201er Posted March 24 Report Posted March 24 As we all know, demonstrated cross wind component doesn't really mean anything. It is what the manufacturer happened to demonstrate but does not mean or imply a maximum. The real max-crosswind capability is where there is no more available rudder to make a side slip without drifting (or where the upwind wing runs out of ground clearance). What is that max? It is likely different between long, mid, and short bodies. And among short bodies there is probably a difference from when they expanded the rudder. Share your knowledge or experience of what that maximum is and specify the specific model it applies to. Quote
N201MKTurbo Posted March 24 Report Posted March 24 I haven’t flown in strong winds on a daily basis since I left Denver in ‘89. I seem to recall it is around 35 KTS where you run out of rudder. 1 Quote
Hank Posted March 24 Report Posted March 24 I've yet to find it. The highest i remember was at KRAP, gusting around 25-27 knots, 50° left of the runway. I took my IFR checkride at KCRW, using Runway 23; seems winds were on the order of 15G23, VAR 230-320. I passed . . . Quote
Fritz1 Posted March 24 Report Posted March 24 On a long body it is somewhere between 35 and 40 KT, landed at KIAD RWY 01 with 35 gusting 40 Kt from 270 about a year ago, runway is 150ft wide, lined up with one of the high speed taxiways, use full flaps, reduces the risk of a stall or tail strike in gusty conditions, started on the right side of the runway and traversed it to the left towards the high speed taxiway, nobody complained 2 Quote
Andy95W Posted March 24 Report Posted March 24 Depends on airspeed. More airspeed = more rudder authority. One of the reasons partial flaps helps. If you can keep your speed up sufficiently and fly it on to the runway, you’ll hit the wingtip before you run out of rudder. Misjudge and you’ll balloon viciously. Realistically, though, I agree with Rich. About 35 knots. 1 1 Quote
Paul Thomas Posted March 24 Report Posted March 24 I've seen these type of threads on multiple forums and while our Mooney do well in X-wind, I still don't like these threads. Some members misremember or exaggerate the numbers and mislead others about the capabilities of the airplane. Touching down is the easy part... slowing down and taxing in are the real challenge. The closest I've ever come to damaging an airplane was getting out of a C140 when a gust almost took the airplane into the hangar door. The bigger the number, the more questionable becomes the judgement if you damage the airplane. My suggestion is to use a number you're comfortable with or divert instead of going by someone's max number on the internet. 4 Quote
PT20J Posted March 24 Report Posted March 24 I once asked Bob Kromer (Mooney factory test pilot) why the demonstrated crosswind velocity was so low and he said that the older test pilots all cautioned to be conservative because not all pilots have the same level of proficiency and most don't often practice crosswind landings. He had a personal max crosswind number that he said he was comfortable with when he was flying Mooneys nearly daily. I don't recall the exact number but it was way less than 35 knots. Somewhere in the low 20s I think. 2 1 Quote
EricJ Posted March 24 Report Posted March 24 10 minutes ago, PT20J said: I once asked Bob Kromer (Mooney factory test pilot) why the demonstrated crosswind velocity was so low and he said that the older test pilots all cautioned to be conservative because not all pilots have the same level of proficiency and most don't often practice crosswind landings. He had a personal max crosswind number that he said he was comfortable with when he was flying Mooneys nearly daily. I don't recall the exact number but it was way less than 35 knots. Somewhere in the low 20s I think. I've always heard that the "demonstrated" number is just the highest crosswind observed during a particular portion of the certification testing, so it is just dependent on what crosswinds were present or available during testing during that phase. In other words, "we saw this value actually demonstrated", which is a useful data point, but also why it isn't a limitation. Quote
PT20J Posted March 25 Report Posted March 25 42 minutes ago, EricJ said: I've always heard that the "demonstrated" number is just the highest crosswind observed during a particular portion of the certification testing, so it is just dependent on what crosswinds were present or available during testing during that phase. In other words, "we saw this value actually demonstrated", which is a useful data point, but also why it isn't a limitation. Bob told me that at Mooney, the number was up to the flight test engineer. They flew a number of flights and then chose a conservative number that they felt the "average" pilot wouldn't get into trouble with. One of the issues with the Mooney is that the nose gear is rigidly connected to the rudder pedals so you have to release pressure and let the rudder center when the nosewheel touches down while simultaneously increasing aileron into the wind. 1 Quote
47U Posted March 25 Report Posted March 25 9 hours ago, 201er said: Share your knowledge or experience of what that maximum is and specify the specific model it applies to. Short body, short rudder. Last week I landed on RW17, 75’ wide. Wind was 240 degrees, 17kt G22. And it was gusty. I elected no flaps for the higher speed. It was sporty, but did not feel unsafe. Yeah, it skipped a couple times with the excess airspeed, but I road the upwind wheel for a bit and it settled down fine. Skip @PT20J is right, the nose needs to be centered when it touches down. I did pretty good, but it wasn’t perfect. 2 Quote
N201MKTurbo Posted March 25 Report Posted March 25 The question wasn’t what is smart or prudent. Everybody needs to figure that out for themselves. Back when strong crosswind landings were a daily occurrence, if I couldn’t track the runway with the rudder pinned to the floor, it was time to find a better runway. The OP asked a question. I answered it as best I could. Also, I never carried extra speed. I wanted that airplane to be done flying when the wheels touched down. As has been mentioned, if it takes extra speed to control the plane, you will lose control of it as you slow down. If you cannot track the runway, it is time to go around. 7 Quote
hazek Posted March 25 Report Posted March 25 2 hours ago, N201MKTurbo said: Also, I never carried extra speed. Everyone carries extra speed. Some foolishly add extra to the extra to be "safe". 1 Quote
aviatoreb Posted March 25 Report Posted March 25 Some are reporting the angle here, or implicitly doing so by reporting the wind direction and runway direction, but I want to remind just in case. I know a lot know but just in case, entertain this old math professor - 30kts at 60 degrees is a lot less than 30kts at 90 degrees. 30*sin(60)=25.98 which is a bit less than 30 if it were at 90 degrees and a lot more than 30 if it were at 45 degrees 30*sin(45)=21.21. So remember to pay attention to angle when considering. My personal absolute max is 20 degrees in the perpendicular component. So 30kts cross wind is ok if it's at 40 degrees. 30*sin(40)=19.28. 3 Quote
Hank Posted March 25 Report Posted March 25 10 minutes ago, aviatoreb said: 30kts at 60 degrees is a lot less than 30kts at 90 degrees. 30*sin(60)=25.98 which is a bit less than 30 if it were at 90 degrees and a lot more than 30 if it were at 45 degrees 30*sin(45)=21.21. So remember to pay attention to angle when considering. My personal absolute max is 20 degrees in the perpendicular component. So 30kts cross wind is ok if it's at 40 degrees. 30*sin(40)=19.28. Tru dat, and both my phone and tablet have a calculator, but I'm not looking down long enough to use it (maybe if it had buttons I could feel?). I read somewhere one time a little thing to approximate the crosswind component: 30° off runway heading = 1/2 windspeed 45° off runway heading = 2/3 windspeed 60° off runway heading = windspeed This is mental math that I can keep track of, and it's close enough to keep me safe. I rarely fly when winds are > 20 knots on the ground anyway, just lucky I guess. (And I've only been to Wyoming in my Mooney the one time ). 2 Quote
aviatoreb Posted March 25 Report Posted March 25 3 minutes ago, Hank said: Tru dat, and both my phone and tablet have a calculator, but I'm not looking down long enough to use it (maybe if it had buttons I could feel?). I read somewhere one time a little thing to approximate the crosswind component: 30° off runway heading = 1/2 windspeed 45° off runway heading = 2/3 windspeed 60° off runway heading = windspeed This is mental math that I can keep track of, and it's close enough to keep me safe. I rarely fly when winds are > 20 knots on the ground anyway, just lucky I guess. (And I've only been to Wyoming in my Mooney the one time ). Exactly - I dont actually compute with the trig functions to two decimal places of accuracy on an irrational number when I am flying. My main point is I sometimes get the feeling that some people speak of cross wind across the runway that is a fierce 30 knots and they land it but actually its 45 degrees off perpendicular so they didnt really land a 30 knot cross wind and then they tell themselves it was fine and then another time it really is 30 degrees 90 degrees off and they are expecting it to be the same relying on mistaken math. 2 Quote
201er Posted March 25 Author Report Posted March 25 (edited) 4 hours ago, aviatoreb said: I dont actually compute with the trig functions to two decimal places of accuracy on an irrational number when I am flying. I’m disappointed, I expected at least to one decimal point from you. Show your work next time. Edited March 25 by 201er 1 Quote
Hank Posted March 25 Report Posted March 25 37 minutes ago, 201er said: I’d disappointed, I expected at least to one decimal point from you. Show your work next time. Be careful, Mikey. He might post the next million digits of pi . . . . . 1 Quote
exM20K Posted March 25 Report Posted March 25 I’m in “Fly the Approach and Find Out” camp. I think the kids call this FAFO. The runway itself is also a decision factor. 2500x30 vs 5000x100. Big difference in the time available to execute a graceful touchdown. And, don’t forget: the anenometer may well be mounted at the FAA’S preferred 10 meter height, not the 2ish meter altitude where the flare begins. And the ATIS is, on average, 30 mins old. -dan 1 Quote
midlifeflyer Posted March 25 Report Posted March 25 8 minutes ago, exM20K said: I’m in “Fly the Approach and Find Out” camp. I think the kids call this FAFO. LOL! I was doing a night currency flight in a Cessna 152. Winds were howling from the west for runway 17. As I turned base to final I saw there was no way I was going to be able to land that time around. ATC: Cleared to land runway 17. Me: I don't think so. Quote
A64Pilot Posted March 26 Report Posted March 26 (edited) Crosswind capability depends on gross weight, speed, power applied and even on which side the wind is coming from, obviously if your carrying power as surely most all of us are in a cross wind landing then you need a little right rudder and that cuts into what’s available, wind from the left does just the opposite. Additionally most every aircraft I’ve been around has a range of allowable rudder travel, if yours is at the min then you have less rudder authority than one that’s at the max So we end up in most of GA aircraft rather conservative cross wind numbers, there are some exceptions to this of course, Gulfstream killed a couple of test pilots and crew with a rather ridiculously difficult short field takeoff procedure because they wanted to advertise that the G650 could get into and out of very short fields, so they had no “fudge” at all. https://www.ntsb.gov/investigations/AccidentReports/Reports/AAR1202.pdf Long and short of this is that crosswind capability is very variable, oh and I forgot grass runways too, grass is much more forgiving if you don’t touch down perfectly straight so cross wind landings are easier on grass, so add that to the list. Edited March 26 by A64Pilot 1 Quote
Brandt Posted April 1 Report Posted April 1 On 3/24/2025 at 2:19 PM, Fritz1 said: On a long body it is somewhere between 35 and 40 KT, landed at KIAD RWY 01 with 35 gusting 40 Kt from 270 about a year ago, runway is 150ft wide, lined up with one of the high speed taxiways, use full flaps, reduces the risk of a stall or tail strike in gusty conditions, started on the right side of the runway and traversed it to the left towards the high speed taxiway, nobody complained I would be deeply concerned about using full flaps in this situation, not only from the impact on airflow over the tail in the slip, but also because of the impact of a gust on landing. I’d use T/O flaps and add a gust factor to the landing speed. 1 Quote
midlifeflyer Posted April 1 Report Posted April 1 1 hour ago, Brandt said: I would be deeply concerned about using full flaps in this situation, not only from the impact on airflow over the tail in the slip, but also because of the impact of a gust on landing. I’d use T/O flaps and add a gust factor to the landing speed. I'd be deeply concerned with a 35-40 KT crosswind regardless of flap setting Not a Mooney. Cessna 152. Not much heavier than an light sport and with a Vref of about 60 KIAS ±5, very little momentum. Demonstrated crosswind component of 12 KTS. I was working on my CFI. We had planned a ground session for that day because the winds were howling directly across the runway. I don't recall the specifics, but well above the 12. My instructor asked, "if we went up today, how would you land?" "I would never use flaps on a day like this," was my reply, something I learned as a student pilot. "Let's go up and do some full-flap landings," was the response. We did. That was the day I mentioned earlier - when I stopped reducing flaps for a crosswind. 4 Quote
dkkim73 Posted April 1 Report Posted April 1 38 minutes ago, midlifeflyer said: Not a Mooney. Cessna 152. 40kts is probably closer to Vne, right? So you could land perpendicular... I keed, I keed! Love the 152. Seriously, though, with that set up did you slant your course across the runway? To @Brandt's point, I would worry a bit about full flaps on a longbody esp at fwd CG loadings due to tail authority. I've felt the tailplane bobble before and it's weird. OTOH most of my crossing landings to date, even with a lot of rudder, have been full flap... So just thinking of extreme cases with gusts in particular. PP thoughts only, not even as good at cross wind landings as I seem to remember being... 1 Quote
Brandt Posted April 1 Report Posted April 1 24 minutes ago, dkkim73 said: 40kts is probably closer to Vne, right? So you could land perpendicular... I keed, I keed! Love the 152. Seriously, though, with that set up did you slant your course across the runway? To @Brandt's point, I would worry a bit about full flaps on a longbody esp at fwd CG loadings due to tail authority. I've felt the tailplane bobble before and it's weird. OTOH most of my crossing landings to date, even with a lot of rudder, have been full flap... So just thinking of extreme cases with gusts in particular. PP thoughts only, not even as good at cross wind landings as I seem to remember being... I’m just impressed at you working in a Triumph reference… Quote
Yetti Posted April 1 Report Posted April 1 1 hour ago, midlifeflyer said: I'd be deeply concerned with a 35-40 KT crosswind regardless of flap setting Not a Mooney. Cessna 152. Not much heavier than an light sport and with a Vref of about 60 KIAS ±5, very little momentum. Demonstrated crosswind component of 12 KTS. I was working on my CFI. We had planned a ground session for that day because the winds were howling directly across the runway. I don't recall the specifics, but well above the 12. My instructor asked, "if we went up today, how would you land?" "I would never use flaps on a day like this," was my reply, something I learned as a student pilot. "Let's go up and do some full-flap landings," was the response. We did. That was the day I mentioned earlier - when I stopped reducing flaps for a crosswind. Not sure about a C150 but the flaps on a Mooney have less surface area than a C172 does. They are also way closer to the ground. When the flaps get close to the ground they are pushing air down into the runway. This adds to the float. half flaps lets some of that air escape out the back. I am pretty much half flaps all the time for landing in the F model. Quote
