My friend had the nose wheel tire on his K model go flat this evening upon landing. Fortunately he was able to make it off the runway so the airport did not have to be closed down. I asked him if it caused a prop strike. He said no and that is because (and here is my question) to be certified a plane has to have 9 inches of proper clearance even if the nose wheel is flat and the strut is completely compressed”. Well I actually did not measure it but I don’t think I have 9 inches of prop clearance in my J model even when everything is in perfect condition. Any truth to this certification requirement? And as a follow-up question, what type of suspension system does the nose wheel on a J model or a K model have? Is it a piston or rubber donuts or some thing else?
49 minutes ago, Glen Davis said:
what type of suspension system does the nose wheel on a J model or a K model have? Is it a piston or rubber donuts or something else.
All M20’s have rubber donuts.
10 hours ago, PT20J said:
Here’s the reference in CAR 3
So out of curiosity...  Is the 9" clearance on a tail wheel aircraft while the tail wheel is touching the ground?  (e.g. parked or slow taxi)  Or while in the takeoff roll when the tail is elevated.  And if it is 9" when the TW is down, does it then have a 7" clearance on the takeoff roll?  (Some day I gotta get around to that endorsement...)
Level takeoff or taxi, whichever is most critical. I don’t believe 7 inches plays into anything on a conventional gear airplane.
Just read it again…slowly :)
Glenn,
The nose gear is tall enough to protect the engine from a prop strike under most conditions….
For all Mooneys…
But, with a missing tire… the blades will be closer to the ground than usual….
Where Mooneys have had prop strikes…. Holes in the ground.  Pot holes in the pavement, or washed out soil taxiing off the pavement….
The hole required to cause a prop strike just got a few inches smaller, as the tire deflates….
MS experiences only, not mine…
Thanks, all.  I thing it's a good idea to measure the distance from the tip on the prop to the ground to see if the donuts in the nosegear are up to snuff.
11 minutes ago, Fly Boomer said:
I read 7 inches with air in the tire and "positive clearance" when flat.
And the critical gear (nose wheel here of course) fully compressed
But we have all heard or seen prop strikes on level hard surface runways, without flats, so it can be done.
Our rubber pucks don't compress much. Unless you hit the runway with a whopping descent rate . . . .
7 hours ago, OR75 said:
Anyone still have the shock absorber on the nose wheel ?
Hard to find on any MSer planes…
Many reasons to remove…
No reasons to keep…
All documented around here somewhere…
No reasons to keep…
What would be the reasons to remove ?
apart from a few lbs saving
I still have it installed
Have you SEEN some of my landings?? :lol:
There are times when I’d like to have one, specifically sometimes I get into bumps that get the nose pogoing up and down, not dangerous, but annoying. Slow down quickly and it stops, I’m talking walking speed not fast taxi.
A shock would dampen this resonant movement
It was my understanding that "shock absorber" is actually a shimmy damper.  If you look at the picture the rubber disks are still there.
This thing is technically the shimmy damper….
A bolt on device for a problem we don’t have…
Proper set-up of the nose gear keeps the shimmy out…
If it doesn’t, there are wear items that get replaced…
Taking the parts off is a maintenance procedure…
The savings… must be a whole LB UL.   :)
The device is soooo old.  It probably doesn’t provide any shimmy absorption… like a 50 year old shock absorber…
PP thoughts only…
3 minutes ago, OR75 said:
maybe remove it and see if there is  a difference . put it back if if i don't like how it feels
I did that first part with a spouse once who refused to fly with me....there was a difference, in a good way
Shock absorbers are not typically for travel limit, but they an do wo.
They are to dampen motion.  So that the nose does not continue to bounce up and down after hitting a bump.
