As a newbie Mooney owner, I'm a bit anxious about all kinds of things.  And at the risk of being told to go study the POH, I'm gonna ask the question anyway.
My oil pressure gauge indicates in the yellow/high yellow on take off.  As soon as I dial the power back to 25/25 it settles back into the green.  I'm showing 6 qt's on the stick and it's nice and clean.  The engine runs really smooth and seems to make plenty of power.  I'm in Texas and so the temps are pretty mild.
Should I be concerned?  Or is this normal for an O360?
Thanks,
Paul
What's the oil temp?
What pressure is the yellow zone on your aircraft?
I this normal to be in the yellow I'm not sure but an engine will produce more oil pressure at higher RPMs and colder oil temps.  Conversely lower RPMs and higher oil temperatures will produce lower oil pressure.
Oil temp does play a role in what the oil pressure will be. I also think the actual measurement can be off. If you look at the attached photo, my oil pressure reading on the JPI 830 shows 73 psi. The factory gauge looks to be over 80.
Posted Image
Sent using Tapatalk
I completely agree with Marauder. First flight of the day oil pressures are usually higher than later ones, since oil at 180 deg. Is much less viscous than at 120.
And the old gauges are horribly inaccurate. My engine was overhauled by a very reputable shop that dyno- tested everything and set the oil pressure based on calibrated test equipment. In the airplane, oil pressure is in the yellow on takeoff and high-green arc in cruise, although it does drop some as oil temperature rises.
Makes you wish you had Marauder's engine monitor, doesn't it? I sure do...
Marauder you just wanted to let everyone see your very cool panel. pressure on my envy meter went way up.
Too funny! There are a few of us here who could help spend your money and help alleviate the envy meter. :)
Pretty normal, Paul ... #8 above is good advice, too.  There are ways to mitigate the reading being quite so high on start, but it isn't an issue as long as you're reading proper pressure at cruise and above the lower redline while idling warm.
Enjoy your bird!
I think the most important thing is to set base line indications for your aircraft. Pressure typically rises with load and rpm and it takes a bit of time for the temps to get fully warmed up internal parts expand at different rates. What is normal for your engine
I set my oil pressure so it is at the bottom of the green arc after the oil is warm. I have found if you set it any higher you just increase the leak rate.
How does it leak more with higher oil pressure?
Well, I don't know for sure, but we all know that if you fill the lycoming to 8 quarts it will blow one out pretty quickly. With the oil pressure cranked way up this happens a bit faster.
Ours has about 90-95 PSI on the stock gauge but the dyno sheet from Lycoming shows 83 PSI. It does have a lot of oil on the belly but that's not a leak per se. So I'd buy that it may push some extra oil out the breather but that offset by increased oil flow to the valves. Oil that migrates past the lifters in the bore runs down the pushrod tubes to the valves. Higher oil pressure is more oil past the lifter.
  • 2 weeks later...
You mean you burn more oil because the higher pressure pushes it past valve guides ect??
My oil pressure was doing the same thing. Not initially but about a year after I bought the airplane. It would redline on the high side on takeoff. Even in warmer temps nearing zero ;) And this was after the oil was at normal temp.
My mechanic suggested changing the pressure relief valve to a newer adjustable style and the problem was solved. We tweaked it after a few flights to get it running in the mid greens during cruise at 75%.
PK
Also, be aware that it's common practice for maintenance/overhaul shops to set older Lycoming engines oil pressure to "new production" specs, which are significantly higher. Lycomings have traditionally had issues with sticking valves. One way the factory chose to reduce this issue is with the higher oil flow to the rockers/valves, via higher oil pressure.
Posted Image
Sent using Tapatalk
Really cool panel!
If I recall, there is no upward oil pressure limit on takeoff for lycomings.
115psi on TO on most of the later Lycomings!
Older ones were lower...
-Matt
I really would like to get the second aspen. But I am concerned about the lack of comparability between ASPEN and Garmin. I am now playing with the idea to replace the 430 with a 650 to complement the 750  Any ideas?
Im missing something here, where would it be leaking under pressure?
I misspoke, it doesn't leak more, it consumes more. I don't know why. I could guess, but that is all it would be. I don't have any data, but I have jacked around with oil pressure a few times and every time the consumption was better at lower oil pressure.
  • 3 weeks later...
What are the reasons for high oil pressure all the time ? Seems to me like a good thing to have VS low oil pressure. Thanks. Troy
