jaylw314 Posted July 31, 2018 Report Posted July 31, 2018 16 hours ago, whiskytango said: I have heard the same warning about damaging the vanes in a dry vacuum pump as a result of turning the prop backwards from an A&P, and never do it. Dry vacuum pumps have always seemed to have 2 strikes against them at all times, so why make things worse? Because a vacuum pump failure should fail safe--in VMC it's a non-issue, and in IMC you have a standby pump and partial panel training. Nobody has ever died from the initial vacuum pump failure, they've died from lack of recognition or subsequent failures in decision-making. On the other hand, people have died and have been seriously injured from prop kicks 16 hours ago, DXB said: Yeah I've had a backfire too at a low RPM, I think it was around 1100 rpm which is where I normally idle per my POH. It was actually when formally complying with the 100AD for the Bendix ignition. I can't recall if I had it maximally leaned out or not - leaning more or a lower rpm might have prevented it, but I've been gun shy about trying again ever since. When I had a backfire, I had it leaned out aggressively for taxi. Of course, I also had a bad right mag, so maybe there was extra unburned fuel in the exhaust.
Yetti Posted August 1, 2018 Report Posted August 1, 2018 I have a couple of rules. Never put your self in the prop arc. I hate it when I see people leaning over a prop. For the move of the blade that it needs to be straight across for the towbar, I use gentle pressure till the compression bleeds off, using only my finger tips. If a plane is running, I have a rule of never going forward of the wing. I hanger at a busy lunch spot and I will always walk behind any running plane. always looking for activity around planes and for people starting up. Same thing with chainsaws and all saws, never cut with your body in line of the saw. Always stand to one side and cut to the side. 1
