Lukon Posted December 6, 2019 Report Posted December 6, 2019 (edited) Getting ready to do another oil change. Wondering how people feel about AeroShell 100W vs Phillips66 100AW. I've always used AeroShell, but the Phillips66 is much cheaper, and they seem to be the same thing. Also, where do you guys buy your oil and filters. I'm always looking to save a buck... Edited December 6, 2019 by Lukon (sp)
cctsurf Posted December 7, 2019 Report Posted December 7, 2019 you can start a holy war with this sort of question... Depends very much on the temperatures and usage you have in mind. I know a pilot who ran aeroshell and was having issues with his engine. cussed out one of Continental's major players about it (he's prone to cussing people out, but really did a job on this one). Switched engine oil to Philips and the problem went away. 1
Yetti Posted December 7, 2019 Report Posted December 7, 2019 It doesn't really have a company name on it when it comes out of the ground. 1
N201MKTurbo Posted December 7, 2019 Report Posted December 7, 2019 The oil doesn’t matter as much as how you use it. 1
Browncbr1 Posted December 7, 2019 Report Posted December 7, 2019 Fly every week LOP and change at 25 hours and it doesn’t matter much which you go with. 2
Jim Peace Posted December 7, 2019 Report Posted December 7, 2019 Just last week I switched from Shell 15w50 to Phillips 66 x/c 20w50 plus camguard. I did it mostly from the good things I hear about the Phillips/Camguard combination......oil analysis will tell the story.....I really had no problems with shell performance but always looking to improve...I fly about 100+ hours a year but I also go through on average about 6 times a year with no flying for almost 2 to 3 weeks.....plane based in a non air-conditioned Florida hangar..... 1
markgrue Posted December 7, 2019 Report Posted December 7, 2019 The new phillips 20W50 does not require the camguard. It is already in it. with that said I use aeroshell 15w50 in every aircraft. Never a problem with it. Mark
ilovecornfields Posted December 7, 2019 Report Posted December 7, 2019 (edited) 10 minutes ago, markgrue said: The new phillips 20W50 does not require the camguard. It is already in it. with that said I use aeroshell 15w50 in every aircraft. Never a problem with it. Mark Mark, I don’t think that statement is correct. There is a new Phillips oil with the lycoming additive but it is not Camguard. https://www.google.com/amp/s/generalaviationnews.com/2019/08/09/phillips-66-introduces-new-oil-pre-blended-with-lycoming-anti-wear-additive/amp/ Edited December 7, 2019 by ilovecornfields 2 2
markgrue Posted December 7, 2019 Report Posted December 7, 2019 I stand corrected. It is the Lycoming additive. Mark
carusoam Posted December 7, 2019 Report Posted December 7, 2019 CCT, For additional confusion find the thread that has a SB(?) advising why you shouldn’t change types of oils once you have selected one... does this and that have anything in common? Best regards, -a- 1
tmo Posted December 7, 2019 Report Posted December 7, 2019 8 hours ago, ilovecornfields said: Mark, I don’t think that statement is correct. There is a new Phillips oil with the lycoming additive but it is not Camguard. https://www.google.com/amp/s/generalaviationnews.com/2019/08/09/phillips-66-introduces-new-oil-pre-blended-with-lycoming-anti-wear-additive/amp/ And to add to this, I think this should not be used in Continental engines, because the Lycoming additive (only really needed for one Lycoming engine, IIRC) will possibly cause starter slippage issues.
cferr59 Posted December 7, 2019 Report Posted December 7, 2019 Aeroshell is semi-synthetic. One big benefit of synthetic oil is a longer change interval. Unfortunately, we can't take advantage of that because of the we use leaded fuel and the oil ends up very dirty. So, it is not worth the extra cost for Aeroshell. 2
takair Posted December 7, 2019 Report Posted December 7, 2019 So, has anybody tried the new Phillips Victory AW 20W-50 with the Lycoming additive? I assume that one would not add Cam Guard on top of this, is that correct? I thought I read somewhere that CamGuard may have other benefits, but too much of a good thing could be a bad thing too....
Yetti Posted December 7, 2019 Report Posted December 7, 2019 The bigger question is did Phillips jack up their prices like Shell a couple of months ago.
Jim Peace Posted December 7, 2019 Report Posted December 7, 2019 12 hours ago, carusoam said: For additional confusion find the thread that has a SB(?) advising why you shouldn’t change types of oils once you have selected one... http://www.tcmlink.com/pdf2/SIL19-04.pdf 1
Andy95W Posted December 8, 2019 Report Posted December 8, 2019 On 12/7/2019 at 9:03 AM, takair said: So, has anybody tried the new Phillips Victory AW 20W-50 with the Lycoming additive? I assume that one would not add Cam Guard on top of this, is that correct? I thought I read somewhere that CamGuard may have other benefits, but too much of a good thing could be a bad thing too.... I'm using it because I got it cheap at OSH. I love it. Aviation Consumer magazine found a lot of benefit to the Lycoming additive for reducing corrosion in their tests. They found even more benefit to the additive plus Camguard or Avblend. The Lycoming additive is the only additive actually recommended by an engine manufacturer for helping reduce camshaft and lifter scuffing/wear. It is only required by AD for the O-320-H engines, but it's recommended for all. That's good enough for me. I also use Avblend in the summer and Camguard in the winter, but I'll admit I might be paranoid. 1
kerry Posted December 9, 2019 Report Posted December 9, 2019 I buy Phillips from a local oil supply warehouse. Price is better vs. Spruce or anything I can find online.
ilovecornfields Posted December 9, 2019 Report Posted December 9, 2019 This place seemed pretty reasonable. Free shipping with 2 cases: https://aviationoiloutlet.com/blog/phillips-66-victory-aw-20w50-now-available-/
1964-M20E Posted December 9, 2019 Report Posted December 9, 2019 I run either the Phillips 100AW or the 20W-50 victory. Of course being a Phillips 66 employee I have to support the home team. However, I have been running Philips since I bought my first plane in 2010 and prior to me becoming a P66 employee. So no one asks we do not make the 100AW or 20W-50 here. We don't even make avgas but we do make jet fuel.
PT20J Posted December 9, 2019 Report Posted December 9, 2019 39 minutes ago, 1964-M20E said: So no one asks we do not make the 100AW or 20W-50 here. We don't even make avgas but we do make jet fuel. OK, so now I have to ask: who makes the oil?
1964-M20E Posted December 10, 2019 Report Posted December 10, 2019 7 hours ago, PT20J said: OK, so now I have to ask: who makes the oil? I don't know. At lest when you are mushroom the keep you in the dark and they feed you. I'm still waiting to be fed. 1
PT20J Posted December 11, 2019 Report Posted December 11, 2019 I installed a factory rebuilt IO-360-A3B6 in my J a year ago October. After the first 5 hours, oil consumption on AS 100 stabilized at 8.5 hr/qt. At 40 hours I switched to AS W100. Up until we did the annual inspection last October, it was burning 8.5 hr/qt consistently. At the annual, I switched to X/C 20W-50. It's got ten hours on the oil and it's still down less than a quart. Too early to tell, but it looks like it burns less on Phillips. Anyone else notice this? Skip
Andy95W Posted December 12, 2019 Report Posted December 12, 2019 My O-360 is about the same. About 12 hours for the first quart, then about 8-10 for the second quart. After that I generally change it anyway due to months.
