Pinecone Posted January 4, 2023 Report Posted January 4, 2023 8 hours ago, EricJ said: Would taking off on a long runway in a C150, doing a little slow flight down the runway, and then landing count? I did 5 take offs and landings to a full stop in one pass down the runway in a Citabria. SAC base aero club airplane. So 11,700 foot runway. 1 Quote
MikeOH Posted January 4, 2023 Report Posted January 4, 2023 5 hours ago, GeeBee said: Here is a bonus question. If you are at an uncontrolled field, 2 miles from a towered airport with Class D airspace and it is reporting 1/2 mile visibility but the uncontrolled field has 3 miles, do you need an IFR clearance? Do you need to talk to the tower? That’s TWO questions! No Yes (as soon as practicable after departure) 1 Quote
Will.iam Posted January 4, 2023 Report Posted January 4, 2023 Well we did figure 8’s landing on the runway both directions in a tanker a modified B707 when the winds were less than 5 mph. My record was 33 landings in 4.5 hours getting landing currency done. Quote
RLCarter Posted January 4, 2023 Report Posted January 4, 2023 Couple hundred feet in my E, was a high speed taxi with a little too much nose up trim and gusty headwinds…….ooppppps Quote
Canadian Gal Posted January 21, 2023 Report Posted January 21, 2023 It wasn't in a Mooney, but 1.2 nm from my dock to a friends dock in my 185. Estimated altitude 10'. 1 Quote
aviatoreb Posted January 21, 2023 Report Posted January 21, 2023 Do touch and goes count? How about straight ahead touch and goes - at KPBG a nice 12000 ft runway from the B52 bomber era you can do a few touch and goes straight ahead? If so I would say my shortest flight is a few hundred feet. Or if a bounced landing counts - I would say a few dozen feet is my shortest flight. I went to Kitty Hawk and they have markers out for that first, and very famous, and very short, flight. Quote
Pinecone Posted January 21, 2023 Report Posted January 21, 2023 54 minutes ago, aviatoreb said: Do touch and goes count? How about straight ahead touch and goes - at KPBG a nice 12000 ft runway from the B52 bomber era you can do a few touch and goes straight ahead? If so I would say my shortest flight is a few hundred feet. Or if a bounced landing counts - I would say a few dozen feet is my shortest flight. I went to Kitty Hawk and they have markers out for that first, and very famous, and very short, flight. I already mentioned that. I did 5 to a full stop, climb to 50 feet for each, on one pass down the runway. 1 Quote
carusoam Posted January 22, 2023 Report Posted January 22, 2023 Departed with 180hp, lost a cylinder before TPA… Landed on the nearest cross runway…. A very brief, exciting, and eventful flight… Go bullet proof M20C’s O360! Best regards, -a- 1 Quote
ohdub Posted January 22, 2023 Report Posted January 22, 2023 I think my shortest flight was KFFA-KMQI. 6NM. Quote
Pinecone Posted January 22, 2023 Report Posted January 22, 2023 8 hours ago, carusoam said: Departed with 180hp, lost a cylinder before TPA… Landed on the nearest cross runway…. A very brief, exciting, and eventful flight… Go bullet proof M20C’s O360! Best regards, -a- I almost had a similar short flight. And, of call places, at First Flight. We had stopped to see the site and museum. Club C-172. About 100 feet or so, had what I suspect was a stuck valve. Had enough power to slightly climb, so started a pattern to land. After about 90 degrees of turn, engine started making full power. So I circled over the field, climbing, until I had more than enough glide range to the next airfield and maintained glide to an airport back to KGAI (home base for the plane). 1 Quote
A64Pilot Posted January 25, 2023 Report Posted January 25, 2023 On 1/2/2023 at 8:58 PM, N201MKTurbo said: One lap around the pattern. it’s hard to beat that. I’ve got thousands shorter. Tracking and balancing a helicopter. Pull to a hover for 15 sec or so to take a reading, land, shut down and make a PC link adjustment, repeat until track is good, then start the flying part. Quote
N201MKTurbo Posted January 25, 2023 Report Posted January 25, 2023 37 minutes ago, A64Pilot said: I’ve got thousands shorter. Tracking and balancing a helicopter. Pull to a hover for 15 sec or so to take a reading, land, shut down and make a PC link adjustment, repeat until track is good, then start the flying part. But this is MooneySpace, not ApacheSpace... 1 Quote
