M20 Ogler Posted November 29, 2024 Report Posted November 29, 2024 I have Shower of sparks ignition. I can hear the vibrator buzzing when the ignition key is turned to “start”. Then I press the key in to engage the starter. But the engine won’t fire. Sometimes it gets started after I release the key. My battery drains after two or three attempts at cranking for 10 to 15 seconds so then I have to put back on the charger for a few hours. Maybe my battery is toast? Any quick and easy things I can check before I call the shop? Wires that may be loose or maybe I can spray electrical contact cleaner in the vibrator box? Thx Quote
Hank Posted November 29, 2024 Report Posted November 29, 2024 The engine starting when you release the key is a signal of a failing left magneto. During engine start, the right mag is grounded, as only the left mag has a set of retarded points used at startup; letting go of the key activates the right magneto and the engine may start then. My left mag died in the air, and after landing neither love nor money would make it start again; not even my enhanced vocabulary made it run. 3 1 1 Quote
MooneyMitch Posted November 29, 2024 Report Posted November 29, 2024 In addition to Hank’s information, a faulty ignition switch could be applying a ground on the left magneto P lead wire during the starting phase. Or possibly a bare wire point along the left magneto P lead wire path from the ignition switch to the left magneto could be picking up a ground too. 1 Quote
47U Posted November 29, 2024 Report Posted November 29, 2024 ‘Oh Lord, stuck in Lodi again…’ When the engine starts after releasing the key (and the right mag fires, as Hank describes), have you done a mag check? Does the left mag make spark then? I’m guessing hearing the shower of sparks buzzing means that box is probably working, but an inspection of the wiring between the shower of sparks and the left mag (as MooneyMitch suggests) might reveal an issue. Which side of the firewall is your shower of sparks. Do you have a 201 windscreen? 1 Quote
M20 Ogler Posted November 29, 2024 Author Report Posted November 29, 2024 Yes I do a mag check before takeoff and they both work or else I would not fly. I have the original windscreen. Quote
47U Posted November 29, 2024 Report Posted November 29, 2024 On 11/29/2024 at 4:23 PM, M20 Ogler said: I have the original windscreen. Expand I’m guessing the SoS box is on the cockpit side of the firewall. Pull the top cowl and inspect the wiring from the left mag back to the firewall. If there’s a bad wire, it’s probably on the engine side. The P-lead wire is probably shielded (unless it’s been replaced with shielded wire under the insulation). If that looks ok, then pull the avionics access and inspect that wiring from the SoS box to the firewall. If still no smoking gun, depending on your level of mx ability, remove a plug lead from a plug on the left mag and install a plug in it. Ground the plug to the engine and have someone energize the SoS. DON’T ENGAGE THE STARTER! And, don’t get shocked. I removed my SoS years ago, and never had to troubleshoot it, so I don’t remember if it buzzes that means for certain it’s making spark. There’s an SoS troubleshooting guide, probably in the downloads section. I still have my SoS box, in case you need one. 1 Quote
Fritz1 Posted November 29, 2024 Report Posted November 29, 2024 check as stated by 47U, if SOS dead think about a slick start booster, 3-4 times the bang of SOS, I had a dead SOS on my G-model once upon a time, replaced slick start, fired within one blade cold or hot Quote
Jim Peace Posted November 29, 2024 Report Posted November 29, 2024 curious when the mag inspection was done last? Quote
M20 Ogler Posted November 29, 2024 Author Report Posted November 29, 2024 (edited) On 11/29/2024 at 5:22 PM, Jim Peace said: curious when the mag inspection was done last? Expand I think they where replaced around 250 hours ago Edited November 29, 2024 by M20 Ogler Quote
MooneyMitch Posted November 29, 2024 Report Posted November 29, 2024 We are all really trying to get you started....... With my thoughts on grounded P lead during starting................... 1. render your engine from being able to start [disconnect battery lead at starter is one way]. 2. disconnect P lead from left mag. 3. with volt meter, set meter to DC voltage. 4. attach black meter lead to disconnected P lead. 5. attach red meter wire to 12V DC . 6. turn on Master switch and verify meter registers 12V [this means your P lead is correctly grounded as it should be in this configuration] 7. activate starter switch to START and voltage should disappear. [P lead should no longer show as grounded] 8. this method will verify that your P lead wire/starter switch grounding feature is correct. [no foreign grounding from switch or frayed wire] Quote
N201MKTurbo Posted November 29, 2024 Report Posted November 29, 2024 Pull the point cover off the retard mag, check the wires for chafing and make sure the points are opening. You can do all this without removing the mags. I had this happen once, the wire to the retard breaker was touching the inside surface of the point cover and had warn through the insulation and the wire was shorted to the cover. Quote
MooneyMitch Posted November 29, 2024 Report Posted November 29, 2024 On 11/29/2024 at 5:22 PM, Fritz1 said: check as stated by 47U, if SOS dead think about a slick start booster, 3-4 times the bang of SOS, I had a dead SOS on my G-model once upon a time, replaced slick start, fired within one blade cold or hot Expand Drifting away from trying to help this gentleman get his C started, here's an interesting story regarding the Slick Start Booster on my Mooney [previously installed by others]. I installed mags on my D/C model after 500 hour inspection. Engine would not start until I'd release the START motion [limped into starting] Checked and re-checked all installation over and over and over, thinking I'd done something incorrectly........ wiring, timing, etc. All appeared correct........hmmm! I discovered in start position, there remained a left mag P lead grounding with the P lead disconnected from the mag...............WHAT?? Eventually, hours later, I discovered that during the Slick unit installation/modification, certain wires are to be removed from the ignition switch. One wire had not been removed from the switch during the modification. That wire had been left in the aircraft wiring bundle and coincidentally began picking up a ground which was grounding the left mag P lead during the start procedure ! I disconnected the wire from the switch, taped it up and all was well again. 1 Quote
M20 Ogler Posted December 1, 2024 Author Report Posted December 1, 2024 Went to trouble shoot today and the plane started up and shut down multiple times no problem. Like it just rolled out the factory yesterday. Can’t find any obvious shorts or open circuit. The wires and harnesses all look nearly new. Idk how to troubleshoot an intermittent problem. 1 Quote
Ragsf15e Posted December 1, 2024 Report Posted December 1, 2024 On 12/1/2024 at 7:54 PM, M20 Ogler said: Went to trouble shoot today and the plane started up and shut down multiple times no problem. Like it just rolled out the factory yesterday. Can’t find any obvious shorts or open circuit. The wires and harnesses all look nearly new. Idk how to troubleshoot an intermittent problem. Expand Those are the worst! Quote
MikeOH Posted December 1, 2024 Report Posted December 1, 2024 On 12/1/2024 at 7:54 PM, M20 Ogler said: Idk how to troubleshoot an intermittent problem. Expand Don't feel bad...I'm a career EE and I don't know how to troubleshoot an intermittent problem, either! 3 Quote
takair Posted December 2, 2024 Report Posted December 2, 2024 On 11/29/2024 at 3:42 PM, M20 Ogler said: I have Shower of sparks ignition. I can hear the vibrator buzzing when the ignition key is turned to “start”. Then I press the key in to engage the starter. But the engine won’t fire. Sometimes it gets started after I release the key. My battery drains after two or three attempts at cranking for 10 to 15 seconds so then I have to put back on the charger for a few hours. Maybe my battery is toast? Any quick and easy things I can check before I call the shop? Wires that may be loose or maybe I can spray electrical contact cleaner in the vibrator box? Thx Expand I had this issue a few years ago. As I recall, I just needed to clean/sand/file the contacts in the shower of sparks. Ideally you replace them, but think they were not available. You will probably find them pitted from arcing. 1 Quote
Pinecone Posted December 2, 2024 Report Posted December 2, 2024 On 12/1/2024 at 9:58 PM, MikeOH said: Don't feel bad...I'm a career EE and I don't know how to troubleshoot an intermittent problem, either! Expand It's easy. It just requires more time than you have. And increase in your vocabulary of swear words. Some skin off of various parts of your body. And, if you have hair, ripping some out. And that might not even be enough. 2 Quote
MooneyMitch Posted December 2, 2024 Report Posted December 2, 2024 Yep, intermittent is the worst for sure. Spent many years at our west coast missile launch facility and running across an intermittent was frustrating.........until it raised its head and you could finally cut it off!!! Patience and persistence..............it will reappear. Something is grounding that left mag.............. Quote
47U Posted December 3, 2024 Report Posted December 3, 2024 On 12/2/2024 at 7:22 PM, MooneyMitch said: Yep, intermittent is the worst for sure. Spent many years at our west coast missile launch facility and running across an intermittent was frustrating... Expand We had a sensor with an intermittent issue. Ring’d perfectly on the ground. Finally, found a cannon plug (100+ pins) on a pressure bulkhead with one pin that was reversed, the crimp end was on the female side and the female end was crimped. Pressurizing the bulkhead in flight created enough flex that the connection was intermittent. A Lockmart tech rep found it. Those guys were mostly ancient (compared to the blue suiters) but they knew their shit. 1 1 Quote
cliffy Posted December 3, 2024 Report Posted December 3, 2024 Age and treachery beat youth and looks any day of the week! :-) 1 Quote
Fly Boomer Posted December 3, 2024 Report Posted December 3, 2024 On 12/3/2024 at 2:23 PM, cliffy said: Age and treachery beat youth and looks any day of the week! :-) Expand I always warn the frisky youngsters that I cheat at every opportunity. Quote
Pinecone Posted December 3, 2024 Report Posted December 3, 2024 Old fighter pilot saying: If you ain't cheatin', you ain't tryin'. Quote
phxcobraz Posted December 4, 2024 Report Posted December 4, 2024 I had almost the exact same issue earlier this year(see thread I posted). I was having intermittent trouble starting until one day it wouldn’t start at all. Checked continuity to all wiring to/from the ignition, shower of sparks, and the left mag. All checked out great, however my left mag was approaching overhaul/IRAN 500hr and in checking it we found the retard breaker not working. I figured the $500+ for the mag service was better put toward a new mag so I put on a Surefly electronic mag and it starts fantastic and so easy now. 1 1 Quote
MooneyMitch Posted December 4, 2024 Report Posted December 4, 2024 On 12/4/2024 at 2:42 AM, phxcobraz said: I had almost the exact same issue earlier this year(see thread I posted). I was having intermittent trouble starting until one day it wouldn’t start at all. Checked continuity to all wiring to/from the ignition, shower of sparks, and the left mag. All checked out great, however my left mag was approaching overhaul/IRAN 500hr and in checking it we found the retard breaker not working. I figured the $500+ for the mag service was better put toward a new mag so I put on a Surefly electronic mag and it starts fantastic and so easy now. Expand I like that issue explanation. Quote
M20 Ogler Posted January 25 Author Report Posted January 25 (edited) My A&P and I tested my shower of sparks and it works fine. He says it looks like a welding arc coming from the spark plugs in all four cylinders. I replaced the Gill battery with the Concorde RG-35axc and it cranks wayyyyyy better now. But still won’t start easily. So I’m guessing I have a fuel or compression issue maybe. Edited January 25 by M20 Ogler 1 Quote
