jaylw314 Posted November 6, 2020 Report Posted November 6, 2020 23 minutes ago, eman1200 said: Not according to some PoH’s I mean, if you’re into those things. I read that as talking about 4 separate things: Enroute climb (100-114 KIAS) Max rate climb (89-98 KIAS) Max angle climb (82 KIAS) Normal climb (2600 RPM/26" MAP) Quote
Owen M20F Posted November 6, 2020 Author Report Posted November 6, 2020 On 11/4/2020 at 7:00 AM, KB4 said: For J, but just fill in for the E CONTROL PERFORMANCE MP RPM AI AIRSPEED RATE OF CLIMB/DESCENT CLIMB Standard 26 26 110 Constant AS Vx 26 26 10⁰ - 12⁰ 69 1200 Constant AS Vy 26 26 7⁰ 88 1000 Constant Rate 500/min 26 26 500 S + L MP RPM AI AIRSPEED RATE OF CLIMB/DESCENT Cruise 25 25 Level 160 23 23 Level 145 Approach at 90kts 12 23 90 DESCENT MP RPM AI AIRSPEED RATE OF CLIMB/DESCENT Constant AS 11 23 4.5⁰ 100 500 Constant Rate 15 23 90 500 Cruise Descent 19 23 4.5⁰ 148 500 PRECISION APP 11 23 90 500 NON-PRECISION APP 800 Mooney Power Settings .xlsx 11.48 kB · 10 downloads The only issue with this is i have the rpm limitation on the F i can’t do a constant 2300 rpm i can do 2400-2700 Quote
Shiny moose Posted November 9, 2020 Report Posted November 9, 2020 I think this is what your wanting Go make your own is the easiest. if its for IFR training make it simple, you dont want a lot of different airspeeds, 90kts/103mph is your friend for IFR training. Use it for all except cruising enroute to train. Keep it simple, dont be jamming in full power in for missed approach go fly in the climb trim for 90KTS, dont touch your trim again, slowly pull power to levl your alt, note power setting, put gear down use power only to get -500( you wont need much if any ) , then -750, now level alt with gear down, now climb(to climb SLOWLY add A few inches above your 90KTlevel power setting and pull up gear all at 90 KTS ) , level at 90, using the first power setting you found 90KT level power setting, write all down, add all configurations you want, if you use flaps you will have to retrim and your workload will increase, keep it simple, these are starting points, add configurations for your needs Speed MP RPM flaps gear ROC/ROD 90. 00 90. -500 90. -750 90 + whatever for MA climb Quote
tony Posted July 11, 2021 Report Posted July 11, 2021 On 11/4/2020 at 9:29 PM, VinceCB said: For vintage Mooney flyers out there, do you approach with flaps? Having recently bought my E I haven't yet had the chance to start experimenting but was wondering what to do about this since the flap operating speed is 100mph (86 kts). If you approach at 90kts to minimums on an ILS (200 AGL), is it difficult to dump the speed? Or do you simply fly the approach slower? I configure my aircraft to be ready for a go around (50 percent flaps) If I have to go around, I want to do as little work as possible. Full throttle and pick up the gear. Quote
midlifeflyer Posted July 11, 2021 Report Posted July 11, 2021 On 11/4/2020 at 1:36 PM, Hank said: Wow! All of my Climbs are at 2700, and Descents are at the same RPM as used for cruise. It's funny. When I do complex transition training, pilots are often concerned about the many potential prop settings. To KISS, I teach there are only 3 they actually need to use on any given flight. Full. Enroute climb (and some don't even change for that). Cruise. The rest are just repeats of those three. 1 Quote
M20F Posted July 12, 2021 Report Posted July 12, 2021 On 11/4/2020 at 9:40 PM, gsxrpilot said: In my M20C I never used flaps on an instrument approach. You're guaranteed to have a longish runway and it's one less thing to do. I like to have half flaps at IAF so the plane is configured to go around. I tend to not go to full flaps if we are expecting to get to 200’ on the break out. Still the same concept with the longish runway except I always make the assumption on an approach that I will always go missed and not land. Quote
eman1200 Posted July 12, 2021 Report Posted July 12, 2021 2 hours ago, M20F said: I like to have half flaps at IAF so the plane is configured to go around. I tend to not go to full flaps if we are expecting to get to 200’ on the break out. Still the same concept with the longish runway except I always make the assumption on an approach that I will always go missed and not land. the IAF or the FAF? the IAF seems like a looong way out to have any flaps out. Quote
Hank Posted July 12, 2021 Report Posted July 12, 2021 1 hour ago, eman1200 said: the IAF or the FAF? the IAF seems like a looong way out to have any flaps out. I like to be near 105 mph with Takeoff flaps at the IAF. Works well. Whatever cruise RPM & EGT were. Quote
M20F Posted July 12, 2021 Report Posted July 12, 2021 2 hours ago, eman1200 said: the IAF or the FAF? the IAF seems like a looong way out to have any flaps out. FAF, sorry bad typing. Drop the gear and flaps right before FAF and it rides the G/S down with a little trim. 1 Quote
eman1200 Posted July 12, 2021 Report Posted July 12, 2021 FAF, sorry bad typing. Drop the gear and flaps right before FAF and it rides the G/S down with a little trim. Yep, that makes more sense, thanks. Now if we can just get Hank some instrument training…. Quote
Hank Posted July 12, 2021 Report Posted July 12, 2021 21 minutes ago, eman1200 said: Yep, that makes more sense, thanks. Now if we can just get Hank some instrument training…. Hank slows to 90 knots /105 mph around the IAF, and puts out Takeoff flaps. When the glideslope needle is 1-1/2 dots Hugh, I drop gear and ride the slope down with minimal changes. Works well for me. Depending on the situation, I can go faster but still back off and slow down by FAF. Too hard trying to slow down during descent, not something I want to mess with in IMC. Be slow, have flaps out, dropping gear starts descent. Sorry for those of you with low flap speeds. Vfo = 125 mph; Vg = 120 mph. This process works well. Quote
M20F Posted July 13, 2021 Report Posted July 13, 2021 8 hours ago, Hank said: Hank slows to 90 knots /105 mph around the IAF, and puts out Takeoff flaps. When the glideslope needle is 1-1/2 dots Hugh, I drop gear and ride the slope down with minimal changes. Works well for me. Depending on the situation, I can go faster but still back off and slow down by FAF. Too hard trying to slow down during descent, not something I want to mess with in IMC. Be slow, have flaps out, dropping gear starts descent. Sorry for those of you with low flap speeds. Vfo = 125 mph; Vg = 120 mph. This process works well. Generally the step down from IAF to FAF is not that much to be an issue. Flying around very slow straight and level in the clouds for often 5-10 NM from IAF to the FAF increases the chances of an inadvertent stall. With no gear to get 90KTS you need a very high nose pitch. With gear out then it is still a high pitch but now with a lot of power (which leads to CHT issues). Given you are more than likely going to have wind on the nose in an approach, you are looking 8-10 minutes in this configuration. I think (and in fairness my opinion) slowly working the power back a bit prior to IAF to hit 120 about a mile from FAF is a better solution. Then dump the gear, hold it level, get to flap speed, and dump to half flaps right before IAF (or in your case flop gear/flaps). Personally I do not like to be on the bottom half of the white arc with the nose pointed anywhere but down. Especially in IMC. 1 Quote
TCSMOORE Posted July 10, 2023 Report Posted July 10, 2023 M20F performance numbers please Here is a Google Sheets editable link https://docs.google.com/spreadsheets/d/1QBrUp6av3abXrmvp4r-drpY5Ab02Cow4FrZ38M9POus/edit I am flying an Australian 1998 M20F Ovation VH-OID and would love someone to edit this sheet with the appropriate numbers as related to an M20F Kind regards Tim Quote
midlifeflyer Posted July 10, 2023 Report Posted July 10, 2023 On 11/4/2020 at 6:05 PM, Marauder said: 1975 F Sent from my iPad using Tapatalk Pro Nice. What I like best is that it's short. The problem I see with many is that they have too much. Owners tend to memorize them eventually but those of us who fly multiple makes and models use them all the time in flight as a reference. That means finding things at a glance. Some I've seen makes that impossible. I don't have one for an F but all of mine only have five entries - all approach related: Vectoring (not just for vectoring. A step-down speed once in the approach environment. I started doing that when I learned to fly a J. It became essential in an Ovation :D) Approach Level APV Descent MDA Descent (any approach that does not have vertical guidance) MDA Level I discovered fairly quickly that the others were just basic checklist items whether VFR or IFR or non-critical. Everyone needs to decide on what they need as a reference but, like checklists, I think ergonomics/usability is more important than extreme detail. 1 Quote
jetdriven Posted July 10, 2023 Report Posted July 10, 2023 On 11/3/2020 at 10:37 PM, Owen M20F said: Anyone have a chart for Power settings for instrument approaches and what not? I’m a new owner and am about to start instrument training in it and thing this info would be very helpful. Thanks Instrument training is easy. leave the prop at 2500 RPM, and use the throttle like a 172, power for airspeed. pull the mixture back 1/3rd. Spend your time on instrument flying. Quote
RoundTwo Posted July 10, 2023 Report Posted July 10, 2023 16 minutes ago, jetdriven said: Instrument training is easy. leave the prop at 2500 RPM, and use the throttle like a 172, power for airspeed. pull the mixture back 1/3rd. Spend your time on instrument flying. Party pooper. Quote
jetdriven Posted July 10, 2023 Report Posted July 10, 2023 let me revise that. Instrument training is quite intense and can be difficult, but the engine part is easy. Just park it at 20-23" for the terminal area, and its less than that during the approach. 1 Quote
Pinecone Posted July 10, 2023 Report Posted July 10, 2023 On 11/5/2020 at 12:49 PM, M20F said: The charts are +/- 3% out of the gate, I don’t think @ 5 HP is going make much of a difference. To each their own but I don’t see the difference. That difference is 6.5%, which on a 180 HP engine is almost 12 HP. 10 extra HP on a 252 is part of making it an Encore and 230 high gross weigh. Quote
Pinecone Posted July 10, 2023 Report Posted July 10, 2023 On 11/5/2020 at 7:13 PM, eman1200 said: Not according to some PoH’s I mean, if you’re into those things. That is talking about a normal climb after you get some altitude, not a Vx or Vy climb due to obstacles or climb gradients. And reduced power climbs were the normal back when that POH was written, but current practice is full power climbs to altitude. Quote
eman1200 Posted July 10, 2023 Report Posted July 10, 2023 That is talking about a normal climb after you get some altitude, not a Vx or Vy climb due to obstacles or climb gradients. And reduced power climbs were the normal back when that POH was written, but current practice is full power climbs to altitude. Maybe YOUR current practice. Quote
Hank Posted July 10, 2023 Report Posted July 10, 2023 15 minutes ago, eman1200 said: Maybe YOUR current practice. It's current practice for many of us. Starting with the mighty 172 as a student, and the last 15 years as a Mooney owner. Like all generalities, it does not apply to everyone. 1 Quote
midlifeflyer Posted July 10, 2023 Report Posted July 10, 2023 On 11/4/2020 at 9:29 PM, VinceCB said: For vintage Mooney flyers out there, do you approach with flaps? Having recently bought my E I haven't yet had the chance to start experimenting but was wondering what to do about this since the flap operating speed is 100mph (86 kts). If you approach at 90kts to minimums on an ILS (200 AGL), is it difficult to dump the speed? Or do you simply fly the approach slower? I don't. For me, it's not even matter of a low Vfe. It started when my CFII failed trying to get me to use them in a C172 during my training. I use approach flaps in 4-5 of the 30 or so make/models of singlesI've flown. Mooney Js (sometimes) and Rs, Cessna 182 RGs (the approach flap speed is 140 KIAS), and Cirrus SR22 and 20. Quote
mike_elliott Posted July 10, 2023 Report Posted July 10, 2023 my recommendation wouild be approach (TO) flaps at glide slope intercept along with gear down. With correct PAC setting, this shouldnt require much if any retrim for a 3 Deg 600'/min decent. Full flaps after you break out and will land. YMMV, but this works well in Mooneys, 1 Quote
midlifeflyer Posted July 10, 2023 Report Posted July 10, 2023 10 minutes ago, mike_elliott said: my recommendation wouild be approach (TO) flaps at glide slope intercept along with gear down. With correct PAC setting, this shouldnt require much if any retrim for a 3 Deg 600'/min decent. Full flaps after you break out and will land. YMMV, but this works well in Mooneys, Dont know about all those others Mark has flown. In all of them, there are those who insist on approach flaps. Strictly a matter of technique. Since I don't do primary instrument training, when a pilot flies with me they already have their system. If it's a transition from fixed to retractable gear and they've already developed a preference, I won't mess with it (First Commandment of Flight Instructing). You will get exactly the same effect you describe without flaps. If you are already at target speed, putting the gear down with no flaps will result in a 3° glidepath with no change in IAS and no need to retrim. I was surprised that most every retract I flew behaved the same way. Quote
mike_elliott Posted July 10, 2023 Report Posted July 10, 2023 For me, its not a matter of insisting on approach flaps, it is a matter of developing in a new instrument student good habits, and proper configuration for the phase of flight. As one moves up to bigger equipment, this becomes more and more critical with less wiggle room, so we try to start new IR clients off with structure and regimentation here. Quote
