I occasionally see a flashing voltage light which indicates low voltage which is usually caused by an alternator malfunction, belt slippage, or tripped breaker.
I think the low voltage indicator is set for 12.4 to 12.5 volts.  When I get the light, my JPI EDM 700 shows 13.5 - 13.7 and the ammeter is zero.
The breaker is not tripped, the belt is tight and the battery is fully charged and easily starts the engine.
Do I have a problem?  If so, how should it be fixed?  Thanks
After starting, low rpm taxiing, this would be expected behavior...
Alternator output increases with rpm...
in cruise, showing 13+V the alternator is clearly working...
Follow-up may be learning more about the annunciator panel, proper settings and adjustment? (Is it working correctly)
If the settings are right, everything is working correctly... and it’s a momentary loss of a voltage reading...
Use José’s advice... check both power supply and ground.
PP summary of what I have read on MS...
13 hours ago, 1964-M20E said:
Verify the field wire and the ground wire to the alternator are in good condition and the connections are tight.
+1
