93115F94-1873-40FA-BE06-EF5C5C2454B0.jpeg.18994f2e680123622d2557a152a82ce5.jpegI would like to replace this placard with a new one hopefully engraved either in metal or plastic.  Sorry about it being upside down. I was inverted at the time the photo was taken.  :)
What yearand serial number is your plane, I may have one
I could not find one a while back, so I printed one, laminated it, and stuck it to the panel with heavy-duty Gorilla-brand double-sided tape.  It turned out surprisingly good and I would do it again.  Far easier to read than the old ones.
I got the file from an old post on Mooneyspace.  I can't remember who posted it or I would give them credit, but here's the file attached.  It has lots of useful placards.  I did the fuel selector at the same time and in the same way, since the paint had scraped off the old one to where you couldn't read the "Off" marker.
P.S. - I can't upload the file in Word format for easy editing, although that's how I downloaded it.  I still have the Word version.  Link here:
https://1drv.ms/w/s!AjJPoJhv9yificlaEEVdN9zgkgZHCg?e=fRBSG0
Fuel Selector and Gear Placards .pdf
Did you know that there is a part number for each placard?
Often the placards a listed in the POH of modern Mooneys…
Its probably the limitations section of the POH that has them all.
PP thoughts only,
Thanks that's great. You can also upload it to https://www.stickeryou.com/ and they will print it as a decal and send it to you.
They e-mailed me a code recently FIRST18 to get 18% off an order.
