Recently got a leak which seemed huge, after washing down engine it apparently was a valve cover gasket which I tightened but it didn’t help. Any pointers on replacing the gaskets engine TSIO 550 G
Thanks Dan
Thanks Dan
Buy the Real Gasket brand - they are better and a lot less expensive.
https://realgaskets.com/product-category/aviation/aviation-opposed/continental/page/2/
https://www.aircraftspruce.com/catalog/eppages/siliconecalvecover_08-01319.php
Don't over tighten the rocker cover screws, and make sure you use new star lock washers to keep them doing their job. I wouldn't suggest going against The guidance of not using loctite. Did I mention I never had a screw come loose that had loctite on it?
What setting on the air hammer do you recommend?
  • Haha 3
Sure seems that way.
Many are over torqued.
26in lbs on silicone.
50in lbs on cork.
-Matt
Thanks Dan
Hello,
Here's a brief guide to replacing the valve cover gasket on a TSIO-550-G engine:
  1. Safety First:
    • Disconnect the battery.
    • Ensure the engine is cool before starting.
  2. Remove Components:
    • Remove any components obstructing access to the valve cover (air filter, hoses, etc.).
  3. Remove Valve Cover:
    • Unscrew the bolts holding the valve cover in place.
    • Carefully remove the valve cover to avoid damaging the gasket surface.
  4. Clean Surfaces:
    • Clean the valve cover and the engine surface where the gasket sits, removing old gasket material and oil residue.
  5. Install New Gasket:
    • Place the new gasket onto the valve cover or the engine, ensuring it is properly aligned.
  6. Reinstall Valve Cover:
    • Position the valve cover back onto the engine.
    • Tighten the bolts in a crisscross pattern to the manufacturer’s torque specifications
I hope this will help you,
Thank you
Any ideas of why it would still leak?
Tried 5 gaskets, both standard and silicone.  Sanded the rocker cover to make sure the mating surface is flat.  Swapped covers.  Chased threads to make sure the bolt was going in fully.
Still leaks.
2 hours ago, Ali said:
Hello,
  1. Safety First:
  4. Clean Surfaces:
Thank you
Thanks Ali I basically did as you suggested, after installing I ran it up retorqued per instructions ran it up no leak, let it cool overnight checked torque ran it etc.  No leak yet, waiting for Biden to leave then fly and recheck.
D
Still leaks.
T, I’m sure you did but make sure covers are flat and not bent even a tiny bit, now my leak covered an immense amount of area. I used realgasket if it didn’t work Id try Guys or cork, good luck, I guess your ready to play with the new rocking panel
D
A&P sanded the cover flat.  Then swapped the cover with another one on the engine and the leak stayed on the same cylinder.
Current gasket is a Guy's
Long shot, but any chance there's a hairline crack on the mating surface of the casting?  Clean and examine with an eye lupe?
That is what I am afraid of.  :(
I think they are just super duper fussy for some reason....hardly a real answer.
Mine leak sometimes, using the real gasket brand, following the instructions, etc.  Sometimes they leak and sometimes they don't.  The ones that leak, I just tighten up the screws a bit and revisit, if that doesn't work, remove and clean them.  Sometimes it works, sometimes it doesn't.  I haven't found any rhyme or reason.  Mine have been trouble free the last year or so but this posting will probably cause them to start leaking again.
  • 1 month later...
No fiberglass, prone to sponge
faa/ pma allows leaks
I had to replace a Lycoming valve cover that had a pinhole leak so I went ahead and replaced all the gaskets with yours and they work great.
