thinwing Posted April 20, 2017 Report Posted April 20, 2017 On 4/18/2017 at 5:31 PM, peevee said: Guess I'm the odd man out. It has made no difference in how the GPS functions for me. I use none of the new features. How about full function of Bluetooth keyboard? 1
peevee Posted April 21, 2017 Report Posted April 21, 2017 On 4/20/2017 at 4:39 PM, thinwing said: How about full function of Bluetooth keyboard? Have the keyboard. Haven't used it. No need.
thinwing Posted April 22, 2017 Report Posted April 22, 2017 15 hours ago, peevee said: Have the keyboard. Haven't used it. No need. My wife and navigator loves it ,it was bouncy and we were getting lots of reroutes....we have the keyboard mounted in its 3D printed holder mounted on top of clearance book...like this : 3
Supercop0184 Posted May 29, 2017 Report Posted May 29, 2017 Maybe someone here like avisimpson can help. just had my dealer do the upgrade. Took it out to fly it today and noticed that all my Bluetooth, WIFI, and such are now off. Went to set up and they are no longer highlighted. Soooooo I called the avionics guy but I'm sure he's off today. Any ideas?
carusoam Posted May 29, 2017 Report Posted May 29, 2017 When referring to a whiteknight... Consider using their screen name like this. @AviSimpson This gives Simpson a small indicator light on his MS page... If he is reading MS, like the rest of us... he might get the message. Best regards, -a-
KLRDMD Posted May 29, 2017 Author Report Posted May 29, 2017 Just now, Supercop0184 said: just had my dealer do the upgrade. Took it out to fly it today and noticed that all my Bluetooth, WIFI, and such are now off. Went to set up and they are no longer highlighted. Soooooo I called the avionics guy but I'm sure he's off today. Any ideas? You need to call tech support. This is a known issue, most often seen if you didn't have the tail # input correctly in the setup page before the update. They'll send you a file to install that should make all OK but the'll need your serial number, etc.
FBCK Posted May 30, 2017 Report Posted May 30, 2017 I had the same thing happen, its likely you need another file to unlock those functions again, the unit did not recognize your tail number, and those functions as being paid for already.
LANCECASPER Posted May 30, 2017 Report Posted May 30, 2017 On 4/22/2017 at 9:36 AM, thinwing said: My wife and navigator loves it ,it was bouncy and we were getting lots of reroutes....we have the keyboard mounted in its 3D printed holder mounted on top of clearance book...like this : How would one get a 3D printed keyboard holder?
xcrmckenna Posted May 30, 2017 Report Posted May 30, 2017 My wife and navigator loves it ,it was bouncy and we were getting lots of reroutes....we have the keyboard mounted in its 3D printed holder mounted on top of clearance book...like this : Hey, I saw that this weekend....Sent from my iPhone using Tapatalk
Simpson Bennett Posted May 30, 2017 Report Posted May 30, 2017 14 hours ago, Supercop0184 said: Maybe someone here like avisimpson can help. just had my dealer do the upgrade. Took it out to fly it today and noticed that all my Bluetooth, WIFI, and such are now off. Went to set up and they are no longer highlighted. Soooooo I called the avionics guy but I'm sure he's off today. Any ideas? Like Ken said, call or email our Tech Support team (888-723-7592 or techsupp(at)avidyne.com). Let them know you need your WiFi and BT turned on, they will need your IFD serial number, tail number and email address to send you a .dsf file to correct the issue. 2
carusoam Posted May 30, 2017 Report Posted May 30, 2017 17 hour response time over a holiday weekend, including full technical detail and contacts for follow-up! Nice work, Simpson. Technical Customer service Guru. Best regards, -a-
Supercop0184 Posted May 30, 2017 Report Posted May 30, 2017 5 hours ago, AviSimpson said: Like Ken said, call or email our Tech Support team (888-723-7592 or techsupp(at)avidyne.com). Let them know you need your WiFi and BT turned on, they will need your IFD serial number, tail number and email address to send you a .dsf file to correct the issue. Thanks buddy!! I will. Am I gonna have to "convince them" that they were options I had turned on before or should it's be pretty seamless? Thanks for your help. Hate it when things don't go as planned!!
thinwing Posted May 30, 2017 Report Posted May 30, 2017 16 hours ago, LANCECASPER said: How would one get a 3D printed keyboard holder? I got mine from b2c2 aviation ..his email is beldridge.ca@gmail.com
Simpson Bennett Posted May 31, 2017 Report Posted May 31, 2017 18 hours ago, Supercop0184 said: Thanks buddy!! I will. Am I gonna have to "convince them" that they were options I had turned on before or should it's be pretty seamless? Thanks for your help. Hate it when things don't go as planned!! Nope, you do not need to convince them of anything, it should be pretty seamless.
tony Posted June 1, 2017 Report Posted June 1, 2017 The latest release of foreflight 9.1 and the avidyne 10.2 update should enable a 2 way connection according to the foreflight 9.1 release notes. Has anyone tried this and can they share how they got it to work? was it via Bluetooth? via wifi? need a stratus in between?
mccdeuce Posted June 1, 2017 Report Posted June 1, 2017 Seems to work - but still doesn't have ADSB in the outstream. Will try and set Stratus up as main hub tomorrow and see how it all works out.
Simpson Bennett Posted June 1, 2017 Report Posted June 1, 2017 11 hours ago, tony said: The latest release of foreflight 9.1 and the avidyne 10.2 update should enable a 2 way connection according to the foreflight 9.1 release notes. Has anyone tried this and can they share how they got it to work? was it via Bluetooth? via wifi? need a stratus in between? The connection is via WiFi and doesn't require a Stratus since the WiFi is coming from the IFDs.
Simpson Bennett Posted June 1, 2017 Report Posted June 1, 2017 10 hours ago, mccdeuce said: Seems to work - but still doesn't have ADSB in the outstream. Will try and set Stratus up as main hub tomorrow and see how it all works out. I believe 9.1 just supports the flight plan transferring. A subsequent release will hopefully take advantage of the ADS-B output for any customers with a SkyTrax hooked up to their IFD.
mccdeuce Posted June 1, 2017 Report Posted June 1, 2017 29 minutes ago, AviSimpson said: I believe 9.1 just supports the flight plan transferring. A subsequent release will hopefully take advantage of the ADS-B output for any customers with a SkyTrax hooked up to their IFD. So based on your response I would interpret that y'all have already implemented ADSB out in the data stream and that it is now up to Foreflght to implement its use.
tony Posted June 1, 2017 Report Posted June 1, 2017 8 hours ago, AviSimpson said: The connection is via WiFi and doesn't require a Stratus since the WiFi is coming from the IFDs. Doesn't require but is there a way to connect up all three? I really don't want to loose traffic and weather off of the iPad.
PeytonM Posted June 2, 2017 Report Posted June 2, 2017 Groundhog Day. I have wanted to configure the IFD440 wifi as described below and have it work as described since I installed the unit in April. I have talked/emailed Avidyne Tech Support. They are very responsive and try and help, but cannot. They've told me it's ForeFlight's issue, which by association, a Stratus issue I have weather and traffic from Stratus2 on my iPad, and want to take advantage of bidirectional flight plan sharing between the IFD and ForeFlight. I have failed up until ForeFlight 9.1. I don't know if ForeFlight 9.1 fixes this, but I have my doubts. Nowhere in the ForeFlight Pilot Guide for 9.1 does it speak to a Wifi config that would be needed for it to work with both Stratus and the IFD. See the instructions that I pulled from the IFD440 Installation Manual, below. I only wish it worked as described!!! Maybe someone can prove me wrong, now that ForeFlight 9.1 has been released. Maybe the real issues is the need for a firmware update for Stratus, so that it can accept the IFD as a client, but who's driving this?? AviSimpson, what say you?? (BTW, the subsequent screenshots in the Installation Manual that describe the process are wrong.) "7.5.14.1.2 Configuring the IFD as a Client to an External WAP In some cases, an aircraft may have an existing WAP in use. For example, some aircraft may be accustomed to connecting 3rd party iPad applications to a Stratus ADS-B receiver. These pilots will likely wish to also have access to the IFD from their iPads. In order to achieve this configuration, the IFD must be configured to connect to the Stratus receiver. This will allow tablet devices to access data from both the Stratus and the IFD simultaneously..." And the Installation Manual goes on to intruct you how to do this. But it hasn't worked for me...
mccdeuce Posted June 4, 2017 Report Posted June 4, 2017 Yesterday I set up the IFD in remote mode connecting the IFD to my stratus. iPad connects to stratus network but also sees the IFD and can transfer flight plans. Worked as advertised. @PeytonM if you have your iPad and stratus working right together leave them. Then go into configuration on the IFD set the Remote SSID to that of your Stratus. (Should be Stratus+serialnumber) finally change mode from local to remote. Once complete turn on everything give it a second and on settings/devices on ForeFlight you will now see both stratus and IFD. @AviSimpson it would be nice if there was a quick way to change between remote and local network modes without going into the setup. For example my Stratus dies in flight and I don't have to reset my IFD to swap the connection. 1
gsengle Posted June 4, 2017 Report Posted June 4, 2017 Ok I'm gonna (see I can speak American). Put my CIO networking hat on and see if I can help. From what I understand of network protocols I can't see how the iPad can connect to the stratus and the IFD at the same time as it can only have one wifi network connection as it only has one "network card". This is a limitation of the iPad. I would assume that the stratus has the same issue, i.e. You should be able to get it to connect to your ifd no problem at all, but to have both it won't allow as basically it doesn't know where to sends its data on its single channel wifi connection. So can you connect the ifd direct to the stratus? yes? Good you can get all your data onto the ifd can you then get the iPad to connect to the stratus? yes brilliant. No then that is because the IFD's wifi channel is occupied by the stratus. You could possibly try to in this instance connect the iPad to the ifd us By a different channel config in the wifi on the iPad. This is not a foreflight app level issue but a network protocol issue. No new release of foreflight etc will resolve this. Andrew Unless a Bluetooth connection can achieve the link for one of the devices, or one of the devices can effectively relay the info.Sent from my iPhone using Tapatalk
gsengle Posted June 4, 2017 Report Posted June 4, 2017 I did think about that, lets see what the tests i asked him to do prove, then we csn move from there. In all cases it simat os level not app level. Yes and no, the app would need some work too, as might the devices in question.... but yes it would be a workaround in a way for a hardware limitation. (putting on my CTO hat)Then again wifi was created for attaching to a network and all these little standalone wifi servers are a bit of a hack themselves...Sent from my iPhone using Tapatalk
gsxrpilot Posted June 4, 2017 Report Posted June 4, 2017 I don't know, it works as advertised for me as well. Simply turn on the Stratus and connect your iPad as usual. Set the IFD to remote mode to act as a client, and connect it the Stratus as well. Now you have a nice little wifi network in the cockpit with the Stratus as the hotspot. Everything can talk to everything else. As @mccdeuce says, you have to go into the Setup on the IFD to switch between the default "local mode" and "remote mode". 1
