ELT Posted January 12, 2013 Report Posted January 12, 2013 Hi, I need education on tire tubes. Last week I noted the left main tire on my E was low. When I tried to air it the stem partiallyseparated from the tube. A local mechanic put on a "straight valve stem tube". I did not know there were different tubes. Which is correct? thanks for any information Eddie
Alan Fox Posted January 12, 2013 Report Posted January 12, 2013 Since I doubt you could even do a parts # cross reference on an inner tube , I would venture to say both are correct.....The bent style stem just makes it easier to fill.....
N201MKTurbo Posted January 12, 2013 Report Posted January 12, 2013 I use the straight ones, I think thay are more robust.
scottfromiowa Posted January 12, 2013 Report Posted January 12, 2013 I use the straight ones, I think thay are more robust. Why?
stevesm20b Posted January 12, 2013 Report Posted January 12, 2013 I had the same problem. The straight stem broke when trying to fill with air. I replaced my tires and tubes and bought the 90 degree stems. Don't have to bend the stems to put air in or check pressure any more.
N201MKTurbo Posted January 12, 2013 Report Posted January 12, 2013 Well, the straight ones are moulded to the tube and come straight out of the wheel. Any pressure put on them while airing them up is straight down. The ones with the angled stem are metal fittings clamped to the tube and every time you put pressure on them while filling you put some side load on the tube. Nothing to get excited about one way or the other. If somebody gave me an angled stem tube for free I would have no problem using it.
1964-M20E Posted January 13, 2013 Report Posted January 13, 2013 I've had two tubes with stright stems fail within monhs of each other on my former palne. We repalced the tire and tubes again with the striaght stem tubes. I'm thinking of trying the anlged stem on my next tire repalcement.
jetdriven Posted January 14, 2013 Report Posted January 14, 2013 Which one works with wheel covers? We are needing some new tires and we might add the wheel covers.
N201MKTurbo Posted January 14, 2013 Report Posted January 14, 2013 Any tube that fails in a few months was probably installed wrong.
1964-M20E Posted January 14, 2013 Report Posted January 14, 2013 Which one works with wheel covers? We are needing some new tires and we might add the wheel covers. From what I understand only the straight stems work with the wheel covers.
1964-M20E Posted January 14, 2013 Report Posted January 14, 2013 Any tube that fails in a few months was probably installed wrong. The stems failed on the tires and tubes that were installed before I bought the plane and I flew the plane close to 100hrs per year for two years before they failed. They just failed close to each other. The good thing they fialed at my home airport so the flat tire was noticed in the preflgiht.
episode180 Posted January 16, 2013 Report Posted January 16, 2013 I recently installed new tires and tubes on my '62 M20C and found the straight stems that Spruce sent me are just long enough to require bending them over drastically to fill and get the cap on and off. I think the bent stem would work better in my circumstance. Bending the straight molded stem will eventually take its toll, as it ages. The threaded on bent stem on the other hand has its drawbacks as well if you get to forceful with the air chuck. As always, failure will come at the least opportune time, so just be gentle.
N201MKTurbo Posted January 16, 2013 Report Posted January 16, 2013 This may all be true, I've never had wheel covers. I used my plane for commuting, taking wheel covers off to air the tires would drastically increase my travel time. Just taking the plane out of the hanger was over 10% of the trip time.
N201MKTurbo Posted January 16, 2013 Report Posted January 16, 2013 Up until the last two years, my Mooneys have always been a work horse. Back in the 80s For 4 years straight I put over 450 hours a year on it. It never failed to start and take me where I needed to go. Most of the time it was a little ugly from grease, oil and dirt, but very reliable. Jim R you must have magic tubes, I've always had to air up the tires at least once a month. Maybe I should clean the schrader valves before I put them back in?
jetdriven Posted January 16, 2013 Report Posted January 16, 2013 is the stem straight, and hidden behind the wheel cover, or is the stem bent 90 degrees and comes through a hole in the wheel cover?
carusoam Posted January 16, 2013 Report Posted January 16, 2013 I think the key word is "butyl" rubber. It is the new compound that retains air better. Does that ring a bell? I used to fill the M20C tires monthly. The R tires a lot less, probably, seasonally... Best regards, -a-
DonMuncy Posted January 16, 2013 Report Posted January 16, 2013 No need to remove wheel covers to check pressure or add air.
FlySafe Posted September 27, 2022 Report Posted September 27, 2022 Hi All, I have a pilot report on valve stems. Recently had a slow leak on my 5x5, 6 ply nose tire on a M20C. It has a wheel cover and has had bent tubes installed in the past. Tube removed was an aero classic leakguard (GL-5076B) with a 90 degree bent stem. I was replacing with a Michelin airstop (097-908-0, TR67-A) also a bent stem. Funny thing was when all back together, the valve stem with its cap sticks out too far and prevents the wheel cover from being reinstalled. I was able to remove the vale stem cap and get the cover back on as a temporary solution until I can get a replacement aero classic tube (knowing it will fit). Must be some small difference in the Michelin stem design. oh well, more owner basic maintenance tire change practice. 1
ArtVandelay Posted September 27, 2022 Report Posted September 27, 2022 Interesting adaptation to your jack, is that a commercially available, I see a label on it. 1
carusoam Posted September 28, 2022 Report Posted September 28, 2022 @FlySafe see request above… Jack question… Nice pirep regarding bent stem issue… thanks for sharing it… Best regards, -a- 1
Pasturepilot Posted September 28, 2022 Report Posted September 28, 2022 10 hours ago, ArtVandelay said: Interesting adaptation to your jack, is that a commercially available, I see a label on it. The label is from Bogert Aviation. They make all kinds of fun stuff. https://bogertaviation.com/collections/bottle-jack-extensions-ram-adapters 1
Pinecone Posted September 28, 2022 Report Posted September 28, 2022 Hmmm, what parts would be needed to jack the wing for work on a main?
Fly Boomer Posted September 28, 2022 Report Posted September 28, 2022 41 minutes ago, Pinecone said: Hmmm, what parts would be needed to jack the wing for work on a main? 2
FlySafe Posted September 28, 2022 Report Posted September 28, 2022 yes @Pasturepilot has the ID spot on. its very handy, can use on any standard bottle jack for tire changes on main or nose; I have only used for lifting of 1 wheel at a time for wheel maintenance tasks and found stability as being very good and very quick setup. Just watch winds and make sure clam/mild if working on a ramp and have the other wheels chocked. Be safe. k
