211º Posted July 26, 2022 Report Posted July 26, 2022 Just realized on a flight today, that I could do a panorama. 4
Hank Posted July 26, 2022 Report Posted July 26, 2022 3 minutes ago, 211º said: Just realized on a flight today, that I could do a panorama. Haven't thought to try that, but your weather looks just like what we've been having here in Sweet Home the past couple or three weeks . . . . .
211º Posted July 26, 2022 Report Posted July 26, 2022 14 hours ago, Hank said: Haven't thought to try that, but your weather looks just like what we've been having here in Sweet Home the past couple or three weeks . . . . . Yes! I was down there is some of that soup a few weeks ago. The difference in temps between 3,000 feet and on the ground - Wow. You'd think that thickness of the air there would halt all arguments around whether or not a Mooney can be on-step. There definitely is a step to be on in that soup.
211º Posted August 10, 2022 Report Posted August 10, 2022 A smoooooth flight when past central Indiana's bumps and buildups. It was an IFR flight when it seemed like no one was flying. "Center, 61Q has a strange request - I'd like to do three 120º right hand turns." "Approved as requested. Advise when back on course. Why are you doing that?" 2
Hank Posted August 10, 2022 Report Posted August 10, 2022 24 minutes ago, 211º said: A smoooooth flight when past central Indiana's bumps and buildups. It was an IFR flight when it seemed like no one was flying. "Center, 61Q has a strange request - I'd like to do three 120º right hand turns." "Approved as requested. Advise when back on course. Why are you doing that?" So 3 minutes on each leg? Or was 2 minutes each enough for everything to stabilize? "Uh, I need to collect some data . . . . . "
0TreeLemur Posted August 10, 2022 Author Report Posted August 10, 2022 2 hours ago, 211º said: A smoooooth flight when past central Indiana's bumps and buildups. It was an IFR flight when it seemed like no one was flying. "Center, 61Q has a strange request - I'd like to do three 120º right hand turns." "Approved as requested. Advise when back on course. Why are you doing that?" Cool. Were you in IMC?
211º Posted August 10, 2022 Report Posted August 10, 2022 6 hours ago, 0TreeLemur said: Cool. Were you in IMC? Ha! Nope. Severe clear. 1
211º Posted August 10, 2022 Report Posted August 10, 2022 8 hours ago, Hank said: "Uh, I need to collect some data . I did it twice on the flight - one LOP, one ROP. The KC Center was more interested and asked question. Hulman Approach was more “Whatever.”
Ragsf15e Posted August 10, 2022 Report Posted August 10, 2022 10 hours ago, 211º said: I did it twice on the flight - one LOP, one ROP. The KC Center was more interested and asked question. Hulman Approach was more “Whatever.” Nice speed check! What did you come up with?
211º Posted August 11, 2022 Report Posted August 11, 2022 3 hours ago, Ragsf15e said: Nice speed check! What did you come up with? Well, the two short answers are "well, I don't know for sure" and "should I accidentally let people think that its knots and not mph?" LOP was 155 mph and ROP was 161 mph... But I'm not sure that I can just sum the three 120° headings and divide by three - the idea came to me on the long flight, but afterward, I looked up on line and realized that the standard is 3 legs 90º apart. I need to do some geometry and component angle thinking to see if my version has merit. I'm also not sure that I gave it enough time to settle-in. I wasn't in a hurry per se, but I didn't want to be annoying to ATC. 1
211º Posted August 11, 2022 Report Posted August 11, 2022 And while it isn't art... it was kind of fun to have that track on flight aware.
Ragsf15e Posted August 11, 2022 Report Posted August 11, 2022 8 minutes ago, 211º said: Well, the two short answers are "well, I don't know for sure" and "should I accidentally let people think that its knots and not mph?" LOP was 155 mph and ROP was 161 mph... But I'm not sure that I can just sum the three 120° headings and divide by three - the idea came to me on the long flight, but afterward, I looked up on line and realized that the standard is 3 legs 90º apart. I need to do some geometry and component angle thinking to see if my version has merit. I'm also not sure that I gave it enough time to settle-in. I wasn't in a hurry per se, but I didn't want to be annoying to ATC. Well shoot. Both of the calcs I’ve used required 90 degree heading changes. I’m sure you can do it if you’re a real good vector mathologist. No you can’t just average those 3 runs. You’ll have a little extra from the xwind vector that won’t be canceled (hw/tw will cancel but the x wind component doesn’t). It will be close. You noted the gps groundspeed on each leg, correct? If you ever want to try the 90 degree one, here’s a calc for it. https://www.eaa62.org/technotes/speed.htm the gap between ROP and LOP is similar to mine. How high were you and what power setting?
David Lloyd Posted August 11, 2022 Report Posted August 11, 2022 Using three cardinal headings, three 90* apart, four headings, three or four tracks as opposed to headings; on a day with light winds, all methods will be within a knot or two.
carusoam Posted August 12, 2022 Report Posted August 12, 2022 There is easy math…. And things that work with a spreadsheet…. Or calculator… or app… I think @jetdriven has pointed out the speed calculations before… (average speed calculation to eliminate wind error) Best regards, -a-
Ragsf15e Posted August 13, 2022 Report Posted August 13, 2022 Not the Mooney wing, but this is IFR past Mt Rainier! 10,000’ vs a big Mtn! Mt Adams and Mt Hood in the far distance left side. 3
carusoam Posted August 13, 2022 Report Posted August 13, 2022 Earth pimples…. What wing is it? Interesting fuel cap location, out closer to the end…. In front of the airleron. VGs adjusting the airflow mostly around the more sensitive flight control surfaces. Best regards, -a-
Ragsf15e Posted August 13, 2022 Report Posted August 13, 2022 7 minutes ago, carusoam said: Earth pimples…. What wing is it? Interesting fuel cap location, out closer to the end…. Best regards, -a- PA46T. Gotta have the fuel caps out that far to fit 85 gallons in each wing. Going that way in the Mooney in a couple weeks, I’ll get a new picture with a prettier wing. 1
toto Posted August 14, 2022 Report Posted August 14, 2022 Flew five groups of Young Eagles this morning. About half of the kids had never been in an aircraft of any kind before today. If you haven’t done this, it’s a really great and rewarding experience - and it feels like a chance to influence the future of general aviation in a small way. https://youngeaglesday.org/ 1 1
Ragsf15e Posted August 14, 2022 Report Posted August 14, 2022 Got a better shot today… left to right, Adams, Rainier, St Helens… 4
MikeOH Posted August 14, 2022 Report Posted August 14, 2022 1 hour ago, Ragsf15e said: Got a better shot today… left to right, Adams, Rainier, St Helens… Yeah, but you promised a prettier wing! 2
ilovecornfields Posted August 20, 2022 Report Posted August 20, 2022 Little Dude started taking lessons again in the Mighty 172. His instructor said he did pretty well for not logging any time in the last two years. Now that he’s 12 he has to fly AND make all the radio calls. Growing up is tough! 4
Sue Bon Posted August 24, 2022 Report Posted August 24, 2022 Hello from Gibraltar! I can't believe this all worked out. In Swiss German this was what's called a Mwurks - like trying to fit a square peg in a round hole through asking, begging, coercing, forcing... I got so lucky! Of the five available parking spots, EasyJet and British Airways are taking four. At the very last minute (one hour before arrival from an airport one hour away) they let me have the fifth and then said, "Well, your plane is so small. If we have to, we can just move it somewhere." 10
Fly Boomer Posted August 24, 2022 Report Posted August 24, 2022 26 minutes ago, Sue Bon said: Gibraltar Gorgeous! 1
carusoam Posted August 25, 2022 Report Posted August 25, 2022 Sue’s M20J in front of THE Rock… I sent the pic to Mooney’s Mooney of the Month contest… One day… they may actually update it from its current Mooney of the decade contest… Best regards, -a- 1 1
