INA201 Posted November 28, 2019 Report Posted November 28, 2019 Just pulled up the closest two currently available for sale off of Trade a Plane. More apples to apples. https://www.trade-a-plane.com/search?category_level1=Single+Engine+Piston&make=MOONEY&model=M20J+201&listing_id=2370722&s-type=aircraft https://www.trade-a-plane.com/search?category_level1=Single+Engine+Piston&make=CIRRUS&model=SR20&listing_id=2364350&s-type=aircraft 1
201er Posted November 28, 2019 Report Posted November 28, 2019 Given that the Mooney is 17 years older for only slightly less money seems to imply it is still a more highly valued airplane when you get into apples to apples.
67 m20F chump Posted November 28, 2019 Report Posted November 28, 2019 One of them is a plastic clown plane. 2 2
MikeOH Posted November 28, 2019 Report Posted November 28, 2019 (edited) 8 minutes ago, 67 m20F chump said: One of them is a plastic clown plane. And the other is a chump's? Edited November 28, 2019 by MikeOH
Tim Jodice Posted November 28, 2019 Report Posted November 28, 2019 Assuming that the cirrus has been done on time in the past, it will need a chute repack next year. They don't say anything about ADSB or that the 430s are WAAS. That would certainly drop the price. The Mooney having both WAAS and ADSB would certainly make it more desirable. 1
Gagarin Posted November 28, 2019 Report Posted November 28, 2019 The Cirrus fix gear simplify significantly annuals and maintenance since no jacks are required. A composite plane is free of corrosion. Although I feel more comfortable in a Mooney in the vicinity of lightning.
gsengle Posted November 28, 2019 Report Posted November 28, 2019 The Cirrus fix gear simplify significantly annuals and maintenance since no jacks are required. A composite plane is free of corrosion. Although I feel more comfortable in a Mooney in the vicinity of lightning. And yet I’ve seen more than one shop where the fixed price annual is the same Mooney vs Cirrus. And I’ve seen many insurance quotes where the Cirrus cost more per dollar hull than the Mooney. So go figure.Sent from my iPhone using Tapatalk 2
Bob_Belville Posted November 28, 2019 Report Posted November 28, 2019 At @AGL Aviationa fixed priced annual for a M20C-J includes 5 more hours than a SR20 and a M20K gets 2 more hours than an SR22.
1964-M20E Posted November 28, 2019 Report Posted November 28, 2019 You still need a Jack to do wheel bearings 2
Bob_Belville Posted November 28, 2019 Report Posted November 28, 2019 5 minutes ago, 1964-M20E said: You still need a Jack to do wheel bearings I suppose it takes 5 minutes +/- to jack up my M20E. Less than that to "un-jack".
INA201 Posted November 28, 2019 Author Report Posted November 28, 2019 This article sums up the Cirrus pretty thoroughly. https://philip.greenspun.com/flying/cirrus-sr20 1. Mooney Cruises a little faster 2. Mooney is more efficient 3. Repairs are easier and less expensive on the Mooney. 4. Chute repack may be comparable to tanks leaking in the Mooney 5. Insurance? 6. Maintenance costs? 7. Useful load is better in the Mooney 5. The Continental will require a top before a Lycosaur and a more expensive overhaul cost. 6. Cirrus has the chute 7. Cirrus is a little roomier and ergonomic on the inside. 8. Mooney gear retracts, looks better when flying 9. Longevity of the airframe is proven for decades in the Mooney 10. The Mooney is depreciated out the Cirrus may still drop some in value 12. Factory support? 13. It is a tough competitor but who's to say that the Cirrus doesn't have a ton of squawks while the Mooney is clean. It is hard to make a real accurate comparison by an ad alone. We need more data
moontownMooney Posted November 28, 2019 Report Posted November 28, 2019 Lots of good points already made. My two cents... If we are just comparing the models genericly, I think the biggest difference to me is the ~150lb useful load advantage of the Mooney (if internet sources of such are to be trusted). Climb rate of the Mooney appears to be a bit sportier as well (25-50%).Sent from my LM-V405 using Tapatalk 1
KB4 Posted November 29, 2019 Report Posted November 29, 2019 32 minutes ago, INA201 said: 13. It is a tough competitor but who's to say that the Cirrus doesn't have a ton of squawks while the Mooney is clean. It is hard to make a real accurate comparison by an ad alone. We need more data By 83' Mooney had things somewhat figured out after 81' modifications to J. This 2000 Cirrus is very early model. SB's, may loom. 15K to repack.
Guest Posted November 29, 2019 Report Posted November 29, 2019 1 hour ago, 1964-M20E said: You still need a Jack to do wheel bearings And to check nose steering friction. Clarence
eman1200 Posted November 29, 2019 Report Posted November 29, 2019 clearly it’s whichever one has a pilot relief tube. 3
Guest Posted November 29, 2019 Report Posted November 29, 2019 To be more fair I think the comparison should be Aircraft of the same or similar power. M20 C and G against a Piper Comanche 180 and Piper Arrow 180, Cessna 172RG, M20 E, F and J against Beech Sierra, Cessna 177RG, Rockwell Commander 112, M20K against Piper turbo Arrow 4, maybe Comanche 260 turbo, M20S against earlier Beech Bonanza, Comanche 250/260, M20R against Beech 35/36, Cirrus SR22 Cessna 210, Piper Lance/ Saratoga, M20TN against Cirrus SR22T, Cessna T210, Beech 36TC. Each airframe in the grouping has different strong and weak points, each one is a trade off in some feature. The Mooneys likely beat them all in overall fuel efficiency. Clarence
DXB Posted November 29, 2019 Report Posted November 29, 2019 A 2000 SR20 Cirrus is objectively a good airplane with various strengths and weaknesses relative to the M20J model. But let's be honest - I doubt any of us, including owners of the pre J models, would enjoy flying the Cirrus nearly as much, or even want to be seen in one . The control feel in the Mooney is just in another league.
jetdriven Posted November 29, 2019 Report Posted November 29, 2019 4 hours ago, Gagarin said: The Cirrus fix gear simplify significantly annuals and maintenance since no jacks are required. A composite plane is free of corrosion. Although I feel more comfortable in a Mooney in the vicinity of lightning. Jacks certainly are required. You still have to inspect/service the wheel bearings and brakes. lightning is perhaps a distant 4th or 5th in the list of hazards of thunderstorms. The Cirrus has a certified system of mesh to conduct lightning. Not a concern.
jetdriven Posted November 29, 2019 Report Posted November 29, 2019 11 minutes ago, DXB said: A 2000 SR20 Cirrus is objectively a good airplane with various strengths and weaknesses relative to the M20J model. But let's be honest - I doubt any of us, including owners of the pre J models, would enjoy flying the Cirrus nearly as much, or even want to be seen in one . The control feel in the Mooney is just in another league. Until they fly a Beechcraft. A Mooney flies like a F250 diesel with worn tie rods compared to, say, a V35B. Truly a fingertip airplane. 2 1
DXB Posted November 29, 2019 Report Posted November 29, 2019 12 hours ago, jetdriven said: Until they fly a Beechcraft. A Mooney flies like a F250 diesel with worn tie rods compared to, say, a V35B. Truly a fingertip airplane. This is a vast exaggeration , though admittedly Bonanzas do seem to have an edge on control feel in my very brief experience. But with essentially all my time in a Mooney, the V36 Bo seating position felt a little odd - more like sitting at a kitchen table than in a cockpit. But Bonanza and Mooney owners should no longer be divided by such issues and instead stay focused on denigrating Cirrus . 2 4
Mooney in Oz Posted November 29, 2019 Report Posted November 29, 2019 12 hours ago, INA201 said: 5. The Continental will require a top before a Lycosaur and a more expensive overhaul cost. Isn't the SR-20 powered by a Lyc I0-360?
tmo Posted November 29, 2019 Report Posted November 29, 2019 (edited) 46 minutes ago, Mooney in Oz said: Isn't the SR-20 powered by a Lyc I0-360? It is a Continental IO-360, NA. The newer ones have a Lycoming IO-390. The -22 is Continental [TS]IO-550. Edited November 29, 2019 by tmo 1
Browncbr1 Posted November 29, 2019 Report Posted November 29, 2019 I think comparisons should be made dollar for dollar... for what that chute costs to maintain, you could throw in a second engine. For as much money as these two planes are listed, that could get you a totally pimped out upgraded twin Comanche. 1
flyer338 Posted December 1, 2019 Report Posted December 1, 2019 There is a big difference in the control feel of the ‘65 C model I used to own and the ‘83 J I just bought. The C was much more nimble feeling. As to buying a pimped out twin, buying gas for or two engines does not pencil out for me, no matter how cheap to buy. I understand Comanches have gear motor issues that make the Mooney back spring issues seem like a blessing. I do not know if they apply to Twin Comanches.
Guest Posted December 1, 2019 Report Posted December 1, 2019 9 hours ago, flyer338 said: There is a big difference in the control feel of the ‘65 C model I used to own and the ‘83 J I just bought. The C was much more nimble feeling. As to buying a pimped out twin, buying gas for or two engines does not pencil out for me, no matter how cheap to buy. I understand Comanches have gear motor issues that make the Mooney back spring issues seem like a blessing. I do not know if they apply to Twin Comanches. You may be misinformed regarding Comanche gear transmissions. They come in 2 models, Dura and Dukes, the Dura is the weaker of the designs. The forward bearing is known to come loose, but can be bonded with any number of Loctite products. Dukes is the preferred model but is more rare. Both single and twin Comanche use the same transmission. Matt Kurke of Comanche Gear in Florida machines new housing from stronger materials and copies the Dukes bearing retainer. Both designs are superior to the Mooney system, in the event of a failure in a Comanche you disconnect the transmission from the mechanical system and lower the gear. If the spring or gears fail in a Mooney transmission, there is no way to disconnect the transmission and lower the landing gear and a gear up landing will result. Clarence
