5 hours ago, Steve Dawson said:
Don, Why the Shadin fuel flow gauge when you also have the EVP?
For a couple of reasons. First, you can get to several functions more quickly with the Shadin knob. Secondly, the one problem with the MVP-50 is that it only gives "fuel to waypoint" with no option for "fuel to destination".  The Shading can be set up for "fuel to destination".  Third, for redundancy.  I do have other redundancy with that information on both the GTN 750 and GTN 650, but that also involves a lot more tapping.
Like Don's plane mine also has two fuel flow computers.  Fuel level and flow rate are important enough to deserve redundant systems.
At Boeing that is known as "belt and suspenders" engineering.
Two fuel computers driven by a single tranducer is still a single fuel system.
My redundancy is related to information and quick access to it, not systems.  Some would say having a second (GTN 650), third (Aera 796), or even fourth (iPad) GPS is way over the top, but different information can be presented on each, so they all serve each other well.
Is that 2 sensors or 2 instruments sharing one sensor? I think I could go for 2 sensors.
I also have two fuel instruments with fuel information, Shadin Mini-flow L and the JPI 930.  The thought when I did it was that the Shadin information is constantly visible and you do not have to do any button pushing to find it.  Both are off one sensor.
John Breda
John Breda
John, the fuel flow is constantly visible on my 930.?
But I would not mind having a second sensor.
  • 2 weeks later...
But as Don has pointed out, fuel to destination and similar data has to be searched for in the JPI.  Better to have a dedicated instrument for information as important as fuel management.  Also as Don points out, different information can be displayed on different screens keeping the data more readily available and thus minimizing distractions which lead to errors.
John Breda
I'm late to the party, but recently did some modest panel work on my '68 G.  Went from /U to /G with perks.  Installed a 430W, GMA-340 audio panel, and 4-place intercom.  Now I've got a highly-capable IFR platform with headsets for everyone and a music input for the pax on those long XC flights.  I kept all the factory steam gauges and the vintage-style layout with wood grain panel cover.  Not an A&P so I had to pay for the parts and labor, which ran me about 15.5 AMU.
Advantages: I have a modern IFR navigation system highly capable in today's environment and a much more comfortable aircraft for my pax.
Disadvantages: Still using vacuum gyros with no backup pump, no AoA, no engine monitor, no "J-style" panel.  To me these are still nice-to-haves, but not required.
16 minutes ago, CaptainAB said:
I only dream of a g1000 gfc700. Anything less ranges from reality to a nightmare
While i like the G1000/GFC 700, I wouldn't own an airplane with one after seeing what has happened to those Mooneys with the G1000.   The airplane is certified with a specific type of G1000 and can only be updated by the manufacturer, not Garmin.  So, if the manufacturer chooses not to do any upgrades like Mooney and Beech, you are left with an out of date and vastly depreciated airplane.
The latest model Mooney doesn't have the avionics capability of even my airplane.
I will need to look under my cowling to verify the plumbing. When I had the JPI 830, fuel flow was shared by the EI FP-5L and the JPI 830. The EI had it's own fuel pressure sensor and I had the fuel line mechanical fuel pressure gauge. When I installed the JPI 900, I know my mechanic spent considerable time setting up my system so that fuel pressure is obtained by two sensors. We also talked about splitting the fuel flow and I don't recall if we did that at the same time. Usually it is just shared between units. I do see differences in pressures (not much) and I think the fuel flow would be different if the k factors are set differently for each unit.
Several months ago I was seeing erratic FF. The totalizator was off as well. It turned out that the sensor was not the problem but there was a tiny leak @ the fuel selector which was sucking a little air around the selector shaft. I suppose a 2nd, independent, FF sensor would have saved some trouble shooting time. If both sensors were showing the some problem we'd have ruled out the sensor. (JPI tech support pointed us to the selector valve.)
ISTM a second display of the same info is much less useful.
Bob, how long did this take to troubleshoot?  Sounds like it could have been really difficult.  Just curious.
Kris, I sent flight data to JPI. Tech support apprently had seen this before and suggested the problem might be sucking air at the fuel selector shaft. He had me put a couple of drops of motor oil on the shaft. That worked to "fix" the problem so we serviced the whole mechanism during the annual which was a few weeks later.
Very interesting. Thanks for sharing.
Air bubbles in the line are probably going to cause similar data challenges with two sensors. Unless the two sensors vary by design.
There are two things to consider possibly....
1) The air bubbles occupy volume and get counted as fuel as they pass through...
2) An air bubble can get caught in the sensor and get counted over and over. Proper mounting of the sensor, usually mitigates this challenge.
Bob's oil drop experiment worked successfully.   If it didn't, pulling a few FIs and running fuel into jars may be required to see if any air is getting in the line....
PP ideas, not a mechanic...
That's super good news.  Glad the JPI tech was so good.  I feel a little bad about taking my JPI out (going in for an EI upgrade within the week).  Thanks!
Which JPI are you removing?
  • 1 month later...
OK guys, just got her back from the shop!  Sorry, couldn't find room for the 8 track!  Here is what she looks like:
Edited by Discus
Looks good!
Did you have to keep the ASI and Altimeter as a backup with the Aspen and G5?
Awesome panel - congrats!  Are you using the G5 as the IFR backup AI for your Aspen PFD? There was recent discussion on an adjacent thread on whether or not the G5 can back up the Aspen legally.  My avionics guy said nope - yours obviously  thinks otherwise - I'm curious to know anything you might have heard on this.
I asked the same question. He said it was totally legal, and showed me the paperwork backing it up. Removed my vacuum system completely. Good riddance!
KPAUL, yes, the altimeter and ASI had to stay. Also, couldn't switch the Aspen to Knots since the manual is written in MPH. :-(
