For a while after i land and when it is hot I smell fuel in the cockpit nothing major, but I have not been able to figure out where it comes from. I checked the most obvious places for stains, but nothing. The fuel selector valve is fine, under the carpets nothings... any suggestions???
I think the fuel sender access behind the trim on the side wall below the door and in the same position on the pilot side is most likely.
But if you do not smell it when you first open the door before startup I would not suspect that's it since those units are below the "water line". The other possibility if you have the older fuel pressure gauge is that there a leak on the back of the gauge or at the firewall. If that's the culprit it probably only leaks while the engine/fuel pump is running and pressurizing that line which is above the "water line". Look under the panel for signs, maybe while running the boost pump but it might be just a pin hole. When I redid my interior I found the insulation in that area stained with oil, hydraulic, maybe fuel. Glad the new EDM gets oil and fuel lines out of the cabin!
My suggestion would be the fuel pressure gauge. Both oil and fuel are "in the cockpit" and although the system was absolutely fine for four decades, after that the envelope is being pushed. I'd recommend getting those lines out of the cockpit, even if it doesn't prove to be the problem. Of course, I am assuming you still have the original analog gauges.
I saw a post once where a guy was flying and said that his wife felt something dripping on her leg that turned out to be fuel. Yikes :o
I have a fuel smell in the cockpit also and it pisses me off. I am taking it to Edison at wetwingologists in February to get that solved. If it's not the tanks I'll have him fix the tanks plus whatever else it is.
65c, fuel sender gaskets leaked enough to soak the back carpets where the kids sat....
Removed side panels to see lots of dark blue goo...
Original gaskets are cork and can stand replacement.
Our fuel sender gasket needed to be replaced, but the smell occurred only in cold weather.
My tanks leaked very little in summer, but when winter hit WV they really opened up. Four years on my reseal now, and doing well except for some wear on the wing walk that I need to patch up (quarter-sized spot).
Cold seems to have that effect.
I had always smelled old fuel in my 64 C until I pulled the panels for the upholstery upgrading.  Both sending units had a slight seep.  Simple to fix with new gaskets once you have pulled the side panels.
Don
  • 1 year later...
Does anyone know a part number for the fuel transmitter gasket and screws. Spruce is not very helpful unless a number is provided.
Sent from my SM-T330NU using Tapatalk
Paul Beck of Weep no More, LLC should be able to fix you up. Give him a ring Monday, most likely he will have them ready to send.
Thanks mike. I will give that a try.
Or, if all else fails, call DMax or any other MSC.
I have spent a lot of time and money on this issue and I still have fuel smell in the cockpit. It is there when I open the door and its there after I land. Both of my fuel senders were rebuilt a year ago and have new rubber gaskets. I had all the side panels off during the last annual and I did not detect leaks/seeps. At this point, I'm choosing to simply live with it because I have no way to determine where it's coming from.
4 hours ago, Raptor05121 said:
Your IA can simply cut some cork out in the same shape. I can't seem to find any online
Cork with 100% silicone slightly applied works real good.
You might try removing the wing inspection panels that are under the wings, about mid tank, in front of the tank and take a look. It can leak there in front of the tank and then travel towards the cockpit.
100 LL disolves silicone, gasket cement is normally not required. If you need something use Permatex gasket cement on cork.
I had a heck of a time getting mine to stop leaking. Got everything squeaky clean, new gaskets, new screws, new insulators, still leaked. I finally coated the gasket with tank sealant and that fixed it.
3 hours ago, Yetti said:
There was an RV builder and his granddaughter taken out by thinking Silicone was good around 100LL
That was RVT and it was heavily applied to the threads of a fuel line.  I put 100% silicone to the cork with with my fingers with absolutely no excess.  When I need to replace the gasket the cork never sticks.
  • 3 weeks later...
