cliffy Posted August 7, 2021 Report Posted August 7, 2021 What borescopes for cylinder inspection does everyone use and where to get them? We need a list here for everyone. Quote
Danb Posted August 7, 2021 Report Posted August 7, 2021 Vividia scope 980 learning how to use and interpret the findings. The pictures are great, they have solid,flexible and semi flexible. Quote
flyingchump Posted August 7, 2021 Report Posted August 7, 2021 I have used a cheapo borescope form amazon for all sorts of stuff. Its not the greatest for the cylinders as mine cant do a tight 180degree bend but it works great for many of the areas you need to see but may not have the contortionist skills needed. https://www.amazon.com/gp/product/B01MYTHWK4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Quote
Rick Junkin Posted August 7, 2021 Report Posted August 7, 2021 (edited) Vividia VA-400 recommended by Mike Busch early on. The scope connects by USB to a computer or if you're using an Android device you can connect directly to your phone or tablet, but you can't connect directly to an Apple device. I suggest getting the package with the battery powered wifi box so you can use it with your iPhone or iPad, and it will also work with Android devices and eliminate the cord management issues between the borescope and your display device. You will need an external battery - I use my iPad back-up battery. Here's the Amazon link for the wifi package: https://smile.amazon.com/VA-400-WiFi-Bundle-Ablescope-Articulating-Borescope/dp/B01MQPC6U1/ref=sr_1_3?crid=34WQ7TTPS9SD9&dchild=1&keywords=vividia+va-400&qid=1628342695&sprefix=vivid%2Caps%2C241&sr=8-3 Here's the link for just the borescope: https://smile.amazon.com/Vividia-Ablescope-VA-400-Borescope-Articulating/dp/B00GY7C9ZW/ref=sr_1_4?crid=34WQ7TTPS9SD9&dchild=1&keywords=vividia+va-400&qid=1628342695&sprefix=vivid%2Caps%2C241&sr=8-4 Cheers, Rick Edited August 7, 2021 by Junkman added image 3 Quote
carusoam Posted August 7, 2021 Report Posted August 7, 2021 Nice work Rick! +1 for the Smile.Amazon version of the link… -a- 1 Quote
EricJ Posted August 7, 2021 Report Posted August 7, 2021 The Vividia scopes seem to be the go-to brand these days for cylinder inspection. The rigid one is good and less expensive if that meets your needs. I got the semi-rigid one, which is also good for things like snaking up the exhaust to inspect the muffler. https://www.amazon.com/Vividia-VA-980-Semi-Flexible-Inspection-Articulating/dp/B072DS7LQN The $35 cheapies can be good, too, and I have several of those that are handy for various things because the cables are longer and more flexible. They're good for things like reading serial numbers off the back of installed parts, behind the panel, down holes, inside wings, etc. 1 Quote
MikeOH Posted August 7, 2021 Report Posted August 7, 2021 Vividia VA-400 and have been very happy with it. I looked at the cheaper options, but came to my senses when I realized that anything under 1 AMU is CHEAP by aviation standards Quote
PT20J Posted August 7, 2021 Report Posted August 7, 2021 I too have a Vividia VA-400. I seem to get a lot glare from reflections off the cylinder walls that washes out some of the photos. The lens in clean. Any tips for getting clearer shots? Skip 1 Quote
Rick Junkin Posted August 7, 2021 Report Posted August 7, 2021 23 minutes ago, PT20J said: I too have a Vividia VA-400. I seem to get a lot glare from reflections off the cylinder walls that washes out some of the photos. The lens in clean. Any tips for getting clearer shots? Skip Skip, how long ago did you get your VA-400? I remember reading something talking about problems with the original lenses in the VA-400 and a change to a better lens but I couldn't easily find the reference I'm remembering. Your best bet is probably to reach out to the Vividia folks through their contact page http://www.vividia-tech.com/contact-us.html. I submitted a question and they responded within a day. I'm sure they've had this question before and will be able to steer you to a solution. Cheers, Rick 1 Quote
Davidv Posted August 7, 2021 Report Posted August 7, 2021 3 hours ago, MikeOH said: Vividia VA-400 and have been very happy with it. I looked at the cheaper options, but came to my senses when I realized that anything under 1 AMU is CHEAP by aviation standards For better or for worse, when you start comparing stuff like this to a tank of fuel or a cylinder replacement the credit card just sort of comes out of your pocket. 2 Quote
EricJ Posted August 7, 2021 Report Posted August 7, 2021 2 hours ago, PT20J said: I too have a Vividia VA-400. I seem to get a lot glare from reflections off the cylinder walls that washes out some of the photos. The lens in clean. Any tips for getting clearer shots? Skip For me that's usually fixed by adjusting the lamp brightness. Sometimes it takes a few iterations to get it figured out. 4 Quote
carusoam Posted August 7, 2021 Report Posted August 7, 2021 Taking pics of shiny metal can be one of the toughest challenges… Experiments with different light sources / angles may be helpful… PP guesses only, no real photographic experience… Best regards, -a- Quote
Will.iam Posted August 7, 2021 Report Posted August 7, 2021 I just talked to vividia at oshkosh and they finally bumped up their camera resolution as 640x480 was just too low for me to shell out. I think they said they are up to 1280x768. my elcheapo amazon borescope camera that has 1080p with focus at 1.2cm it’s just a pain trying to push the flexible cord into a way to get a good shot. Quote
EricJ Posted August 7, 2021 Report Posted August 7, 2021 46 minutes ago, Will.iam said: I just talked to vividia at oshkosh and they finally bumped up their camera resolution as 640x480 was just too low for me to shell out. I think they said they are up to 1280x768. my elcheapo amazon borescope camera that has 1080p with focus at 1.2cm it’s just a pain trying to push the flexible cord into a way to get a good shot. They've had higher resolution available for a while, it's just on much more expensive units. https://www.amazon.com/Articulating-Videoscope-Inspection-Waterproof-Technicians/dp/B08NFCM7J1 Quote
kortopates Posted August 7, 2021 Report Posted August 7, 2021 I commented about the recent increase in resolution in another thread - probably in the spring. Problem has been, since they didn't change the model no, there is no way to know whether your getting the newer one without ordering it direct from them. Other retailers still had the original resolution in stock. Be aware if your purchasing one.Sent from my iPhone using Tapatalk 3 Quote
DXB Posted August 8, 2021 Report Posted August 8, 2021 I have an older Vividia scope VA-400, and I agree the camera resolution could be a lot better. I also struggle with the fogging/glare issue, and reducing brightness helps but not entirely. I only got the vague sense of a burnt exhaust valve once with possibly a thin crescent at one end, but when the cylinder came off, the burning was unmistakable. I'm glad I didn't keep running it, but now I'm constantly alarmed by any vague hint of asymmetry. I'd be curious to know if these issues are fully resolved in their newer low cost scopes. I'd be willing to buy another one with better resolution for the peace of mind - what's another $250 in this precarious and intrinsically wallet draining hobby? Quote
carusoam Posted August 8, 2021 Report Posted August 8, 2021 Manufacturing sins 101…. Change the design without changing the part number… This is something lesser companies tend to do… Best regards, -a- 2 Quote
larrynimmo Posted October 7, 2021 Report Posted October 7, 2021 Here are some sample pics on the Amazon $300 borescope 1 Quote
carusoam Posted October 7, 2021 Report Posted October 7, 2021 Larry, You have the great pics today! From inside of mags to inside the cylinder… Fantastic cross-hatch pattern on the cylinder wall. nice even coloration on the exhaust valve. Even fantastic focus on the fine wire spark plug tip. Great pics! Thanks for sharing them. Best regards, -a- Quote
Greg Ellis Posted October 7, 2021 Report Posted October 7, 2021 Looking at the Vividia website, they have a nice chart comparing the different scopes they sell. I have copied it here. As you can see, the rigid scopes only have a resolution of 640X480. To get a higher resolution you have to go to a flexible scope which looks like to me would be difficult to use in a cylinder. The VA-980 may fit the bill though with higher resolution and a semi rigid probe which can be bent in pretty much any shape you need and holds the shape. Unfortunately it lists on Amazon from $380 to $460 depending on the seller. I have the VA-400W and it works ok. The resolution is kind of low. The other thing is to make sure to not use it in a cylinder that is the slightest bit warm. It can greatly affect the image as well as damage the scope (info direct from the manufacturer). Comparison of several Vividia Articulation Borescopes Videoscopes: Models VA-400 VA-400W Bundle VA-150 VA-450 ME-610 ME-610X VA-980 Output for Display USB to PC USB/WiFi to PC phone LCD, SD card LCD, WiFi, SD card LCD, HDMI, SD card USB to PC Probe (D x L) 8.5mm x 40cm 8.5mm x 40 cm 6mm x 1 m 5.5mm x 1 m 6mm x 1 m 8.5mm x 80cm Camera Resolution 640x480 640x480 640x480 1280x720 1280x720 1280x720* Focus Range 10mm to 100mm 10mm to 100mm 20mm to 50mm 10mm to 80mm 10mm to 80mm 10mm to 100mm Probe Articulation rigid, one-way rigid, one-way flexible, 2-way flexible, 2-way flexible, joystick 360 degree semi-rigid, moldable LCD Display NA NA 2.7 inch 4.5 inch 3.5 inch NA Windows 10/8/7/XP Compatible Yes Yes No No No Yes iPhone iPad compatible No Yes No No No No Android Systems Yes** Yes No Yes No Yes** * The new version of VA-980 has pixels of 1280x720. The previous version (before 2020) or earlier) has resolution of 640x480. ** For Android devices, phone or tablet, only some Android models are compatible. Some Android models are not compatible, due to either lacking OTG function or too much customization of the operation system. 1 Quote
Jetrn Posted October 7, 2021 Report Posted October 7, 2021 I ordered mine from mcfarlan, their bundle pricing was the cheapest. Quote
201Steve Posted October 8, 2021 Report Posted October 8, 2021 I’ve used both the rigid and flex version vividia. No question for Cylinders, the rigid shaft is way more stable to maneuver. Of course, the flex shaft has its’ advantages for other purposes noted above. 1 Quote
A64Pilot Posted October 8, 2021 Report Posted October 8, 2021 On 10/7/2021 at 7:56 AM, larrynimmo said: Here are some sample pics on the Amazon $300 borescope Link to that scope? If those pics add achievable by ordinary idiots like me, it’s plenty good. Quote
RoundTwo Posted June 8, 2023 Report Posted June 8, 2023 Bumping this thread back up. I’d like to get a scope and agree the rigid scope (VA-400] would be easiest to use for cylinders, but the semi-rigid one (VA-800) opens up other possibilities that won’t work for the rigid unit. Is the semi-rigid scope that much more difficult to control in a cylinder, to make it a poor choice? Could you zip tie it to a piece of TIG rod, or other suitable stiffener, to make it easier for cylinder work? Quote
EricJ Posted June 8, 2023 Report Posted June 8, 2023 26 minutes ago, RoundTwo said: Bumping this thread back up. I’d like to get a scope and agree the rigid scope (VA-400] would be easiest to use for cylinders, but the semi-rigid one (VA-800) opens up other possibilities that won’t work for the rigid unit. Is the semi-rigid scope that much more difficult to control in a cylinder, to make it a poor choice? Could you zip tie it to a piece of TIG rod, or other suitable stiffener, to make it easier for cylinder work? I have both, the semi-rigid in the original 640 resolution, and a rigid unit with the new high resolution. Both can be used for cylinders, but the rigid one is definitely easier to use in a cylinder. It's not an enormous difference, and if you're willing to put up with a little more complicated maneuvering with the semi-rigid unit, it works, too. It was all I had until I got the rigid one, and I got by okay. That said, the semi-rigid one can do things like go all the way up the exhaust into the muffler to inspect your fire tube, and the rigid one can't do that. So the semi-rigid wins on general utility, the rigid wins on ease-of-use for cylinder work. I'm glad I have both, but if I were going to pick only one for general use, I'd get the semi-rigid. If you plan to do mostly cylinders, I'd get the rigid and then maybe one of the cheapie endoscopes on Amazon for the occassional everything else. I have some of those, too, and sometimes they're the go-to device for getting into little crevices or into weird places. Since they're cheap it's easy to keep one or two of those around. 1 Quote
