FloridaMan Posted November 7, 2019 Report Posted November 7, 2019 What’s the easiest way to clean lead off the belly of a Mooney? Quote
RLCarter Posted November 7, 2019 Report Posted November 7, 2019 Aircraft Spruce sells a product that removes exhaust stains, the local guy at my airport uses it when he details planes, but he is on vacation so I can't ask him 1 Quote
PTK Posted November 7, 2019 Report Posted November 7, 2019 On 11/7/2019 at 10:10 AM, FloridaMan said: What’s the easiest way to clean lead off the belly of a Mooney? Expand I have found AeroShell Flight Jacket Oil & Exhaust Remover to be the best. The way I use it is simply spray it on, let it sit several seconds and wipe off with microfiber cloth. Repeat with clean cloth as needed. Leaves a clean shiny surface. How thick the residue is determines how long you let it work and repeat. I go through a lot of microfiber cloths! 1 Quote
Hank Posted November 7, 2019 Report Posted November 7, 2019 Aerocosmetics Wash n Wax! Regular (blue) for the plane, degreaser (red) for the belly, and plain, cheap terrycloth handtowels. 4 Quote
jetdriven Posted November 7, 2019 Report Posted November 7, 2019 Also PTI aircraft grease remover kills it. 1 Quote
quik flite Posted November 7, 2019 Report Posted November 7, 2019 WD-40 spray on rag wipe off. 1 Quote
LANCECASPER Posted November 7, 2019 Report Posted November 7, 2019 I've tried everything (Wash N Wax Red, Simple Green, Citrus Degreaser, Rejex, AeroShell Oil & Exhaust, etc,) and mineral spirits still works the best. 4 1 Quote
StevenL757 Posted November 7, 2019 Report Posted November 7, 2019 On 11/7/2019 at 12:03 PM, Hank said: Aerocosmetics Wash n Wax! Regular (blue) for the plane, degreaser (red) for the belly, and plain, cheap terrycloth handtowels. Expand +1 I do the same, but also use the Belly Soap (formerly Belly Wash) to remove the exhaust stains. I've found over the last several years, the Degreaser does a great job of degreasing, but not so well on the exhaust stains. Sidebar...I also use the pink stuff for the windows, but according to the Wash-Wax All folks, you can use the blue and pink stuff interchangeably...for the same applications. Go figure. Steve 1 Quote
jetdriven Posted November 7, 2019 Report Posted November 7, 2019 70-90% ispropyl alcohol is the only thing I’ve found to remove the grayish-brownish paint staining from exhaust. After you wash the belly there is a dull streak of that left over. 1 Quote
PT20J Posted November 7, 2019 Report Posted November 7, 2019 Ive had good success with Carbon-X. 1 Quote
takair Posted November 7, 2019 Report Posted November 7, 2019 LPS-2 works well on the belly. Adds corrosion assistance to the seems as well. Wipes off clean and leaves a shine. Simple green for aviation if I’m washing, but leaves a flatter finish. 1 Quote
RogueOne Posted November 7, 2019 Report Posted November 7, 2019 On 11/7/2019 at 11:47 AM, PTK said: I have found AeroShell Flight Jacket Oil & Exhaust Remover to be the best. The way I use it is simply spray it on, let it sit several seconds and wipe off with microfiber cloth. Repeat with clean cloth as needed. Leaves a clean shiny surface. How thick the residue is determines how long you let it work and repeat. I go through a lot of microfiber cloths! Expand Who sells this and at what cost? 1 Quote
Emmet Posted November 7, 2019 Report Posted November 7, 2019 Baby wipes They degrease pretty well, are cheap and come with their own cloths 1 Quote
jaylw314 Posted November 7, 2019 Report Posted November 7, 2019 On 11/7/2019 at 10:10 AM, FloridaMan said: What’s the easiest way to clean lead off the belly of a Mooney? Expand Wait, are you talking about oil and exhaust stains, or are you actually trying to mitigate lead? Quote
Greg Ellis Posted November 7, 2019 Report Posted November 7, 2019 On 11/7/2019 at 5:03 PM, RogueOne said: Who sells this and at what cost? Expand Aircraft Spruce has it for $9.85. 2 Quote
RLCarter Posted November 8, 2019 Report Posted November 8, 2019 XHAUST & SOOT REMOVER from spruce is what he uses 1 Quote
bgpilot1 Posted November 8, 2019 Report Posted November 8, 2019 By far, the best product I've used is Turtle Was Bug and Tar Remover. Only $5 a bottle and can be found at any car parts store near you. 2 Quote
jetdriven Posted November 8, 2019 Report Posted November 8, 2019 Here is the msds. It’s mineral spirits and light spirit. 1 Quote
flight2000 Posted November 9, 2019 Report Posted November 9, 2019 On 11/7/2019 at 10:10 AM, FloridaMan said: What’s the easiest way to clean lead off the belly of a Mooney? Expand Pay a local teenager $20 bucks and sit in a lawn chair supervising.... I at least give them the supplies and then turn them loose. Brian Quote
CaptRJM Posted November 9, 2019 Report Posted November 9, 2019 Lemon Pledge! I wipe it down every 25 hours or so. 3 cans for $10 at Sam's Club 2 Quote
PJClark Posted November 11, 2019 Report Posted November 11, 2019 I used this today on a tip from the YouTube detailer Aviana Aircraft Detailing. I diluted this approx 5 : 1, spray on, let sit for 3-5 min, wipe off with towel. Repeated in a couple spots. Then clean and polish with 1:20 mix ONR in a spray bottle. Worked like a champ, no smell no fumes no headache. Whole belly done in about 40 min. Pro tip...get or borrow a padded mechanic's creeper! Quote
Mooneymuscle56m Posted November 17, 2019 Report Posted November 17, 2019 409 bathroom cleaner, but rinse after. By far the best I’ve used and it’s cheap Quote
Dustin Kurath Posted November 18, 2019 Report Posted November 18, 2019 Personally I have found the best belly cleaner to be premium (no ethanol) mogas and a microfiber cloth. The gas cuts right through the oil and grease and the microfiber cloth does a great job holding on to it. I can usually do the whole belly with just one cloth. Quote
carusoam Posted November 18, 2019 Report Posted November 18, 2019 Welcome aboard, Dustin. Glad you could join us... We need more long body pilots. The Cs and Js have us outnumbered... Best regards, -a- Quote
rmininni Posted November 28, 2019 Report Posted November 28, 2019 To remove lead and soot, try Hoppes 9. This was developed to clean lead and soot from gun barrels. Simply wipe on, wipe off. Fastest belly cleaner on the planet. Have found no negative effects on the paint. You can get it at Walmart for a few bucks.Sent from my SM-G973U using Tapatalk 1 Quote
