Yetti Posted December 4, 2017 Report Posted December 4, 2017 WD 40 has gone to $6.00 a can. Goop hand cleaner is still $2.00 a tub. Rub on and wipe off. Quote
Andy95W Posted December 4, 2017 Report Posted December 4, 2017 And Mineral Spirits is about $4/gallon, and you can spray down your engine with it. But it doesn't smell nearly as nice. Quote
jaylw314 Posted December 5, 2017 Report Posted December 5, 2017 On 12/3/2017 at 5:58 PM, jonhop said: +1 for WD-40 on the underside and gear wells. Then I use a light squirt of dish-washing soap and water and go to town on the upper-sides. I follow that up with wax. I keep bugs off the leading edges and cowl with liberal use of pledge after each flight. They normally wipe off because there is nothing to adhere to... In car detailing, they discourage the use of dish washing soap, claiming it's more acidic, and that it should only be used to strip a wax coat. I have no idea if that is BS or not Quote
mooniac15u Posted December 5, 2017 Report Posted December 5, 2017 11 minutes ago, jaylw314 said: In car detailing, they discourage the use of dish washing soap, claiming it's more acidic, and that it should only be used to strip a wax coat. I have no idea if that is BS or not Dish soap is slightly basic. Quote
jaylw314 Posted December 5, 2017 Report Posted December 5, 2017 12 minutes ago, mooniac15u said: Dish soap is slightly basic. Maybe they meant "less basic". They might have been chemically challenged Quote
EricJ Posted December 5, 2017 Report Posted December 5, 2017 Of the dish soaps, Dawn is particularly mild. It is used for things like cleaning up animals after oil or chemical spills, etc. I've seen it recommended in a number of places for washing airplanes. Also, what's wrong with the aviation extreme simple green? That's been recommended many times as well. Quote
jetdriven Posted December 5, 2017 Report Posted December 5, 2017 it ruined out paint by drying it out, it soon began alligatoring then outright peeling off everywhere. Took about a year. It dries out the plasticizers in the paint. with a Ph of 11, it gets into lap seams and corrodes aluminum. My first hint was when I was washing the belly and some of it ran down my shirt onto my armpit. The intense burning and the rash for a few days afterward should have make me investigate further. But anyways, a new paint job made it alright. This stuff gets loose in the wheel wells it flows into the laminated spar. Then you have a situation a few years later like we have started seeing, corroded spars under the sealer. http://simplegreen.com/downloads/SDS_EN-US_SimpleGreenExtremeAircraftPrecisionCleaner.pdf Quote
TravelVeteran Posted November 2, 2020 Report Posted November 2, 2020 This is what my wheel wells look like. I was planning to take some wd40 specialist degreaser, spray it’s all up in there, then use a high pressure sprayer to blast it all clean to remove all the grime and peeling paint, followed by greasing all the grease points in the landing gear with an A&P after a few days. Thoughts? Quote
larrynimmo Posted November 2, 2020 Report Posted November 2, 2020 I spend one minute cleaning my front belly after every flight and I take about 20 minutes cleaning the entire bottom fuselage about every 12 hours. Just use the light blue aircraft wash/wax. an ounce of prevention is better than a pound of cure 2 Quote
GeeBee Posted November 2, 2020 Report Posted November 2, 2020 I recently switched from Simple Green Aircraft to "Carbon-X". I must say it is highly effective for bellies and wells. https://www.aircraftspruce.com/catalog/cspages/chemcokleenjet.php?clickkey=13813 Quote
PT20J Posted November 2, 2020 Report Posted November 2, 2020 +1 for Carbon-X. Really gets off exhaust residue as well as a good degreaser and can be mixed to whatever strength you need. Quote
DanM20C Posted November 2, 2020 Report Posted November 2, 2020 52 minutes ago, PT20J said: +1 for Carbon-X. Really gets off exhaust residue as well as a good degreaser and can be mixed to whatever strength you need. I have been using Mach 1 with good results. I see Carbon-X is from the same company. It's nearing time for me to order another jug, anyone know if there is a benefit to Carbon-X over Mach 1? Cheers, Dan Quote
PT20J Posted November 2, 2020 Report Posted November 2, 2020 7 minutes ago, DanM20C said: I have been using Mach 1 with good results. I see Carbon-X is from the same company. It's nearing time for me to order another jug, anyone know if there is a benefit to Carbon-X over Mach 1? Cheers, Dan I’ve never used Mach 1, so I looked it up on Arrow Magnolia’s website and it’s listed as out of stock and unavailable and the TDS has been removed, so perhaps it is discontinued. Skip Quote
DanM20C Posted November 2, 2020 Report Posted November 2, 2020 5 minutes ago, PT20J said: I’ve never used Mach 1, so I looked it up on Arrow Magnolia’s website and it’s listed as out of stock and unavailable and the TDS has been removed, so perhaps it is discontinued. Skip Spruce still lists it in stock and has the msds there. But Spruce doesn't provide the msds for Carbon X and I can't find it on thee Arrow Magnoilia's website so I can't compare. Not that it really maters, I like Mach 1 but it sounds like Carbon X is as good or better based on the reviews. I'll give it a shot. Cheers, Dan Quote
MikeOH Posted November 3, 2020 Report Posted November 3, 2020 I've been perfectly happy with blue Wash-Wax-All. I do clean regularly, so the crud doesn't get 'baked on.' Quote
Ragsf15e Posted November 3, 2020 Report Posted November 3, 2020 15 hours ago, MikeOH said: I've been perfectly happy with blue Wash-Wax-All. I do clean regularly, so the crud doesn't get 'baked on.' Try the red wash wax all under the airplane and you’ll be really happy. It definitely gets off exhaust and oil better than the blue. I always go blue on top, red on bottom. 1 Quote
Hank Posted November 3, 2020 Report Posted November 3, 2020 36 minutes ago, Ragsf15e said: Try the red wash wax all under the airplane and you’ll be really happy. It definitely gets off exhaust and oil better than the blue. I always go blue on top, red on bottom. That's what I do, too. Washing the one piece belly at annual takes about 4 minutes, with it leaning against the wall. 1 Quote
Ragsf15e Posted November 3, 2020 Report Posted November 3, 2020 3 minutes ago, Hank said: That's what I do, too. Washing the one piece belly at annual takes about 4 minutes, with it leaning against the wall. One more reason I wish i had the one piece. That and the million screws. However, my ‘68 has survived without a gear incident all these years. I hope to keep that going even if it’s a little more work to clean and remove. 1 Quote
MikeOH Posted November 4, 2020 Report Posted November 4, 2020 4 hours ago, Ragsf15e said: One more reason I wish i had the one piece. That and the million screws. However, my ‘68 has survived without a gear incident all these years. I hope to keep that going even if it’s a little more work to clean and remove. LOL! Well, I'm glad some other guy screwed up 30 years ago....and I reap the benefit of the one piece belly 1 Quote
Hank Posted November 4, 2020 Report Posted November 4, 2020 2 minutes ago, MikeOH said: LOL! Well, I'm glad some other guy screwed up 30 years ago....and I reap the benefit of the one piece belly Mine was in '03, well before my purchase too. But ain't it nice? Quote
Ragsf15e Posted November 4, 2020 Report Posted November 4, 2020 9 minutes ago, MikeOH said: LOL! Well, I'm glad some other guy screwed up 30 years ago....and I reap the benefit of the one piece belly 6 minutes ago, Hank said: Mine was in '03, well before my purchase too. But ain't it nice? You guys still have a step? Some of the one piece belly airplanes are “much” faster due to not replacing the step either... Quote
MikeOH Posted November 4, 2020 Report Posted November 4, 2020 Just now, Ragsf15e said: You guys still have a step? Some of the one piece belly airplanes are “much” faster due to not replacing the step either... Funny, hah, hah, hah! Mine's still scratched up on the bottom, but works fine Quote
Yetti Posted November 4, 2020 Report Posted November 4, 2020 On 11/1/2020 at 10:40 PM, TravelVeteran said: This is what my wheel wells look like. I was planning to take some wd40 specialist degreaser, spray it’s all up in there, then use a high pressure sprayer to blast it all clean to remove all the grime and peeling paint, followed by greasing all the grease points in the landing gear with an A&P after a few days. Thoughts? Nope. You are going to blow out all the duct tape that you should replace with aluminum tape and then be cold all winter. There is duct tape that seals the cabin from the outside. Besides it is free anti corrosion layer. Quote
Hank Posted November 4, 2020 Report Posted November 4, 2020 32 minutes ago, Ragsf15e said: You guys still have a step? Some of the one piece belly airplanes are “much” faster due to not replacing the step either... I just redid my wing walk and step, but didn't think to check the underside. 1 Quote
jetdriven Posted November 4, 2020 Report Posted November 4, 2020 PTI-2000 degreaser really cleans the belly Quote
