larrynimmo Posted November 11, 2021 Report Posted November 11, 2021 All I can say is wow…. how much was the paint job and how long did they take…how long was the wait time to get your plane in with them? Quote
ArtVandelay Posted November 11, 2021 Report Posted November 11, 2021 Never considered changing the tail number? Quote
cferr59 Posted November 11, 2021 Report Posted November 11, 2021 Wow, that is a nice looking Mooney! Quote
Danb Posted November 11, 2021 Report Posted November 11, 2021 On 11/11/2021 at 8:57 PM, 201er said: Expand Absolutely gorgeous Mike Quote
Guest Posted November 12, 2021 Report Posted November 12, 2021 What’s up with the trim tab on the right aileron? Clarence Quote
Bartman Posted November 12, 2021 Report Posted November 12, 2021 Beautiful ! I remember seeing your pictures and videos with paint missing on the leading edges. You should be proud of your “new” mooney. 1 Quote
201Steve Posted November 12, 2021 Report Posted November 12, 2021 On 11/11/2021 at 10:36 PM, ArtVandelay said: Never considered changing the tail number? Expand There’s nothing to change it to unless he pays for my new paint job/N number. 1 7 Quote
201er Posted November 12, 2021 Author Report Posted November 12, 2021 On 11/12/2021 at 1:48 AM, 201Steve said: There’s nothing to change it to unless he pays for my new paint job/N number. Expand Poser 1 4 Quote
Marauder Posted November 12, 2021 Report Posted November 12, 2021 You’ve come a long way from this Mike. Sent from my iPhone using Tapatalk Pro 1 Quote
ArtVandelay Posted November 12, 2021 Report Posted November 12, 2021 On 11/12/2021 at 12:20 AM, M20Doc said: What’s up with the trim tab on the right aileron? ClarenceGood eyes: Quote
mike_elliott Posted November 12, 2021 Report Posted November 12, 2021 one of Norm's aftermarket kits. First time I have seen one mounted on the right however. I had one on my F when I owned it, and would have removed it when it was repainted as the AP made this moot, but that would have been major skin surgery and rebalance, so most likely, Mikey took the same ole cheap way out i did and left the tab there while gutting the electronics. 1 Quote
ArtVandelay Posted November 12, 2021 Report Posted November 12, 2021 On 11/12/2021 at 3:29 PM, bluehighwayflyer said: Mike has long range tanks I believe. Norm’s Aero Trim probably helps him balance the load.Why would it be right side heavy? Quote
Andy95W Posted November 12, 2021 Report Posted November 12, 2021 (edited) Actually, the Aero-Trim is installed on the left aileron per Norm Smith’s STC (but yes, it can be installed as rudder trim). I’m not sure what Mike has on his right aileron, but it looks like a riveted on ground adjustable trim tab. Edited November 12, 2021 by Andy95W 1 Quote
aviatoreb Posted November 12, 2021 Report Posted November 12, 2021 On 11/12/2021 at 5:05 PM, Andy95W said: Actually, the Aero-Trim is installed on the left aileron per Norm Smith’s STC (but yes, it can be installed as rudder trim). I’m not sure what Mike has on his right aileron, but it looks like a riveted on ground adjustable trim tab. Expand Interesting - I never heard of this - is there a trim wheel in the cockpit that goes with this setup? Why would someone want it on their aileron instead of their rudder? Quote
201er Posted November 12, 2021 Author Report Posted November 12, 2021 Mine is just a bendable piece of metal. Didn’t realize this wasn’t standard. Quote
Andy95W Posted November 12, 2021 Report Posted November 12, 2021 On 11/12/2021 at 5:24 PM, aviatoreb said: Interesting - I never heard of this - is there a trim wheel in the cockpit that goes with this setup? Why would someone want it on their aileron instead of their rudder? Expand It’s all electric. Not a bad kit, I installed it on my first M20C. http://www.aerotriminc.com/id2.html 1 Quote
philip_g Posted November 12, 2021 Report Posted November 12, 2021 On 11/12/2021 at 5:24 PM, aviatoreb said: Interesting - I never heard of this - is there a trim wheel in the cockpit that goes with this setup? Why would someone want it on their aileron instead of their rudder? Expand Our rocket had it on the rudder. The little servo stripped out and it didn't work any longer 1 Quote
EricJ Posted November 12, 2021 Report Posted November 12, 2021 Nicely done! Definitely looks good! Quote
jetdriven Posted November 12, 2021 Report Posted November 12, 2021 On 11/12/2021 at 4:13 AM, Marauder said: You’ve come a long way from this Mike. Sent from my iPhone using Tapatalk Pro Expand 2 Quote
Guest Posted November 13, 2021 Report Posted November 13, 2021 On 11/12/2021 at 1:04 PM, mike_elliott said: one of Norm's aftermarket kits. First time I have seen one mounted on the right however. I had one on my F when I owned it, and would have removed it when it was repainted as the AP made this moot, but that would have been major skin surgery and rebalance, so most likely, Mikey took the same ole cheap way out i did and left the tab there while gutting the electronics. Expand It doesn’t have a hinge, you’ll see if you zoom in on the screen shot. Clarence Quote
jetdriven Posted November 13, 2021 Report Posted November 13, 2021 On 11/13/2021 at 1:11 AM, M20Doc said: It doesn’t have a hinge, you’ll see if you zoom in on the screen shot. Clarence Expand It’s just a piece of .032 riveted into the trailing edge of the aileron. I suppose the person who did that didn’t know you can adjust the flap up stop and the aileron trailing edge to get the same effect. Quote
mike_elliott Posted November 13, 2021 Report Posted November 13, 2021 On 11/13/2021 at 1:11 AM, M20Doc said: It doesn’t have a hinge, you’ll see if you zoom in on the screen shot. Clarence Expand .....humm... MIke, any log entries to demystify this "attachment"? Quote
201er Posted November 13, 2021 Author Report Posted November 13, 2021 On 11/13/2021 at 2:11 PM, mike_elliott said: .....humm... MIke, any log entries to demystify this "attachment"? Expand Not that I’m aware of. That was definitely there when I got it ten years ago. I figured it came that way. I do believe there may have been some work on flaps or ailerons due to gear up in the past. Quote
