I thought I would give a shout out to Eric and Mountain High for their EZ II Cannula.  Is anyone else using one?  I wanted something more comfortable.  The boom attaches to your head set and easily swings out of the way when not in use.  There is no binding like the ones that fit around your head and draw up tight.  $185 for the whole set up including the flow meter however I just ordered a quick disconnect so I can bundle up the tubing when not in use.
Russ
Nice idea, but for me the head clamp is more annoying than a light weight cannula. That contraption won't attach to my Halo's. I do plan to get the Mountain High Pulse Demand system.
You'll love it. We left home with 1500psi on a 74cu ft tank and flew to Cali, or, ut, and back and used like 500psi for 2 people.
Seems too bulky and too much effort compared to just using a Halo headset which doesn't interfere with hat, canula, or glasses!
5 hours ago, teejayevans said:
Nice idea, but I have a problem paying $185 for what looks like $2 in plastic tubing. I use what came with my system, if I used it more I'd probably go with a mask.
Like everything in aviation mh kind of rips people off. Their o2 masks are just a respirator they have changed a couple of the plugs on and charged 250 bucks for about 45 bucks in parts. It's frustrating but unless you have a source for the parts what can you do?
Here you go:
http://www.directhomemedical.com/oa-plus-3100-8-oxyarm-nasal-cannula.html
I have this system and love it. Yes it is too expensive. I actually bought the medical version posted above but then got the MH version anyway. The medical version lacks the screw friction lock. Anyway this is much more comfortable than our old cannula. Every flight for us is a oxygen flight. 12.5/13.5 k for our short flights and 16.5/17.5 for our longer flights. The O2D2 paired with the arm makes 02 usage a non event.
The arm canula is $100 each stand-alone.
I used the medical version for a few years and loved it.  Still have a few for passengers.  But then I got the mh version - and I prefer it for the screw lock mechanism . And very comfortable.  I used halo headset and after about a year I went back to my bose a20 which I decided I prefer.  So mh with the o2d2 is a fantastic setup.
but I don't have a big silly fuzzy fur hat.  Or a shako.  So Bose works for me and mh oxyarm.
  • 5 years later...
Russ
the photo is no longer showing up
I have the MH 02D2 and use it both with the boom and regular cannula. I love the system. If I wanted to save nickels I would not have got into flying.
