mike_elliott Posted May 29 Report Posted May 29 The 99-2002’s were some of the worse for tank sealant leaks per Paul Beck. I hear the factory didn’t apply between rib and skin then. In any event, get it checked out and if it’s the sealant, patching will be a temporary fix as it will fail in other areas in short order 1
IvanP Posted May 29 Report Posted May 29 (edited) Are you asking about the discoloration or the nub sticking out from the wing surface? Edited May 29 by IvanP
N201MKTurbo Posted May 29 Report Posted May 29 14 minutes ago, IvanP said: Are you asking about the discoloration or the nub sticking out from the wing surface? The nub is the speed brake drain line.
Hank Posted May 29 Report Posted May 29 15 minutes ago, billy hellcat said: The brown color Fuel stains. It's leaking, see above.
IvanP Posted May 29 Report Posted May 29 22 minutes ago, MikeOH said: G100UL Kind of looks that way, but I think it would be far worse if he had G100UL in the tank. We would probably be looking at bare metal in some places.
Pinecone Posted May 29 Report Posted May 29 10 hours ago, mike_elliott said: The 99-2002’s were some of the worse for tank sealant leaks per Paul Beck. I hear the factory didn’t apply between rib and skin then. In any event, get it checked out and if it’s the sealant, patching will be a temporary fix as it will fail in other areas in short order AFAIK Mooney never sealed between the ribs and skins except for a few to try it out. But they tried to set the rivets with the sealant wet and that did not work well. It just squeezed out.
Fly Boomer Posted May 29 Report Posted May 29 2 minutes ago, billy hellcat said: Is this sealant then? No fuel is leaking. It looks like fuel, and it looks like it's been leaking for quite some time. Recent fuel leaks are blue from the dye in 100LL. 2
Ragsf15e Posted May 29 Report Posted May 29 1 hour ago, billy hellcat said: Is this sealant then? No fuel is leaking. Agree, it’s fuel.
flyboy0681 Posted May 29 Report Posted May 29 Yup. Same shade of brown that my leak showed. Time to call Edison at Wetwingologists.
billy hellcat Posted May 29 Author Report Posted May 29 Thanks guys! Appreciate the quick response. I was thinking of buying but not now. Went to deploy speed brakes and they were inop. Ughhh. Lots of inop things that weren’t talked about.
Geoff Posted May 29 Report Posted May 29 13 hours ago, N201MKTurbo said: The nub is the speed brake drain line. Nope, fuel tank vent line.
N201MKTurbo Posted May 29 Report Posted May 29 13 minutes ago, Geoff said: Nope, fuel tank vent line. Not even close. Doesn’t even look like the fuel vent. The fuel vent line usually has a small tube welded into a larger tube. And it’s in the wrong place. 1
Ragsf15e Posted May 29 Report Posted May 29 23 minutes ago, Geoff said: Nope, fuel tank vent line. The rectangular panel that drain comes out of is another indication that it’s a speed brake drain. That panel comes off and you can access the bottom of the cartridge.
Geoff Posted May 29 Report Posted May 29 1 minute ago, Ragsf15e said: The rectangular panel that drain comes out of is another indication that it’s a speed brake drain. That panel comes off and you can access the bottom of the cartridge. Perhaps the OP can advise if speed brakes are installed...
N201MKTurbo Posted May 29 Report Posted May 29 8 minutes ago, Geoff said: Perhaps the OP can advise if speed brakes are installed... He said above that the speed brakes don’t work.
Geoff Posted May 29 Report Posted May 29 4 minutes ago, N201MKTurbo said: He said above that the speed brakes don’t work. I suppose that settles it. 14 minutes ago, Ragsf15e said: The rectangular panel that drain comes out of is another indication that it’s a speed brake drain. That panel comes off and you can access the bottom of the cartridge. Perhaps the OP can advise if speed brakes are installed... 1 1
Pinecone Posted May 29 Report Posted May 29 Pilot - Logs discrepancy - Speed Brakes Inop Mechanic - Speed Brakes Not Installed. 3
EricJ Posted May 29 Report Posted May 29 2 minutes ago, 47U said: Upside down was driving me nutty… Well now it's definitely gonna leak. 3
