TargetDriver Posted January 7, 2018 Report Posted January 7, 2018 All, So as you will probably pick up, I am sitting in a hotel room on my way in country and I'm bored. So, I do what every pilot geek does, flip through my K Model POH that I brought with me. I'm reading Airspeed Limitations and ran across a seemingly somewhat insignificant limitation that my curiosity got the best of me. So what better to do than to pose it to my MS brotheren. My POH says the Max Pilot Window Open Speed is 130 kts/150cas. The Never Exceed Speed is 132/152. That little window is only 4in x 5in. If I happen to open it faster than that will my plane pressurize and blow the tail cone off my plane or what ? Ha ha Does anyone have any odd experiences with this window at speed or maybe insight on this limitation? More of a curious question but like I said, I'm bored.
Jeff_S Posted January 7, 2018 Report Posted January 7, 2018 I always thought that the momentary pressure differential would exert a suction force on the fuel knob and pull you involuntarily into a LOP scenario! In reality, my guess is it has something to do with the pressure sensitive instruments in the cockpit and maybe would cause them to either malfunction or at least give erroneous output. But it is a fun thing to contemplate. 1
jetdriven Posted January 7, 2018 Report Posted January 7, 2018 The faster you go the more force tries to close it or hold it closed. At lower speeds you push the window closed and it closes. At higher speeds it tries to slam closed. At 180 KIAS it may slam closed hard enough to shatter the pilot window. Or smash any finger in its way. Just a theory. 2
gsxrpilot Posted January 7, 2018 Report Posted January 7, 2018 3 minutes ago, jetdriven said: The faster you go the more force tries to close it or hold it closed. At lower speeds you push the window closed and it closes. At higher speeds it tries to slam closed. At 180 KIAS it may slam closed hard enough to shatter the pilot window. Or smash any finger in its way. Just a theory. I've heard of the small window flap breaking as it slams shut with the added suction of high speed.
N201MKTurbo Posted January 7, 2018 Report Posted January 7, 2018 It will slam shut with great force if you are going fast. If you inadvertently open it above the red line speed, wrap your fingers around the window so it closes against your fingers then slip them out and let the window close gently. 1
Marauder Posted January 7, 2018 Report Posted January 7, 2018 We all know the real reason you don’t open the window above the limits. Sent from my iPhone using Tapatalk Pro 6
carusoam Posted January 7, 2018 Report Posted January 7, 2018 Two things you can do, but don't want to do at speed... let the little window flop closed and drop the gear... Things happen surprisingly quickly with lots of force under these conditions. Lots of air trying to escape the cabin... Lots of air pushing on the gear doors... Things that don't get much coverage in the old POH. Welcome back in Country! Go Fly, -a- 1
KLRDMD Posted January 7, 2018 Report Posted January 7, 2018 8 hours ago, TargetDriver said: My POH says the Max Pilot Window Open Speed is 130 kts/150cas. The Never Exceed Speed is 132/152. That little window is only 4in x 5in. If I happen to open it faster than that will my plane pressurize and blow the tail cone off my plane or what ? Ha ha Does anyone have any odd experiences with this window at speed or maybe insight on this limitation More of a curious question but like I said, I'm bored. I've been flying a friend's Cessna P210 lately. In reading the POH I noticed the window opening speed is redline. The window structure is very different and it opens very differently than a typical GA airplane. Of course I have to assume if you're opening the window in flight you're not pressurized . . . or you're not gonna be
TargetDriver Posted January 7, 2018 Author Report Posted January 7, 2018 Guys, All very good explanations for sure ! Hey Jim ... I too had thought about the vacuum maybe affecting the instruments like you said, as an Alt Static source issue maybe but wasn't sure. The vacuum sucking the window shut fast enough to break the pilots window...that could be stupid interesting in hurry ! I know in my K, that event would surely ruin the new upholstery that's being done now, while I'm doing my last 9 weeks deployed. HA I normally close my pilots window as the last thing before taxiing onto the runway to depart so have never tried closing it in flight really. I did have a right side passenger door pop open unlatched one time in a Cessna 172 just after breaking ground. I was by myself and in retrospect, never actually checked the door for solid latching because I didn't go in that side. Just assumed it was locked from sitting on the ramp. The noise that made even with a headset on almost ruined the upholstery! ha Good to know about that much force being on the window and to completely hold onto it to close.
bonal Posted January 7, 2018 Report Posted January 7, 2018 On really hot days I have left the window open during climb and closed it when reaching cruise altitude no problem closing as long as you control it and keep it from slamming shut. 3
ArtVandelay Posted January 7, 2018 Report Posted January 7, 2018 If you slip the plane you should be able to block the airflow past the pilot window.
N601RX Posted January 7, 2018 Report Posted January 7, 2018 It will cause a change in cabin pressure. I opened mine one day in level flight to take a better picture and it resulted in the Brittain Altitude Hold applying a full down elevator about 3 seconds later. 1 1
triple8s Posted January 7, 2018 Report Posted January 7, 2018 If the window gasket on the pilots vent window is not glued perfectly the air will suck a piece of it off how do I know don't ask
thinwing Posted January 8, 2018 Report Posted January 8, 2018 Had a friend try to deliver dear departed ashes of the deceased over the Sierra Nevada using a Rube Goldberg pvc/ funnel device to stick out pilots storm window while in cruise flight.He came back looking like a ghost..makeup and all! 2
Piloto Posted January 8, 2018 Report Posted January 8, 2018 The pilot window limitation is to keep women pilot long hair from being pulled out.
HRM Posted January 9, 2018 Report Posted January 9, 2018 3 hours ago, Piloto said: The pilot window limitation is to keep women pilot long hair from being pulled out. ...and it somehow can distinguish the long hair of a man pilot?
Hank Posted January 9, 2018 Report Posted January 9, 2018 19 minutes ago, HRM said: ...and it somehow can distinguish the long hair of a man pilot? Few men have hair long enough to reach out the window while sitting up in the seat. Many women do.
HRM Posted January 10, 2018 Report Posted January 10, 2018 23 hours ago, Hank said: Few men have hair long enough to reach out the window while sitting up in the seat. Many women do. True. I think Dave Morris keeps his hair in a pony tail...must be for this reason
TargetDriver Posted January 12, 2018 Author Report Posted January 12, 2018 Hey all. Thanks for the replies... still laughing at some of them! Back deployed now and have internet again so I'm MS'n again. On 1/7/2018 at 11:43 PM, N601RX said: It will cause a change in cabin pressure. I opened mine one day in level flight to take a better picture and it resulted in the Brittain Altitude Hold applying a full down elevator about 3 seconds later. Note to self... turn autopilot off before opening window to take picture !!! That had to be an upholstery repair job?? Ha On 1/9/2018 at 3:43 AM, thinwing said: Had a friend try to deliver dear departed ashes of the deceased over the Sierra Nevada using a Rube Goldberg pvc/ funnel device to stick out pilots storm window while in cruise flight.He came back looking like a ghost..makeup and all! Thinwing... Sac?? My planes at L36 ! Some of those Sierra Nevada mtns are right behind my house (well, sortof)
