Marauder Posted December 17, 2018 Report Posted December 17, 2018 Could be either way. He might have heard that takeoff minimums don't apply to Part 91 and figured 0/0 landings were ok too. After all, this is the same guy who insisted in some early videos that 91.126 (the pattern direction rule) was only a recommendation. Or flying below 500 feet near houses surrounding the Bay was okay as well.Sent from my iPad using Tapatalk Pro 2
Marcopolo Posted December 17, 2018 Report Posted December 17, 2018 I was invited to sit in on an Instrument ground school class recently (got my IR last December) and there was a pretty heated discussion that took place concerning ILS and LPV approaches. The discussion centered around the alternate minimums and what approaches can be used. As I understand it, If the expected minimums are expected to be 600-2, or anything lower than 800-2, then there would have to be an ILS at the alternate as its the only approach recognized as a "precision" approach. What say you? Ron
Bob - S50 Posted December 17, 2018 Report Posted December 17, 2018 From my memory, if you have a WAAS GPS you can plan on RNAV approaches at both locations. However, minimums weather at the alternate must be based on the minimums for a non-precision (LNAV) approach, so 800 & 2. However, if you actually divert to your alternate and the LPV is available you may fly the approach to LPV minimums. If you have a non-WAAS GPS, you may only plan on a GPS based approach at either your destination or your alternate but not both. If your alternate has an ILS you may use minimums based on that approach. Personally, I want a lot better weather than that. I've flown hundreds of approaches including a CAT II ILS to minimums at DTW in an airplane without autoland and a CAT I approach to 100' based on having the lights in sight at 200' at GRB. I understand that this was just an academic situation, but there is no place I need to get so badly that I'm quibbling about the 200' difference in required weather between a precision/non-precision approach at my alternate or adjusting my takeoff time by 15 or 30 minutes so the forecast will finally be good enough. My personal minimums are 200 & 1/2 above minimums at my destination and essentially VFR at my alternate. 1
xcrmckenna Posted December 17, 2018 Report Posted December 17, 2018 1 hour ago, Marcopolo said: I was invited to sit in on an Instrument ground school class recently (got my IR last December) and there was a pretty heated discussion that took place concerning ILS and LPV approaches. The discussion centered around the alternate minimums and what approaches can be used. As I understand it, If the expected minimums are expected to be 600-2, or anything lower than 800-2, then there would have to be an ILS at the alternate as its the only approach recognized as a "precision" approach. What say you? Ron ILS and PAR are available for the 600/2 minimums but LPV’s still require the 800/2. On the written test if they choose 600/2 for the LPV question it will be wrong. Sent from my iPhone using Tapatalk
Marcopolo Posted December 17, 2018 Report Posted December 17, 2018 21 minutes ago, xcrmckenna said: ILS and PAR are available for the 600/2 minimums but LPV’s still require the 800/2. On the written test if they choose 600/2 for the LPV question it will be wrong. Agreed, I should/could have included the rare PAR approach and also GBAS, and MLS and a couple of others as options for precision approaches. Thanks 1
midlifeflyer Posted December 17, 2018 Report Posted December 17, 2018 1 hour ago, Marcopolo said: I was invited to sit in on an Instrument ground school class recently (got my IR last December) and there was a pretty heated discussion that took place concerning ILS and LPV approaches. The discussion centered around the alternate minimums and what approaches can be used. As I understand it, If the expected minimums are expected to be 600-2, or anything lower than 800-2, then there would have to be an ILS at the alternate as its the only approach recognized as a "precision" approach. What say you? Ron That's true. The alternate minimums for a GPS approach are the nonprecision alternate minimums, 800/2. For the purpose of alternate minimums, only an ILS is a "precision approach." But I don't say so. The FAA does (actually ICAO does). It's in TERPS Section 3-4, and the FAA's Instrument Procedures Handbook for example. From the IPH: "For flight planning purposes, weather information must be reviewed in order to determine the necessity and suitability of alternate airports. For Part 91 operations, the 600-2 and 800-2 rule applies to airports with precision and non-precision approaches, respectively. Approaches with vertical guidance (APV) are non-precision approaches because they do not meet the International Civil Aviation Organization (ICAO) Annex 10 standards for a precision approach." 2
midlifeflyer Posted December 17, 2018 Report Posted December 17, 2018 Answer to one of the sub-threads. Yes, LPV takes you down to the runway. Tested this afternoon using a Garmin 530. Glidepath alive and centered on touchdown. 6
carusoam Posted December 18, 2018 Report Posted December 18, 2018 Great pirep / follow-up / follow through, Mark! Best regards, -a-
midlifeflyer Posted December 18, 2018 Report Posted December 18, 2018 3 hours ago, carusoam said: Great pirep / follow-up / follow through, Mark! Best regards, -a- I was pretty sure it did, but was made curious by the question. Still always learning. 1
Marauder Posted December 24, 2018 Report Posted December 24, 2018 He’s back. Shooting a night LPV approach and forgets to turn on the runway lights. https://youtu.be/lD6NPNsC39ESent from my iPad using Tapatalk Pro
ilovecornfields Posted December 24, 2018 Author Report Posted December 24, 2018 “Good Job!” Reminds me of this: https://en.m.wikipedia.org/wiki/Folie_à_deux 6 hours ago, Marauder said: He’s back. Shooting a night LPV approach and forgets to turn on the runway lights.https://youtu.be/lD6NPNsC39E Sent from my iPad using Tapatalk Pro 1 1
kpaul Posted December 24, 2018 Report Posted December 24, 2018 6 hours ago, Marauder said: He’s back. Shooting a night LPV approach and forgets to turn on the runway lights.https://youtu.be/lD6NPNsC39E Sent from my iPad using Tapatalk Pro All the more reason to fly behind a G100 w/ synthetic vision...interesting that he gets a lot of kudos from followers, so positive feedback for stupid decision making. I've had a couple of similar experiences. Just recently flying the LPV into my home field at night through the weather, I broke out at about 500 AGL only to find out the lights had not turned on even though I had keyed the mic. The other time we were training on NVGs (not in a Mooney) and did a touch and go or two before we realized the airfield lights were not on. It was a full moon night and under the NVGs the runway was easily seen, still not strictly legal though. 2
Bryan Posted December 24, 2018 Report Posted December 24, 2018 Is the ILS an alternate precision approach because the system is ground monitored and can be verified? vs. LPV
M016576 Posted December 24, 2018 Report Posted December 24, 2018 2 hours ago, kpaul said: All the more reason to fly behind a G100 w/ synthetic vision...interesting that he gets a lot of kudos from followers, so positive feedback for stupid decision making. I've had a couple of similar experiences. Just recently flying the LPV into my home field at night through the weather, I broke out at about 500 AGL only to find out the lights had not turned on even though I had keyed the mic. The other time we were training on NVGs (not in a Mooney) and did a touch and go or two before we realized the airfield lights were not on. It was a full moon night and under the NVGs the runway was easily seen, still not strictly legal though. Tanking and/or landing on NVG's... can get dicey really quickly
jackn Posted December 24, 2018 Report Posted December 24, 2018 13 hours ago, Marauder said: He’s back. Shooting a night LPV approach and forgets to turn on the runway lights.https://youtu.be/lD6NPNsC39E Sent from my iPad using Tapatalk Pro “The one thing I did wrong, was to not turn on the runway lights” 1
kpaul Posted December 24, 2018 Report Posted December 24, 2018 5 hours ago, M016576 said: Tanking and/or landing on NVG's... can get dicey really quickly When I was younger I loved NVG operations, I am not as excited about it anymore. I had my fill of landing blacked out on "runways". NVGs are great for being able to clear at night and would defiantly come in handy if one happened to need to land off airport at night. 1
midlifeflyer Posted December 25, 2018 Report Posted December 25, 2018 On 12/13/2018 at 9:54 AM, flyboy0681 said: I guess you snooze you lose. The video was removed before I could view it. Someone downloaded the approach to (below?) minimums video before it was removed and re-posted it on Vimeo. 1
flyboy0681 Posted December 25, 2018 Report Posted December 25, 2018 1 hour ago, midlifeflyer said: Someone downloaded the approach to (below?) minimums video before it was removed and re-posted it on Vimeo. First time I've seen this. This guy has a lot of cojones. Did the tower think that he found a hole in the fog at 200 feet or did they just not want to bother reporting him?
midlifeflyer Posted December 25, 2018 Report Posted December 25, 2018 8 minutes ago, flyboy0681 said: First time I've seen this. This guy has a lot of cojones. Did the tower think that he found a hole in the fog at 200 feet or did they just not want to bother reporting him? What would they report? Part 91, he's allowed to take a look and is not bound by reported RVR. He landed safely and didn't cause a problem (ATC isn't interested in extra paperwork). And, as he did in response to comments when the video was originally up, he would insist he had the required approach lights in sight at DA, the rest of the runway environment in sight 100' lower, and 1/2 mile flight visibility from DA on. The only thing to "prove" him wrong is a video taken with an action cam with a limited-capability lens in low light conditions. 1
flyboy0681 Posted December 25, 2018 Report Posted December 25, 2018 30 minutes ago, midlifeflyer said: What would they report? Part 91, he's allowed to take a look and is not bound by reported RVR. He landed safely and didn't cause a problem (ATC isn't interested in extra paperwork). And, as he did in response to comments when the video was originally up, he would insist he had the required approach lights in sight at DA, the rest of the runway environment in sight 100' lower, and 1/2 mile flight visibility from DA on. The only thing to "prove" him wrong is a video taken with an action cam with a limited-capability lens in low light conditions. So why have a DA at all for Part 91?
gsxrpilot Posted December 25, 2018 Report Posted December 25, 2018 Just now, flyboy0681 said: So why have a DA at all for Part 91? There are rules that must be followed. All we're saying is that there isn't any way to prove he violated the rules. Rules still set a standard that most everyone will follow. And truthfully, he might have been within the rules on this approach. None of us were in the cockpit to know. 2
flyboy0681 Posted December 25, 2018 Report Posted December 25, 2018 3 minutes ago, gsxrpilot said: There are rules that must be followed. All we're saying is that there isn't any way to prove he violated the rules. Rules still set a standard that most everyone will follow. And truthfully, he might have been within the rules on this approach. None of us were in the cockpit to know. So what I'm hearing is that flagrantly busting the minimums is an unenforceable action since the pilot could always claim that he had all of the required elements in sight.
M20F Posted December 25, 2018 Report Posted December 25, 2018 One thing being left out of the discussion is ILS stands for instrument landing system. It has specific requirements for lights, runway markings, etc. not just a radio beam. An LPV does not have the same requirements. When you do an ILS you know exactly what you will get when you swivel your head up and out the window. With an LPV each approach can be very differing. LPV 10 / ILS 10 it’s 6 to 1, half a dozen to another. ILS 10R versus LPV 10L odds are I pick the ILS because I like lots of lights and markings. In most cases LPV’s lacking specific lights/marks will have higher minimums as well though not in all cases.
