Hello all,
I am looking into a buying into a Mooney 231 it has 2 items that will have to be addressed
  1. tank strip and seal
  2. ADS/B solution
So what are the best options and cost associated with them. The aircraft has a Garmin Panel including a 480 and MX 20 so we have wx data from XM just need out.
Thanks in advance
DavidA
There have been about a zillion posts about ADSB compliance. Plenty of opinions if you search.
Tank resealing depends on where you are. East coast and northern, gives you choices. Southwest, look at Houston Tank Specialists.
Garmin is offering a software update on the 480W to output position data. When I looked at it for a relative 2 years ago, Garmin stayed it was only for their transponders. Don’t know if that has been modified to include other manufacturers.
My tank reseal at Troutdale Oregon was just over 10K but, a few additional repairs had to be made due to damaged rivets from a previous repair attempt.  ADS-B is going to be between about 2K - 5K depending on what you choose.
From what I’ve seen is go with a professional good reputation sealing shop or get bladders.  If you don’t get it done right it can be a perpetual headache from what I here..... I’ve got bladders and a Garmin 345. Prob looking at 17k for that particular combo but I’m very pleased with both fwiw.
Do the tanks really need a full reseal or just an ordinary patch? Be aware with bladders some like them and some hate them.  I’m no fan of them myself.
-Robert
I agree, but bladders aren’t even an option for a 231. It’s patch or reseal; preferably by someone with a proven track record and with a warranty as mentioned above.
I used Advanced Aircraft in Troutdale, OR as well, If I remember correctly it was about $4,800 per tank about 5 years ago.  They did a good job and stand behind their work.  Find out how old the tank sealant is, how many leaks and how bad they are.  If they are dripping / staining in multiple spots and the tank sealant is 15-20 years old then a re-seal is the way to go and probably cheaper than trying a patch job then doing a full re seal in a year, I learned the hard way. If there are a few small leaks in easy to reach spots try a patch but make sure to go to Advanced if you are on the west coast, Weep No More if you are in the middle or another shop that has done A LOT of Mooney tanks.  There is a spot in FL too but I have heard mixed reviews on them.
I have the GNS 480 & MX 20 as well and decided on the GTX-345 for adsb and am very happy with the result.
