milotron Posted December 2, 2019 Report Posted December 2, 2019 Hi, I was going to replace my windshield in January and AME felt I would need the trim piece below it replaced as it would not come out intact. I suppose this can only come from the factory or is there a risk-free way to remove this without destroying it? I don't want to get into a position with the plane apart and a key part now becoming impossible to acquire. I know this can always occur, but would hate to do it intentional with this elective surgery. Thanks, Quote
Marauder Posted December 2, 2019 Report Posted December 2, 2019 On 12/2/2019 at 8:38 PM, milotron said: Hi, I was going to replace my windshield in January and AME felt I would need the trim piece below it replaced as it would not come out intact. I suppose this can only come from the factory or is there a risk-free way to remove this without destroying it? I don't want to get into a position with the plane apart and a key part now becoming impossible to acquire. I know this can always occur, but would hate to do it intentional with this elective surgery. Thanks, Expand Which piece are you talking about? When you said "below" are you speaking about the piece forward of the glareshield? Or the piece at the top of the windshield? Quote
flyer338 Posted December 2, 2019 Report Posted December 2, 2019 You might contact Lasar at Lakport, Ca. I assume you are talking about the trim piece at the bottom of the windshield on the outside. They sell the windshield kit to retrofit the 201 windshield to legacy models and the kit includes this part. Quote
BaldEagle Posted December 2, 2019 Report Posted December 2, 2019 I’m getting my windshield replaced next week. From what I understand the trim piece needs to be removed carefully and with much patience and it can (should) be reused. Touch up paint required though. Quote
jetdriven Posted December 2, 2019 Report Posted December 2, 2019 Yes it can be removed. Drill carefully with a #30 drill. But inspect it first. If it’s been replaced before and it is installed with cherrymax rivets you are going to have to destroy it to remove it. Quote
ArtVandelay Posted December 2, 2019 Report Posted December 2, 2019 On 12/2/2019 at 10:24 PM, jetdriven said: If it’s been replaced before and it is installed with cherrymax rivets you are going to have to destroy it to remove it. Not true, my AP just did mine, I guess it depends on how careful they are.Tom Quote
milotron Posted December 3, 2019 Author Report Posted December 3, 2019 Thanks for the responses. Yes, the exterior trim piece below and forward of the windshield. The logs don't show it as being replaced and it looks original to 1981. What does a Cherry max rivet look like installed? Quote
carusoam Posted December 3, 2019 Report Posted December 3, 2019 While waiting for a real answer... Expect the cherry max to look like a two part rivet... where a steel pin is at the center... Drilling out the steel pin makes it challenging... http://www.cherryaerospace.com/product/cherrymax They get used because... They can be put in place where normal rivets don’t have enough room for the tools... PP thoughts only, trying to describe something I’m not really familiar with... Best regards, -a- Quote
EricJ Posted December 3, 2019 Report Posted December 3, 2019 On 12/3/2019 at 3:07 AM, milotron said: What does a Cherry max rivet look like installed? Expand It's a pop rivet with a hard metal locking collar in the head that holds the stem. So the head will have a stem in the middle that should be discernible even under paint...probably. The round-head ones are not too tough to remove, but the flush ones are quite a bit harder to get out. It can be done, though...probably. http://www.cherryaerospace.com/product/video/rivetremoval 1 Quote
Guest Posted December 3, 2019 Report Posted December 3, 2019 I’ve done this on many different airplanes. Once the rivets are removed, buy small diameter guitar steel string, and some dowel. drill holes in 2 pieces of dowel to make handles leaving about 2’ of wire between, work the trailing edge of the fairing up until you can slip the wire in. Have a helper hold the fairing up while the wire is pulled through the sealant with a sawing action. Work carefully the part many not be readily available. Clarence Quote
milotron Posted December 3, 2019 Author Report Posted December 3, 2019 That is an excellent tip Clarence! I will pass this on the my AME. He his willing to do this work, but hasn't done a Mooney in a while ( and doesn't particularly like it from what I gather ) Quote
jetdriven Posted December 3, 2019 Report Posted December 3, 2019 On 12/2/2019 at 11:13 PM, ArtVandelay said: Not true, my AP just did mine, I guess it depends on how careful they are. Tom Expand Were they universal head or flush? Ive never been able to remove more than two or three flush head Cherrymax rivets without it turning to crap. The drill walks off the steel stem and you end up destroying the top piece of metal to get the rivet removed. Universal head are easy, grind the head off 1 Quote
ArtVandelay Posted December 3, 2019 Report Posted December 3, 2019 On 12/3/2019 at 2:56 PM, jetdriven said: Were they universal head or flush? Ive never been able to remove more than two or three flush head Cherrymax rivets without it turning to crap. The drill walks off the steel stem and you end up destroying the top piece of metal to get the rivet removed. Universal head are easy, grind the head off I believe universal, because we discussed this, he said he could grind them off, the steel pin was plainly visible. I’m no rivet expert.BTW, they were able to use regular rivets on the top by removing the glare shield and could get behind it when they replaced it.Tom 1 Quote
jetdriven Posted December 3, 2019 Report Posted December 3, 2019 Factory install is a flush rivet. those are cleaner looking but much harder to remove. Im not sure how well a universal head rivet is held into a dimpled hole. But anyways, im pretty sure you will wreck the retainer strip removing flush Cherrymax rivets. 1 Quote
flyer338 Posted December 4, 2019 Report Posted December 4, 2019 The part that came with the kit was composite. But hey, the factory is back up! Quote
thinwing Posted December 5, 2019 Report Posted December 5, 2019 If you can get your hands on a high speed dental drill like an old Midwest ,connect it to your air compressor and run it at 60 psi.Standard carbide 557 drills will go thru the center of a flush rivet cherry max like butter with no walk.Figure on 5 min per rivet...eBay it... 1 Quote
