As some here will know, I had my plane painted this year. It turned out well, looks great.
But the plane is noticeably slower and I am trying to figure out why.
One possible issue is the paint trim stripes. The ends of the wings and (horizontal stabilizer) has 4 stripes angled and tapered, top and bottom. There's a paint ridge, perhaps as much as 1/16" high between all the stripes. Since the airflow over and under the wing passes over these ridges I suppose there is disruption.
So... does anyone here have experience/knowledge as to whether this might be causing drag?
And... what would be the best way to remove the ridge without screwing up the paint job?
Thanks!
Weight difference Before new paint vs after?
as @jackn said, the way the control surfaces were reinstalled would create a lot more drag than paint.
I know I've drooled over this paint job in the past few months, but never saw the original paint job before. Questioning how a "smooth" paint vs. a previously "rough" job would cause more drag.
Nothing slows a Mooney down quite like poor rigging. And no one seems to be able to coax as much speed out of a good rigging job as Don Maxwell.
Expand
My fuel servo has slowed mine down considerably over the past 3 weeks.... Top speed has been 10-15 ktas, behind a tug, back and forth from the mechanics hangar and mine.
  • Haha 2
Expand
that's moving a bit fast, I would recommend 5 kts max
Brian
Brian
Expand
Pure estimates.... But, yeah your right. Strong tailwind? :P
I have seen people hauling ass towing planes, while that in it self isn't a major issue the problem is more the force on the nose gear when you turn, or  need to slow or stop. a sudden stop could cause the gear to collapse and turns at high speeds will increase side loads on the nose gear. when you are taxing at higher speeds you are breaking with the mains so there is no load pushing back on the nose gear, turning at high speeds can put increased side load on the gear but that load is exaggerated by a tow bar attached to a vehicle.
Expand
Mine was last towed behind a small, dark red riding mower with the deck removed, with the mower running backwards to pull the plane from the ramp to the A&P's shop . . . Not quite my own [slow] walking speed . . . .
Expand
I'm happy to have a AME that's cautious, and works on a lot of Mooney's.... He's slow as F&&K when it comes to getting things done (Fuel Servo has been back from OH for 11 days now... just finishing putting it on today), but he's careful and meticulous.
My comment was that it wasn't going 145 kts like it should...
When your airplane was disassembled for paint and re-assembled could the rigging have been effected?  How is the rigging currently?  Does the ball sit centered when you are in level flight?
Expand
Eric, presumably the ailerons were put back on exactly as they were taken off, at the hinges, without changing the rigging. There is a definite possibility that the trailing edges of the control surface were changed. Lynn and I are in the process of re-tweaking them. Ball is centered in cruise.
Not only the rigging but I know you also had that new cowl.  Is it noticeable after the cowl to after paint or before the cowl to after paint.   How many kts is "noticeable"? The good news is it LOOKS FAST!!!!!!!
Expand
You know - dawling - its now how you feel, its how you wrook.
And you wrook MAAAVELOUS!
Edited by aviatoreb
Expand
No way that any of the control surfaces could be incorrectly installed, about the only thing that could be done improperly beyond balancing them would be too not use the proper hardware which can be verified visually.  Neither effects rigging.
We finished the cowl just in time to fly to the painter so no data to distinguish. But the other planes with the SabreCowl all report speed gains.
Sent from my XT1710-02 using Tapatalk
Expand
The fact that other aircraft reported gains doesn't automatically mean yours will.  Too small a sample size to really make solid predictions.
  On 11/7/2018 at 8:43 PM, Piloto said:
Check
Alternate air button position
Pitot tube paint residue
Static ports paint  residue
Static and pitot tube paint residue.
José
Expand
I think Jose is onto something.  When I had my G5's installed and they re-certified my pitot static system I was having some false readings and they had to track down some leaks.  Therefore, you might actually be going as fast as it looks but just reading slower.
Expand
Bob,
But you had the ARI cowl before, the others I believe just had the LASAR lower enclosure and some still had the air and oil filter out front.  It would make sense that those planes would see genuine gains where yours may not.
  On 11/7/2018 at 9:50 PM, kpaul said:
Bob,
Expand
I Agree. The ARI was fine. But it is not that I've not gained speed, which I did not expect to gain much if anything, I have lost at least 5 kts, maybe more.
Check
José
Expand
Thanks José.
The plane had a static system certification after the paint job.
IAS seems to be accurate. I made a round trip to Smithfield (about 150 nm due east) last week and the GPS  ground speed was 160 kts with a strong tail wind and 115 on the return. 7000' and 6000', 8.1 GPH LOP. Not to assume too much precision, that's an average of 135-140 kts. I would have expected about 145 TAS under those conditions.
