I'm looking to take on some new FAA STC modification projects and looking for ideas.  Please send me a private message if you have any ideas or suggestions.
Expand
Recognition light replacement with LED bulb, direct replace to existing socket would be a killer.
  • Like 5
Hi!
Since 6 years I own a 201. It's a wonderful bird, but the engine doesn't fit in our time anymore. I think the Continental Diesel could be a good combination. Especially because there is the plan to create 170hp out of this 2-liter-engine, MT offers a netter scimitar prop die Diesel usage and the future of avgas is uncertain. What do you think about it?
Expand
http://aerotriminc.com/
Norm Smith passed away a few years ago and had a few STC mods for Mooneys including aileron trim (http://aerotriminc.com/id2.html).
I think the daughter may still be selling a few. (http://aerotriminc.com/id1.html)
Expand
I did speak with his daughter, Elyse. Very friendly and nice to talk to.
Bring back the inner gear doors for the older models. That's been abandoned.
  On 4/3/2020 at 12:03 PM, Marcus Spreti said:
Hi!
Expand
Thanks for the suggestion.  However, the cost to recertify an new engine/airframe combination is big $$$.  A re-engine effort could be in the $300K+ range. Even if you amortized the cost of the engineering/cert across 50 customers, it would be $6,000 plus $50,000 (engine estimate), $15,000 (prop estimate), $8,000 (installation) and $5,000 (charge for STC rights) results in a $84,000 upgrade modification...probably not many takers.
Additional landing lights for older models? Saw a Euro Mooney with ones on the gear.
Electric turbo? Is the m20E rayjay a thing anymore?
Standby alt for the short bodies?
Battery box conversion to move the batteries aft in a long body so as to be able to get rid of charlie ballast - maybe in conjunction with new battery technology too
Some way to get additional heat to the interior of a Bravo and maybe other long bodies (eg a heatsink on the firewall from the oil)
Glareshield dimmer and other interior light circuit 'adjustments' to go LED
Lightweight air-con at a sensible price
  On 4/9/2020 at 2:28 AM, Gagarin said:
Long Range Fuel Tanks for Mooney
Best mod I had 36 gallons extra on my M20J and 1500nm range
http://www.monroyaero.com/lrupgad.pdf
Expand
How about an integral/bladder hybrid system.  Adding a bladder to the wing bay outboard of the integral fuel tanks.  A bladder holding, say, 5 gal (per side) going from 48 gal to 58 would be a big help to me.  Increased range without the complexity of installing an outboard integral tank (although preferred) nor all the additional weight of converting the factory integral tanks to a full bladder system.
  On 4/9/2020 at 2:44 PM, mike_elliott said:
Dont forget a pee tube STC as an option, along with WD40+ belly cleaner for guaranteed 15 kts and FIKI :)
Expand
And some real drain valves for those long range tanks.
