bradp Posted October 5, 2018 Report Posted October 5, 2018 @Raptor05121 Alex is your light a spot or a spot hybrid style? Thanks -B
FloridaMan Posted October 5, 2018 Report Posted October 5, 2018 For a PAR36, I went with two of the Teledyne Alphabeams. You can't even look at them even when you're in bright sunlight.
bob865 Posted October 5, 2018 Report Posted October 5, 2018 On 10/2/2018 at 3:24 PM, Raptor05121 said: I have a $250 truck light (Rigid Industries 63372) and its twice as bright as the Whelen Parmetheus. Was it a drop in replacement? I looked at their website and it looks pretty big, depth wise.
Steve W Posted October 5, 2018 Report Posted October 5, 2018 (edited) So because I love data I went out and got an inexpensive light meter and aimed at at my lights and ended up with more questions than I started with. These were the brightest spot of the beam in each case. 250W Halogen PAR 36: 1400 lux at 11feet: 13737cd(peak) but only drawing 3.5A at 28v... so something was already off here, maybe someone put in a 100W bulb instead. SunSpot 36 01-1030-4596 PAR 36 LED: 4800 lux, er no, 3000, er, no 1800, er no 1600... It stabilized at 1600 and 1.8A(28V) for 18000cd(peak), the taxi light did the same significant drop. After talking with AeroLEDs we came to the consensus that this is probably due to the testing environment with no airflow from the engine or aircraft motion, so I'll be trying to do some testing once I have an engine back. Edit: Yes, one of my right wing lights is 100W, the other is 250W, no good measurements. But it looks like the the LED will come out about twice as bright as the 250W. Edited October 7, 2018 by Steve W 1
Raptor05121 Posted October 7, 2018 Report Posted October 7, 2018 On 10/5/2018 at 6:37 AM, bradp said: @Raptor05121 Alex is your light a spot or a spot hybrid style? Thanks -B I forget. They have different part numbers for different optics. I have 63372 On 10/5/2018 at 7:48 AM, bob865 said: Was it a drop in replacement? I looked at their website and it looks pretty big, depth wise. It is very big and hefty. I was surprised, it seems ultra-high quality. It is thicker and I did have to re-install the retaining ring. It sits 1/8" more forward so you'll need to drill 3 new screws but its a lot more snug than the old landing light. I installed the LASAR landing light cover when I did my LED conversion seeing as I didn't need to replace it every 25 hours 1 1
MIm20c Posted October 8, 2018 Report Posted October 8, 2018 19 hours ago, Raptor05121 said: I forget. They have different part numbers for different optics. I have 63372 It is very big and hefty. I was surprised, it seems ultra-high quality. It is thicker and I did have to re-install the retaining ring. It sits 1/8" more forward so you'll need to drill 3 new screws but its a lot more snug than the old landing light. I installed the LASAR landing light cover when I did my LED conversion seeing as I didn't need to replace it every 25 hours Do you find the spot/hyper spot too narrow for the flare? Comparing the 63372 to the 63362 (drive/hyperspot). Any cheaper source, looks like they have $350 map pricing.
Raptor05121 Posted October 9, 2018 Report Posted October 9, 2018 On 10/8/2018 at 7:45 AM, MIm20c said: Do you find the spot/hyper spot too narrow for the flare? Comparing the 63372 to the 63362 (drive/hyperspot). Any cheaper source, looks like they have $350 map pricing. Yeah I wouldn't be opposed to trying out something with a few degrees wider beam, TBH. But it makes up for it when you're on a 2-mile final and that pencil beam lights up the entirety of a 75' wide runway and the first 2,000 feet
NotarPilot Posted October 16, 2018 Report Posted October 16, 2018 @NicoN In case you haven’t made a decision yet, I just wrote a threat about a new landing light coming out from Whelen.
Raptor05121 Posted October 16, 2018 Report Posted October 16, 2018 On 10/5/2018 at 6:37 AM, bradp said: @Raptor05121 Alex is your light a spot or a spot hybrid style? Thanks -B On 10/8/2018 at 7:45 AM, MIm20c said: Do you find the spot/hyper spot too narrow for the flare? Comparing the 63372 to the 63362 (drive/hyperspot). Any cheaper source, looks like they have $350 map pricing. Made this for you guys. I chose the 63372 because it has 5 more watts. I'd probably choose the wider beam if I did it over again The cheapest seller I found after 2 minutes of searching- $324.98https://www.desertrat.com/i-23303512-rigid-industries-63362-r-series-r2-46-combo-spot-driving-led-light.html
Rookie Posted October 20, 2018 Report Posted October 20, 2018 On October 16, 2018 at 2:35 AM, Raptor05121 said: Made this for you guys. I chose the 63372 because it has 5 more watts. I'd probably choose the wider beam if I did it over again The cheapest seller I found after 2 minutes of searching- $324.98https://www.desertrat.com/i-23303512-rigid-industries-63362-r-series-r2-46-combo-spot-driving-led-light.html How many hours you think you have been running this light?
Raptor05121 Posted October 23, 2018 Report Posted October 23, 2018 On 10/20/2018 at 11:15 AM, Rookie said: How many hours you think you have been running this light? I leave the switch on all the time. Even during start, it barely dims. I've probably got about 200 hours behind it now. 1
Skates97 Posted October 23, 2018 Report Posted October 23, 2018 Right now Amazon has that light for $162.47. https://smile.amazon.com/gp/product/B0102OHDNA?pf_rd_p=faa1d3e1-fadf-4279-ac2d-3096206e4690&pf_rd_r=V8EC1TWW0G8DWX3VKYE8
ArtVandelay Posted October 23, 2018 Report Posted October 23, 2018 Right now Amazon has that light for $162.47.https://smile.amazon.com/gp/product/B0102OHDNA?pf_rd_p=faa1d3e1-fadf-4279-ac2d-3096206e4690&pf_rd_r=V8EC1TWW0G8DWX3VKYE8 What’s the difference (other than price) between this one https://www.amazon.com/Rigid-Industries-63342-Retrofit-Hyperspot/dp/B0102OHNBW/ref=pd_sbs_263_2?_encoding=UTF8&pd_rd_i=B0102OHNBW&pd_rd_r=483c12c6-d6d3-11e8-a3ac-754b11e3c94d&pd_rd_w=Orq8t&pd_rd_wg=rFjKc&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=7d5d9c3c-5e01-44ac-97fd-261afd40b865&pf_rd_r=B10WA0276TKD9PY2JDBA&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=B10WA0276TKD9PY2JDBAand one above?
Skates97 Posted October 23, 2018 Report Posted October 23, 2018 12 minutes ago, teejayevans said: What’s the difference (other than price) between this onehttps://www.amazon.com/Rigid-Industries-63342-Retrofit-Hyperspot/dp/B0102OHNBW/ref=pd_sbs_263_2?_encoding=UTF8&pd_rd_i=B0102OHNBW&pd_rd_r=483c12c6-d6d3-11e8-a3ac-754b11e3c94d&pd_rd_w=Orq8t&pd_rd_wg=rFjKc&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=7d5d9c3c-5e01-44ac-97fd-261afd40b865&pf_rd_r=B10WA0276TKD9PY2JDBA&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=B10WA0276TKD9PY2JDBA and one above? Looks like the 63342 has a narrower beam than the 63362. I think that I would want the wider beam and for half the price it's just a bonus. Edit: Oh, and 2 lbs lighter...
ArtVandelay Posted October 23, 2018 Report Posted October 23, 2018 Looks like the 63342 has a narrower beam than the 63362. I think that I would want the wider beam and for half the price it's just a bonus. Edit: Oh, and 2 lbs lighter... And bigger than original par 46 (5.75”), so they won’t fit?
Rookie Posted October 23, 2018 Report Posted October 23, 2018 8 hours ago, Raptor05121 said: I leave the switch on all the time. Even during start, it barely dims. I've probably got about 200 hours behind it now. Did this light fit or was there some fabrication needed to fit it in the hole?
Skates97 Posted October 23, 2018 Report Posted October 23, 2018 34 minutes ago, teejayevans said: And bigger than original par 46 (5.75”), so they won’t fit? The actual measurements that they are giving are showing 5.65" diameter. Alex said that he had to drill new holes because the retaining ring sat 1/8" more forward but that it fit in the hole.
MIm20c Posted October 23, 2018 Report Posted October 23, 2018 I hope a MS’er got the good deal, it looks to be Back at 350 now. I purchased one to test against the Whelen last week and spent $100 more, oh well.
Raptor05121 Posted October 24, 2018 Report Posted October 24, 2018 11 hours ago, teejayevans said: And bigger than original par 46 (5.75”), so they won’t fit? 10 hours ago, Rookie said: Did this light fit or was there some fabrication needed to fit it in the hole? Standard PAR46 size. It slid in fine. Its depth is bigger so the retaining ring sits more forward, probably 1/8" inch. You could have used a dremel on the light, I opted to just use the self-tapping screws and make 3 more holes. Its super tight now, whereas the old incandescent would wiggle around.
carusoam Posted October 24, 2018 Report Posted October 24, 2018 That reminds me... My 65C hard some foamy rubber electrical tape to occupy some of the extra space... that was for the old ge incandescent bulb. Thanks for the memories... Beat regards, -a-
chriscalandro Posted February 16, 2019 Report Posted February 16, 2019 I've just ordered the 63362... Opted for the wider beam. Let's see how it goes!
Two Oh One Posted February 17, 2019 Report Posted February 17, 2019 5 hours ago, chriscalandro said: I've just ordered the 63362... Opted for the wider beam. Let's see how it goes! I've been considering the same (wider), but I wonder how much of that advantage would be shadowed by the depth of our cowl light housing..
jaylw314 Posted February 17, 2019 Report Posted February 17, 2019 42 minutes ago, Two Oh One said: I've been considering the same (wider), but I wonder how much of that advantage would be shadowed by the depth of our cowl light housing.. I have the Aerolites PAR46 which has a few elements that have dispersing lenses for taxiing. It seems to work fine despite the recessed lamp, probably because it's not just one single element at the center.
larrynimmo Posted February 22, 2019 Report Posted February 22, 2019 ok I did the test.... I changed out my less than a half year Whelen Parmetheus Plus Par46....with the newest Sunsetter. The Whelen has a much stronger pencil thin spot light that helps with earlier illumination of runway stripes from a great distance....and this is a great feature...but when you only have one bulb the benefits of a hybrid outweigh that spot. The Sunsetter really lights the way for wide illumination allowing for ground transit in an unfamiliar airport. And the sunsetter does a more than adequate illumination of the runway on short final. The Whelen cost $300, and the sunsetter cost $150...I will be staying with the lower cost bulb. If anybody wants a deal on the Whelen, PM and make me an offer! It is about 6 months old and has had about 20 hours of operation as I don't leave it on all the time...and its in absolutely new condition.
chriscalandro Posted March 3, 2019 Report Posted March 3, 2019 Here it is. I'm not sure how well the picture translates but it's bright. 1
