bnicolette Posted August 15, 2013 Report Posted August 15, 2013 Does anybody have a set of headset hangers either mfg'd or homemade installed in their Mooney? I hang my Halo's on the hand mic on the pilot side but the other headsets really get in the way during passenger loading and unloading. Just think it would be nice to have a set of hangers that keep them up and out of the way. Ideas's?
201er Posted August 15, 2013 Report Posted August 15, 2013 Well there's always the factory original headset hangers installed: But others have come up with alternate creative options: Some food for thought. And if all else fails, just have em fly on the wing. Saves time on getting in and out. 2
bnicolette Posted August 15, 2013 Author Report Posted August 15, 2013 Nope Mike I was thinking of something on the ceiling like the Cirrus has.
Marauder Posted August 15, 2013 Report Posted August 15, 2013 Have a nice flight today Brett? As for the headset hangers, nope. Most of the time I either drape them over the yoke or on the headrests.
Bob_Belville Posted August 15, 2013 Report Posted August 15, 2013 Legitimate question. I recently had to re-solder one of the wires on a Telex ANC after a passenger, she shall be nameless, got tangled in the cord getting out.
carusoam Posted August 15, 2013 Report Posted August 15, 2013 Mine live on the head rests... Best regards, -a-
Bennett Posted August 15, 2013 Report Posted August 15, 2013 Great idea- using the headrest. I will start doing that for the pilot's side. I currently leave the headset on the glare shield, but I worry about scratching the inside of the windshield. The co-pilot side is the problem because, as we all know, it is too easy to get our feet caught in the wires sliding into the pilots seat. The ideal solution, I think, would be a wi -fi or Bluetooth co-pilot side headset I'm not ready to trust wi-fi or Bluetooth for the pilot. About a year ago I saw an ad for a wireless ANR headset, but I didn't see them at Oshkosh this year. As I recall it had some sort of clunky box that hung down from the headphone jacks, and looked as though it still might be in the way in our Mooneys. 1
thinwing Posted August 15, 2013 Report Posted August 15, 2013 I made headset hangers consisting of 1x4 7071 aluminum strips with a 1/4 hole drilled at one end.Than cover bare aluminum with self stick fuzzy velcrow...bend a slight curve upwards in strip and loosen and remove screw holding visers...the strip is mounted under viser pivot and is free to rotate...headsets are know hanging from visor above glareshield and are safe and out of way....patent applied for,,,,this works awesome if I say so myself..k 1
bnicolette Posted August 15, 2013 Author Report Posted August 15, 2013 I made headset hangers consisting of 1x4 7071 aluminum strips with a 1/4 hole drilled at one end.Than cover bare aluminum with self stick fuzzy velcrow...bend a slight curve upwards in strip and loosen and remove screw holding visers...the strip is mounted under viser pivot and is free to rotate...headsets are know hanging from visor above glareshield and are safe and out of way....patent applied for,,,,this works awesome if I say so myself..k That's awesome and was precisely the solution I was looking for. Can you post a picture?
NotarPilot Posted August 15, 2013 Report Posted August 15, 2013 I made some myself and the trick was keeping the metal from bending due to the weight of the headsets. I screwed the hanger into the ceiling using an existing screw that holds the headliner in place. I'll take a picture later today at my hangar and post it later. I'm very happy how it came out. 1
NotarPilot Posted August 16, 2013 Report Posted August 16, 2013 http://mooneyspace.com/gallery/image/34497-image-6/ http://mooneyspace.com/gallery/image/34498-/ I made these last year and used heat shrink around the metal to cover the sharp edges.
bnicolette Posted August 16, 2013 Author Report Posted August 16, 2013 I really like that setup! Thank you for posting the pictures. I'll have to check out my ceiling and see where something like that might work for the front and rear.
aviatoreb Posted August 17, 2013 Report Posted August 17, 2013 I made these last year and used heat shrink around the metal to cover the sharp edges. Is that a safety hazard for hitting your head if there is ever a crash or even severe turbulence?
tomn Posted August 17, 2013 Report Posted August 17, 2013 Is that a safety hazard for hitting your head if there is ever a crash or even severe turbulence? That is a good thought, one I had not contemplated looking at these pictures. Looks like it might be forward enough to not be an issue. I have hit my head on the ceiling in severe turbulence hard enough to knock my headset loose - the right ear cup ended up on my nose with the whole thing covering my face..... its out there. 2
Bob_Belville Posted August 17, 2013 Report Posted August 17, 2013 That is a good thought, one I had not contemplated looking at these pictures. Looks like it might be forward enough to not be an issue. I have hit my head on the ceiling in severe turbulence hard enough to knock my headset loose - the right ear cup ended up on my nose with the whole thing covering my face..... its out there. I was there a time or 2 in 49M myself. I took comfort that if I could keep her reasonably level and in a reasonable speed range she could stand an awful lot of banging around.
NotarPilot Posted August 18, 2013 Report Posted August 18, 2013 Is that a safety hazard for hitting your head if there is ever a crash or even severe turbulence? Funny, you're not the first person who brought that up to me which was why I opted to put the heat shrink over the metal to cover the edges. In the time I've had it installed, I've hit some pretty good turbulence and haven't even come close to hitting my head on the headset hanger. It's too far forward in the cockpit to even come close to hitting my head and ever since I installed my shoulder harnesses earlier this year I think it's next to impossible for my big melon to hit it.
thinwing Posted September 5, 2013 Report Posted September 5, 2013 sorry so late to reply..Ive been flying for a week on vacation...I will take a pic and post...my solution puts the hanger facing toward the windshield and hangs the headset over the glare shield...looks better than notars solution and does not pose an impact risk in turbulence (I hit hard enough to break a pair of lightspeed zulus)and requires no drilling and gets the cord away from pilot/copilot so they are not yanked out exiting aircraft..kpc
Rick Junkin Posted November 30, 2017 Report Posted November 30, 2017 I came up with another idea for a headset hanger after searching for ideas led me to this thread. I bought a 6" flag pole rope cleat and attached it to the top of the tube in the center of the windscreen. Amazingly simple, and works great! Sorry about the picture orientation, I"m not smart enough to know how to rotate them on here. Cheers, Rick 4
HRM Posted November 30, 2017 Report Posted November 30, 2017 Headsets have large magnets in them, best to keep them away from compasses. Just sayin'.
Rick Junkin Posted November 30, 2017 Report Posted November 30, 2017 On 11/29/2017 at 9:39 PM, HRM said: Headsets have large magnets in them, best to keep them away from compasses. Just sayin'. Good point. I checked for that, they hang far enough away that there is no deflection on the compass. Cheers, Rick EDIT: I stand corrected - there is no deflection when BOTH headsets are hanging up, but there is 20 degrees of deflection when only ONE is hanging up. So yeah, that could be a problem if I left one hanging there for an extended time. I changed how I have the cleat mounted, now have it attached to the top of a RAM ball mount for my iPhone cradle. here are the new pics.
jaylw314 Posted November 30, 2017 Report Posted November 30, 2017 On 8/15/2013 at 10:56 AM, Bennett said: Great idea- using the headrest. I will start doing that for the pilot's side. I currently leave the headset on the glare shield, but I worry about scratching the inside of the windshield. The co-pilot side is the problem because, as we all know, it is too easy to get our feet caught in the wires sliding into the pilots seat. Why not have have the front passenger use the right rear plugs? Unless they help you with the radio, they don't need the PTT button, and they could just toss the headset in the backseat when exiting. Assuming there is no rear passengers, of course. 1
Yetti Posted November 30, 2017 Report Posted November 30, 2017 There is really no extra room for a large frame Yetti to get in and out. Replace the carpet put them on the floor
1964-M20E Posted November 30, 2017 Report Posted November 30, 2017 On my side I place them on the floor in front of me somewhat under the front seat after I have pushed the seat all the way back. This is out of the way so I do not step on them. Passenger side I unplug them a place them on the rear seat before the passenger begins to exit. So far this has worked well for me. 1
Stnelson903 Posted December 1, 2017 Report Posted December 1, 2017 http://mooneyspace.com/gallery/image/34497-image-6/http://mooneyspace.com/gallery/image/34498-/I made these last year and used heat shrink around the metal to cover the sharp edges. Can you repost those pics? They are not coming through. Sent from my iPhone using Tapatalk
NotarPilot Posted December 3, 2017 Report Posted December 3, 2017 On 11/29/2017 at 7:39 PM, HRM said: Headsets have large magnets in them, best to keep them away from compasses. Just sayin'. Between my iPad, two GPS navigators, HSI and Garmin G5 with a 4 hour battery back up, I highly doubt I would ever have use for my compass. It’s only there because the MEL says it has to be. 1
