201er Posted March 22, 2017 Report Posted March 22, 2017 What vertical descent rate do you typically use? Particularly coming down from a long cross country flight.
gsengle Posted March 22, 2017 Report Posted March 22, 2017 300-500 fpm. Allow Garmin 530 to pick my top of descent (TOD)Sent from my iPhone using Tapatalk
kortopates Posted March 22, 2017 Report Posted March 22, 2017 200-300' FPM Slow as possible for maximum time and fuel effeciency and rarely a problem even being IFR, but IFR is often closer to 300'
201er Posted March 22, 2017 Author Report Posted March 22, 2017 I use my 430W to plan a 300fpm descent to arrive 1nm from the airport at 1000ft AGL. Since I pick up a little speed in the descent, I can vary the descent rate to still arrive at the same point. This will range between 300-400fpm. I usually bring the power back a little because going too fast in the descent adds a lot of parasitic drag and is inefficient. 300fpm is comfortable, allows me to maintain cruise or slightly higher speed at a lower fuel flow, and gives me a stable platform for the last portion of the flight.
1964-M20E Posted March 22, 2017 Report Posted March 22, 2017 I said 500fpm but it will vary. In the summer time if ATC tells me to descend at pilot's discretion and I'm far enough out I will do 200fpm to stay in the cool air longer. When told to descend to x altitude I will generally go 500fpm.
N201MKTurbo Posted March 22, 2017 Report Posted March 22, 2017 I plan on 500 FPM. I have my GPS set to put me at pattern altitude 5 miles out. This gives me space to slow to approach speed.
peevee Posted March 22, 2017 Report Posted March 22, 2017 depending on route my airport lies right on the edge of mountains. I need to get from minimum 12,5 to 6500 in not too many miles. Less than 1k FPM isn't really feasible trucking along at 200+ knots.
peevee Posted March 22, 2017 Report Posted March 22, 2017 1 hour ago, kortopates said: but IFR is often closer to 300' AIM 4-4-10(d) d. When ATC has not used the term “AT PILOT’S DISCRETION” nor imposed any climb or descent restrictions, pilots should initiate climb or descent promptly on acknowledgement of the clearance.Descend or climb at an optimum rate consistent with the operating characteristics of the aircraft to 1,000 feet above or below the assigned altitude, and then attempt to descend or climb at a rate of between 500 and 1,500 fpm until the assigned altitude is reached. If at anytime the pilot is unable to climb or descend at a rate of at least 500 feet a minute, advise ATC. If it is necessary to level off at an intermediate altitude during climb or descent, advise ATC, except when leveling off at 10,000 feet MSL on descent, or 2,500 feet above airport elevation (prior to entering a Class C or Class D surface area), when required for speed reduction.
Ron McBride Posted March 22, 2017 Report Posted March 22, 2017 I start my descent when the 496 says approx. 300 ft. per minute. I usually at about 400 ft per minute with the extra speed. Ron
kortopates Posted March 22, 2017 Report Posted March 22, 2017 1 minute ago, peevee said: AIM 4-4-10(d) d. When ATC has not used the term “AT PILOT’S DISCRETION” nor imposed any climb or descent restrictions, pilots should initiate climb or descent promptly on acknowledgement of the clearance.Descend or climb at an optimum rate consistent with the operating characteristics of the aircraft to 1,000 feet above or below the assigned altitude, and then attempt to descend or climb at a rate of between 500 and 1,500 fpm until the assigned altitude is reached. If at anytime the pilot is unable to climb or descend at a rate of at least 500 feet a minute, advise ATC. If it is necessary to level off at an intermediate altitude during climb or descent, advise ATC, except when leveling off at 10,000 feet MSL on descent, or 2,500 feet above airport elevation (prior to entering a Class C or Class D surface area), when required for speed reduction. Yes, Its all about communicating. My point is even in busy airspace its not that hard to get a slow descent with the controllers Ok. Even in busy SOCAL airspace, even if I can't get pilots discretion for the entire descent, I'll most often get it after clearing some altitude he/she needs me below. Sometimes for example, I may be asked to expedite for opposite direction traffic to an altitude of x and then resume pilot discretion to y. I am often asking for an early pilot discretion descent and am familiar enough with the airspace to know where I am most able to get it. Just gotta talk and ask. Who knows, maybe we'll eventually see more of the Next-Gen approaches geared to help make jet's make a continuous descent to the airport at near idle power get deployed to GA airports. RF-Leg capable GPS and EFIS capability make it possible for many of these. 1
peevee Posted March 22, 2017 Report Posted March 22, 2017 Just now, kortopates said: Who knows, maybe we'll eventually see more of the Next-Gen approaches geared to help make jet's make a continuous descent to the airport at near idle power get deployed to GA airports. RF-Leg capable GPS and EFIS capability make it possible for many of these. They don't work that well for the jets, why would they work any better for GA?
kortopates Posted March 22, 2017 Report Posted March 22, 2017 3 minutes ago, peevee said: They don't work that well for the jets, why would they work any better for GA? I don't know, but my impression as an observer has been the controllers don't like them much yet since when the old ILS is still getting the majority of the traffic the new longer approaches kinds tie up your hands for vectoring them to final and probably create a headache for fitting them onto final with other traffic. If more of the traffic was using the new approach I imagine it would make it a lot easier for everyone. But I could be way off. What do you see as the issues?
PTK Posted March 22, 2017 Report Posted March 22, 2017 Assuming IFR, I shoot for a 500 fpm rate of decent. It keeps ATC happy and the math simple. 1
carusoam Posted March 22, 2017 Report Posted March 22, 2017 (edited) 500 for the math, but 400 fit my preferred route over water at the primary destination... I had a portable G that would warn of the TOD and give a virtual glide slope for guidance... no math required. any higher the airspeed is blistering... This is for my NA engine. Max power available, staying off redline, while descending... Getting to the airfield with the targeted amount of energy. Not arrive 3000' high or be three miles out at TPA... Fun engineering energy calculations, no wrong answers... Best regards, -a- Edited March 22, 2017 by carusoam
Awful_Charlie Posted March 23, 2017 Report Posted March 23, 2017 I set the Avidynes up for a 600fpm descent, and when it chimes then dial in 700fpm without touching the throttle - the increased speed more or less cancels out the difference. Still takes 20 odd minutes and ~100nm to get down from FL200! For mental planning without the GPS I use 200ft/nm, or 5nm per 1000'
chrisk Posted March 23, 2017 Report Posted March 23, 2017 I prefer 500 fpm, but I've also had plenty at 1500 fpm. It's what happens when a controller hands you off late, or terrain gets in the way. 1
Bob_Belville Posted March 23, 2017 Report Posted March 23, 2017 14 minutes ago, chrisk said: I prefer 500 fpm, but I've also had plenty at 1500 fpm. It's what happens when a controller hands you off late, or terrain gets in the way. +1
midlifeflyer Posted March 23, 2017 Report Posted March 23, 2017 Another general 500 FPM target here. It's easy math if I don't want to use the calculator and is quick enough without bothering some passengers. obviously, there are situations in which I might do more or less.
Danb Posted March 23, 2017 Report Posted March 23, 2017 The answer's are assumed your IFR within the system, I've cancelled often going into KILG 80 miles out so descend and go direct to the airport on my terms, I lose speed going into the teens I would like to gain it back on my descent,when in the system I set 600 FPM in the box unless a different descent profile is asked l'll cross Money at 8000 then pilots discretion.
chrisk Posted March 23, 2017 Report Posted March 23, 2017 Here is a good example of a slam dunk from Tuesday, visiting DMax. Somewhat my fault for asking for not asking the controller earlier.
peevee Posted March 23, 2017 Report Posted March 23, 2017 3 hours ago, Awful_Charlie said: I set the Avidynes up for a 600fpm descent, and when it chimes then dial in 700fpm without touching the throttle - the increased speed more or less cancels out the difference. Still takes 20 odd minutes and ~100nm to get down from FL200! For mental planning without the GPS I use 200ft/nm, or 5nm per 1000' I feel your pain. Reducing at 1" per minute from 31 or 32 inches to 25" adds time to the process plus controllers don't really understand we can't go down like the jets.
peevee Posted March 23, 2017 Report Posted March 23, 2017 Hey that's a good idea, just a VFR flight so not a controller slam dunk, but terrain+ground speed=hustle down. Pattern is 6500
Mooneymite Posted March 23, 2017 Report Posted March 23, 2017 When cruising with a tailwind, I tend to try to stay up at the optimum altitude longer and accept a higher rate of descent at the lower altitudes. Same thing if I know the lower altitudes are bumpy. Stay in the tailwind/smooth air longer, hurry through the adverse wind/bumpy air. Interesting that my POH recommends maintaining cruise airspeed in the descent, but doesn't differentiated between cruise indicated, or cruise TAS. I presume it means indicated, but I generally allow the indicated to creep up to maintain cruise TAS. Using the Vertical nav feature of the 430W allows me to see where I am in relation to my programmed 500' descent.
jkhirsch Posted March 23, 2017 Report Posted March 23, 2017 (edited) Clearly any good pilot should look to carry maximum kinetic energy to the point of impact and achieve this on each and every approach to landing to avoid operating at reduced power settings where every single engine failure happens: Edited March 23, 2017 by jkhirsch
