Hi MSers,
Me too thread here. Yet another IIO360A1A with lifter>CAM>Oil pump damage sequence.
Vitals:
App 1100 hrs SMOH on 1994 Firewall Fwd Overhaul
Cam Guard Used
Flown 150 hrs hours per year since I purchased in 2017.
First symptom was verify fine dust started showing up in Oil Filter (see thread on MS with pics)
Oil Analysis was "clean" per IA doing changes.
Oil changes @ 25 hour intervals, or more often,  since "dust" started showing up.
Finger screen clean until last oil change where some flakes appeared.
Flew it to Jewl Aircraft Engines for tear-down :
Having full OH done with DLC Lifters/Cam.
Didn't get pictures of that but can request from Jewell. Assume fines scoured or damaged pump gears or chamber so that is on the replace list.
Yes, condolences...
In the 23 years since overhaul before your purchase, the average was around 35 hrs/year... were those hours accumulated early after the overhaul?  Did the airplane sit for any extended period of time before your purchase?
Tom
Thank you, Stephen, for sharing the details and pics...
Looking forward to hearing your experience with the new lifters and cam...
It May take decades... :)
AFAIK, the oil pump is a pretty robust piece of hardware (when was the last time you heard of an oil pump getting overhauled?), so I wonder if there is something larger than just flakes... :unsure:
Around Y2K... an aluminum gear was used for preferential wear... it was too soft and wore out to easily...
It was an AD around that time for all Lycoming 360 engines...
PP thoughts, fuzzy memory at best...
Oil pump gear AD’s go back to the mid 70’s through the mid 90’s for the most recent one.  It was to get rid of aluminum gears, sintered iron gears, woodruff key drive gears and 2 piece pump bodies.
Sorry to hear about your engine. This seems to confirm much of what I’ve thought for years about the camshaft problem being more prevalent on the IO-360 engines versus the O-360’s. That extra 20 HP comes at a cost. This also brings into question the real effectiveness of Camguard versus the success of their marketing. So does Camguard offer any concessions for you in this case?
  • Sad 1
He just purchased it in 2017, so Camguard will say damage was done before then.
Tom
At the risk of being an a__hole, that line of thinking is a prime candidate for confirmation bias.  you should be looking for examples that disprove or undermine your hypothesis... :P
Actually, that's not a risk, most people I know do think I'm an a__hole... ;)
Edited by jaylw314
Well, after almost 9 years of being on this site and previously on Mooney pilots FB, almost all of the camshaft problems are in IO-360 engines. I’ve been looking for a spike in O-360 engine camshaft issues and haven’t found that trend shift yet. Thankfully there’s not many a_holes on MS. The ones that are, I have blocked!
  • Sad 1
First I've heard of it, but its all about the force and area.  The earlier O320H2AD engines had smaller lifters, then the T mode came along to make the lifters larger.  In my experience, its more about the regular use of the engine than the T mod.
Now for the O360 vs IO360 - I assume the same cam / lifter arrangement?  So same bearing pressure on the face of the cam/lifter?  Anything different about the valves / springs?
If not, I'd put it all on the lack of use rather than the engine time.
Aerodon
Aerodon
I’d have to get into the Lycoming IPC to verify cam and lifter p/n’s to see if they are the same or not between the models. I don’t believe lack of activity is the major factor, but rather metallurgy of the camshaft as well as camshaft and lifter re-grinding during overhaul versus replacing with new parts.
All bets are off with long term storage in high humidity environments. It won’t just be the camshaft with issues in this case.
I, too havwe noticed that. Not sure why, but it seems all the IO-360s have lifter problems, and some O-360s do.
Aerodon
Regular use doesnt prevent it. It doesnt seem to make a difference. I know a few pilots, Mooney guys, on their third engine now. found a mid time cam wiped out, lifters shot. Replaced it, new cam and lifters, ran it 450 hours in 2-3-4 years. Camguard, Phillips XC oil, never sat more than 4 days.  Still spalls again. Brian at Wilmar has a story. So does @aaronk25
Edited by jetdriven
I believe that it is a combination of stronger valve springs on the IO series and the double duty of the intake lobes doing twice the work of the exhaust lobes, mixed in with lower use/ inactivity at times.
Meh, I had an O-360 and same exact deal. My lifters and cam were even more worn than what is seen in this picture. I think any Lycoming that sits is going to be vulnerable.
Edited by AlexLev
The hardening of the cam is only on the surface, so any rust that appears will breakthrough and eventually you’ll have problems.
We’ll see if new diamond coating helps, supposedly Lycoming said if they they would not have gone with the roller tappets if they had this new technology.
Tom
....from your keyboard to my engine !
Hopefully they do the trick
20 hours ago, 47U said:
Yes, condolences...
Tom
Was an AZ plane I believe through most of that time then AL afterwards, very likely had idle time but I don’t know. Was active while I’ve owned it and hopefully will remain so
That's 25 years since overhaul. The damage was probably done before you owned it. A small amount of corrosion on the cam, and it took your frequent flying for it to grind away enough to become evident in the filter.
I had a similar experience, mine had been over 20 years since overhaul and starting making metal. I feel like after two decades plus it was time for it anyway. To me it is just not realistic to expect an engine to sit on airplane for two or three decades and remain airworthy.
 So you bought the plane with time on the engine.  Overhaul done in 1994.What was time on engine when you purchased?  You have no idea how engine was operated before purchase.  What was annual operation in years before you purchased?
1995 hours___
1996 hours___
1997 hours___
1998 hours___
1999 hours___
2000 hours___
2001 hours___
2001 hours___
2002 hours___
2003 hours___
2004 hours___
2005 hours___
2006 hours___
2007 hours___
2008 hours___
2009 hours___
2010 hours___
2011 hours___
2012 hours___
2013 hours___
2014 hours___
2015 hours___
2016 hours___
Why is CamGuard being blamed?
Sorry you are having engine problems.
I don’t blame this on IO-360 engine at all...
Edited by RogueOne
Probably need to block me because that post is garbage.
