ChristianGodin Posted November 1, 2016 Report Posted November 1, 2016 Anyone can tell me the approx cost for tanks resealed for an Ovation? Some say that the tank are 89 gallons. Others says that all 89 gallons are 102 gallons if filled to the top. Is this right. Also, anyone know a good Mooney Center Near Conroe, Texas (KCXO) Thank You Quote
Jerry 5TJ Posted November 1, 2016 Report Posted November 1, 2016 Just now, ChristianGodin said: Some say that the tank are 89 gallons. Others says that all 89 gallons are 102 gallons if filled to the top. Is this right? Ovation holds 89 gallons filled to the bottom of the filler neck. About 100 if carefully filled to the caps. Quote
carusoam Posted November 1, 2016 Report Posted November 1, 2016 The standard O1 tanks are about 102. The Eagle uses a much lower number, but the tanks are physically the same size. Internal tank hardware makes the difference. That were born with a long fuel neck. The fuel neck forces refueling to be slowed by venting al the air out the tank's vent. Ingenious hangar elves have modified some of those necks. The way to be sure, is as easy as reading your POH, which can often be found in the plane tucked in a pocket behind the copilot seat. The POH lists all volumes. Often they will use the Serial number of the airframe. There is also a section of placards. There is probably a placard or two for that... Best regards, -a- Quote
Hank Posted November 1, 2016 Report Posted November 1, 2016 How far is Conroe, TX from Longview? It's east of Dallas, look for KGGG. You won't find better service for your Mooney. 1 Quote
ChristianGodin Posted November 1, 2016 Author Report Posted November 1, 2016 Longview is not far by plane but 20 hours + if by car? Quote
donkaye, MCFI Posted November 1, 2016 Report Posted November 1, 2016 2 hours ago, ChristianGodin said: Anyone can tell me the approx cost for tanks resealed for an Ovation? Between $11,000 to $13,000 depending on who you use. Get bids from all who specialize in full tank reseals. Not the time to try someone with little experience. Mine are being resealed right now at Weep no More in Willmar, MN. I live in California, so that should tell you what I think of them. 1 Quote
romair Posted November 1, 2016 Report Posted November 1, 2016 +1 on Weep no More. Definitely worth the trip there. 1 Quote
Zwaustin Posted November 1, 2016 Report Posted November 1, 2016 Mine were done by weep no more in 2010. No issues since I bought the plane. Think the warranty is good for 7 years if I recall correctly. Conroe to Longview is about a 3 hour drive and a 45-55 minute flight. Dugosh in Kerrville is also pretty good, Southwest Texas aviation in San Marcos (soon to be moving to KBAZ) heard good things. I have been to Maxwell more than once. Happy to share those experiences as well. Quote
anthonydesmet Posted November 2, 2016 Report Posted November 2, 2016 Had mine resealed at wetwingologists in Ft Lauderdale. Does Mooney's only. Also has a 7 year warranty. Couldn't be happier. From my research I think you are on solid footing if you go with Weep No More, Dugosh or wetwingologists. 1 Quote
mooneyflyfast Posted November 2, 2016 Report Posted November 2, 2016 Check with Houston Tank Specialists in Eagle Lake. I had a tank sealed at Willimar,MN and was happy with the job but......It is the hardest place to get to from Texas. It is in the boondocks west of Minneapolis. I had a guy with airline privileges take it up there and it still cost at least 1,500 to get it up there and back.. I flew commercial to Minneapolis, took a $50 cab ride to a small airport on the west side of town. Paid a pilot to fly over and pick me up and fly us back to Willmar.. Flew to Omaha and spent the night. Got home the next day. I will try to get it done closer to home next time. Quote
anthonydesmet Posted November 3, 2016 Report Posted November 3, 2016 23 hours ago, mooneyflyfast said: Check with Houston Tank Specialists in Eagle Lake. I had a tank sealed at Willimar,MN and was happy with the job but......It is the hardest place to get to from Texas. It is in the boondocks west of Minneapolis. I had a guy with airline privileges take it up there and it still cost at least 1,500 to get it up there and back.. I flew commercial to Minneapolis, took a $50 cab ride to a small airport on the west side of town. Paid a pilot to fly over and pick me up and fly us back to Willmar.. Flew to Omaha and spent the night. Got home the next day. I will try to get it done closer to home next time. Pretty much why I ended up wetwingologists. Have a 2nd house in Florida about a 1.3 flight time and commercial back to Virginia with mileage points after drop off. Wetwingologists does have 24 years of service and a great reputation. I also know Paul at weep no more is very highly claimed. I think if I was also going to do other upgrades at the same time as the reseal (dreaming that I had bottomless pockets) like interior, glass, annual at the same time I probably would have went to Paul and Bruce Jeager. Quote
donkaye, MCFI Posted November 3, 2016 Report Posted November 3, 2016 On 11/2/2016 at 10:38 AM, mooneyflyfast said: Check with Houston Tank Specialists in Eagle Lake. I had a tank sealed at Willimar,MN and was happy with the job but......It is the hardest place to get to from Texas. It is in the boondocks west of Minneapolis. I had a guy with airline privileges take it up there and it still cost at least 1,500 to get it up there and back.. I flew commercial to Minneapolis, took a $50 cab ride to a small airport on the west side of town. Paid a pilot to fly over and pick me up and fly us back to Willmar.. Flew to Omaha and spent the night. Got home the next day. I will try to get it done closer to home next time. Where there's a will there's a way. It's a 2 hour drive from Willmar to Minneapolis. That's the extent of the "hard to get to" from Texas. Paul even lent me his truck. Remember, I flew there from Kerrville, Texas. We'll see how it goes going the other way, but I have a potential student in Chicago who wants some training in his new Acclaim, who offered to fly to Willmar when the plane is ready for pickup. Quote
mooneyflyfast Posted November 4, 2016 Report Posted November 4, 2016 (edited) 19 hours ago, donkaye said: That's the extent of the "hard to get to" from Texas. Glad it was so easy for you to get your plane there and back. By the way how much did it cost you to fly your plane the 2,600 n.m. there and back from Santa Clara?. It's only 2,000 from San Antonio. And the round trip airfare from San Jose to Minneapolis?. How many nights hotel and how much for meals?. Do you place any value on your time? Edited November 4, 2016 by mooneyflyfast Quote
LANCECASPER Posted November 4, 2016 Report Posted November 4, 2016 1 hour ago, mooneyflyfast said: Glad it was so easy for you to get your plane there and back. By the way how much did it cost you to fly your plane the 2,600 n.m. there and back from Santa Clara?. It's only 2,000 from San Antonio. And the round trip airfare from San Jose to Minneapolis?. How many nights hotel and how much for meals?. Do you place any value on your time? Kerrville to Wilmar is 927 nm direct. Wilmar to San Jose is 1288 mm direct. Thank goodness for airline miles and hotel points. Quote
donkaye, MCFI Posted November 4, 2016 Report Posted November 4, 2016 1 hour ago, mooneyflyfast said: Glad it was so easy for you to get your plane there and back. By the way how much did it cost you to fly your plane the 2,600 n.m. there and back from Santa Clara?. It's only 2,000 from San Antonio. And the round trip airfare from San Jose to Minneapolis?. How many nights hotel and how much for meals?. Do you place any value on your time? There were significant reasons that I chose not to go with Houston Tank Specialists not the least of which was a significant price difference, more than all the expenses of going to Minnesota. I got 3 bids before I decided to go with Weep no More. The extra flying that I did was from Kerrville to Willmar, about 900 nm. The distance from BDH and the Houston airport to SJC is about the same. We had a great time in Minneapolis, spending several days at the Mall of America. I still need to pick up the plane in a couple of weeks. Quote
Ron McBride Posted November 4, 2016 Report Posted November 4, 2016 I took mine last year to Troutdale Oregon. It is about 3 1/2 hours from home in Central Cal. Dealing with ice when I flew, priceless??? Airline flights were short, Fresno is about an hour from home. It was still a day of moving the plane each way. Houston and Wilmar would be a long day and then the airlines for a second day for me. Don Kaye has many major airports not to far to make it easier also. As Don said, check the prices of several shops, figure in all of the expenses and choose the best for your situation. Ron Quote
mooneyflyfast Posted November 4, 2016 Report Posted November 4, 2016 I don't care where anyone gets theit tanks sealed. My only disagreement was with Don's contradiction of my statement about it being hard to get a plane up there and back. I have done it and it is expensive and time consuming. Quote
kj2016 Posted November 4, 2016 Report Posted November 4, 2016 weep no more and you get a life long warranty. They are the best guys in the business of sealing tanks on Mooney. Don't show up to LASAR in Northern California. Quote
cnoe Posted November 4, 2016 Report Posted November 4, 2016 1 hour ago, kj2016 said: weep no more and you get a life long warranty. They are the best guys in the business of sealing tanks on Mooney. Not to be contrary (in fact Weep No More sealed the tanks in my J) but your post said "life long warranty". If their warranty terms have changed I'd love to hear about it. Quote
cnoe Posted November 4, 2016 Report Posted November 4, 2016 7 hours ago, N803RM said: As Don said, check the prices of several shops, figure in all of the expenses and choose the best for your situation. And don't discount the time and expense of returning the plane for warranty service if/when issues arise after a reseal job. I don't believe these costs are covered under anybody's warranty. Quote
carusoam Posted November 5, 2016 Report Posted November 5, 2016 There are some cases where it makes sense to send a mechanic from the supplier to where the plane is for warranty work. Other times the warranty work has been done by a trusted resource near the plane. A simple dab of sealant to reseal a single rivet is often part of the warranty service. No need to fly th plane a couple of thousand miles for that... The usual warenties are something like five or six years. Which at one time seemed like a lifetime. Now, six years goes by in a flash... Best regards, -a- Quote
AndyFromCB Posted November 5, 2016 Report Posted November 5, 2016 1 hour ago, carusoam said: There are some cases where it makes sense to send a mechanic from the supplier to where the plane is for warranty work. Other times the warranty work has been done by a trusted resource near the plane. A simple dab of sealant to reseal a single rivet is often part of the warranty service. No need to fly th plane a couple of thousand miles for that... The usual warenties are something like five or six years. Which at one time seemed like a lifetime. Now, six years goes by in a flash... Best regards, -a- Anthony, What the hell is it with getting old? Where the hell did 2016 go? What did I accomplish? I'm glad I'm not the only one that noticed that. Quote
ohdub Posted November 5, 2016 Report Posted November 5, 2016 As for getting between MSP and BDH - should you choose Weep No More - for $100, Paul's partner Eric will fly to FCM and use a courtesy car to drive to MSP to pick you up/drop you off. It all went very smoothly for me. I would highly recommend Weep No More. Quote
peevee Posted November 5, 2016 Report Posted November 5, 2016 Once they start work how long does Weep no more take? 2 weeks? More? Quote
donkaye, MCFI Posted November 5, 2016 Report Posted November 5, 2016 9 hours ago, peevee said: Once they start work how long does Weep no more take? 2 weeks? More? With their stripping machine, which I saw and is quite interesting, Paul said the actual job should take 2 weeks with a third week having the airplane sit with fuel to check for leaks. In talking to him yesterday, my plane seems to be on schedule for that time frame. Quote
