30 performing so well. Has anyone actually had a GFC500 installed in a Mooney for $15K out the door?
Ragsf15e Posted August 16, 2019 Report Posted August 16, 2019 1 hour ago, Nippernaper said: Picked up my plane this week. Soooooooo happy with it. Looks nice! I was thinking about doing almost exactly the same. I’ve got the same avionics as you and stec 30. Curious, why keep the cdi for the SL30? Could hook both sl30 and gps into the g3x. Now since they are both digital. In an emergency, the sl30 has built in cdi functionality too.
Nippernaper Posted August 16, 2019 Report Posted August 16, 2019 Looks nice! I was thinking about doing almost exactly the same. I’ve got the same avionics as you and stec 30. Curious, why keep the cdi for the SL30? Could hook both sl30 and gps into the g3x. Now since they are both digital. In an emergency, the sl30 has built in cdi functionality too. Thanks! See discussion earlier in this thread; can't connect 2 nav sources to the G3x when using a non garmin autopilot. They may be working on a change to the stc to allow this, but I wasn't going to hold my breath.Sent from my iPhone using Tapatalk
Ragsf15e Posted August 16, 2019 Report Posted August 16, 2019 12 minutes ago, Nippernaper said: Thanks! See discussion earlier in this thread; can't connect 2 nav sources to the G3x when using a non garmin autopilot. They may be working on a change to the stc to allow this, but I wasn't going to hold my breath. Sent from my iPhone using Tapatalk Ahh, yes. Thought they changed that when they made the G5 able to use two nav sources recently. I was still thinking about leaving out the cdi for the SL30 since I so rarely use it and it has the internal one, but I’d also understand why you kept it. Nice backup to an awesome panel!
carusoam Posted August 17, 2019 Report Posted August 17, 2019 Great panel pic, Nn! Thanks for posting that. Best regards, -a-
bradp Posted August 18, 2019 Report Posted August 18, 2019 Right now the Gad29B only outputs heading and hearing error information to legacy autopilots. The Gad/G3X/G5 can’t command mode switching for a 3rd party autopilot, thus the limitations about two nav sources for these autopilots. If you display nav2 information, your autopilot could still be tracking nav1. If you have a nav source select switch like on my autopilot; you could be presenting nav 1 and flying nav2 or vice verse. The solution is having autopilot interface directly with the Gad box for all modes not just heading error (GPSS). Given that Garmin is listening (folks asked for dual G5, autopilot interface, OAT probe, GFC STCd etc and they’ve delivered), I wouldn’t be surprised if they offered a EA-100 style autopilot adapter to bring more folks into their ecosystem. I would suspect this would not be until the gee wiz factor of the GFC fades away. Pretty awesome panel BTW 1
donkaye, MCFI Posted August 18, 2019 Report Posted August 18, 2019 48 minutes ago, bradp said: Given that Garmin is listening (folks asked for dual G5, autopilot interface, OAT probe, GFC STCd etc and they’ve delivered), I wouldn’t be surprised if they offered a EA-100 style autopilot adapter to bring more folks into their ecosystem. I would suspect this would not be until the gee wiz factor of the GFC fades away. That's not going to happen.
M20C66Q Posted November 19, 2019 Report Posted November 19, 2019 Update - Mooney is all put back together and flying. This set up has been amazing and very easy to use. Finding something new it does every time I fly! 7
carusoam Posted November 20, 2019 Report Posted November 20, 2019 That is one beautiful M20C... Thanks for sharing the pic! It’s like an executive’s front office... best regards, -a-
donkaye, MCFI Posted November 20, 2019 Report Posted November 20, 2019 8 hours ago, M20C66Q said: Update - Mooney is all put back together and flying. This set up has been amazing and very easy to use. Finding something new it does every time I fly! Did the aircraft have go experimental? I notice a GFC 500 GMC 507 over there on the right, but it's not certified yet for the C Model. ??? 1
Brian E. Posted November 20, 2019 Report Posted November 20, 2019 14 hours ago, M20C66Q said: Update - Mooney is all put back together and flying. This set up has been amazing and very easy to use. Finding something new it does every time I fly! I like you gear warning indicator!
vorlon1 Posted November 20, 2019 Report Posted November 20, 2019 7 hours ago, donkaye said: Did the aircraft have go experimental? I notice a GFC 500 GMC 507 over there on the right, but it's not certified yet for the C Model. ??? 1
PJClark Posted November 22, 2019 Report Posted November 22, 2019 here's mine in case anyone still wants examples
81X Posted November 23, 2019 Report Posted November 23, 2019 On 11/19/2019 at 2:49 PM, M20C66Q said: Update - Mooney is all put back together and flying. This set up has been amazing and very easy to use. Finding something new it does every time I fly! Wow. This is some serious panel porn.
ilovecornfields Posted November 23, 2019 Report Posted November 23, 2019 On 11/19/2019 at 11:49 AM, M20C66Q said: Update - Mooney is all put back together and flying. This set up has been amazing and very easy to use. Finding something new it does every time I fly! Wow! What a clean looking panel. Very nice!
