2 minutes ago, Shadrach said:
I appreciate your experience and statistical analysis.  However, applying that analysis to a a 50+ year old airframe that has been owned by multiple individuals and maintained by dozens is an interesting exercise, it's far from a vintage Mooney's operational reality. It assumes the chances of a event with a double failure of a properly functioning system.  What is more typical with 50 year old airplanes is that a human has attempted to "repair" the system and fails to ensure every thing is properly seated during reassemble.  This may only result in a single failure as part of the "repair". There are certainly owners flying around with flaps that stay down but are sucking air or pushing fluid to ways through an unseated valve or are not properly bled or have had incorrect hardware substituted or...etc...  They live with sub-optimal performance until a second point of failure. The system then goes from functioning sub optimally to not functioning at all.  This chain of events sometimes starts with an non-Mooney specific IA spotting a few drops of hydraulic fluid on the belly and prescribing a pump overhaul.
I truly respect and appreciate your expertise in the field but applying it to vintage Mooneys is a bit like applying it to the Cuban taxi cab fleet.
In this situation, from speaking with the IA, its most likely from a previous A&P that attempted a repair. It sounds like they're in rough shape and weren't properly repaired or replaced in the past (the flap "auto-retraction" is very slow so it probably wasn't noticed in the past). The double point of failure makes sense if the previous mechanic used a rough tool for removing them both and scarred them beyond proper function in the past (just a guess as I'm not looking at them myself).
FWIW
Teflon will cold flow. If you set the damaged seal on a table with a ball in the seat and set a fairly heavy weight (5 lbs or so) on the ball, it would probably form a tight seal in a few days. You could verify using a microscope or a loup. Might not take that long.
  • Thanks 2
2 hours ago, N201MKTurbo said:
FWIW
Good advice.  I've never tried this.  I have also never met a Teflon seal that I could not get to seat. Some have frustratingly required multiple attempts.
Edited by Shadrach
My starting point was "it wasn't working and then it stopped" with no external influences like: someone jacking with it.  Even given that, it could be the the inlet starts leaking and nobody notices, then months/years later the outlet fails and that's how you practically end up with both of them failed at the same time.  This is the possibility I tried to raise at the end of my prior post but I maybe didn't explain it well.  Though I can't imagine these teflon seats deciding to leak with normal use.  They should be very robust.
I think the weak point in this pump is the elastic seals/o-rings.  Probably everything is fine until a seal wears-out or ages-out and leaks.  Then the rebuild process introduces risk of handling damage and debris...then new issues arise.  Surgery is risky...lol
The problem is many don't know what properly is. Anthony @carusoam believed for years that the first pump was to pressurize the system and the flaps didn't actuate until the second pump. This misconception and others have been often repeated and or mentioned because many of the systems (simple as they are) have not been properly installed, bled and adjusted. The new owner of an old Mooney does not know what he does not know...nor would an A&P that is not intimately familiar with vintage Mooneys. Functioning properly to many simply means the flaps go down when I pump and come up when I flip the return switch.  That's good enough to get by.  Really functioning properly means precisely 4 pumps from start to lock out, no slop in the system and 10-12 seconds to return to the up position.  I would bet there are many birds out there that do not meet the standards listed above.  As much as I like the system, I now understand why so many do not.
Edited by Shadrach
  • 3 years later...
Anyone got a line on where to get the Teflon HE1517 seals these days?
Send me a PM.
John Breda
I was contacted by a Mooneyspacer asking that I make him some teflon seals for the H&E Vintage Flap Pump.  I though I would let the group know that I plan on making these for one person.  If anyone wants and needs these, Please PM me.
John Breda
Thanks John.
The PM section says you are unable to receive messages.
I’ll take 4. Thanks for your contribution to the community.
-Matt
20 minutes ago, MB65E said:
Thanks John.
-Matt
It’s a you problem. I sent him a DM with no trouble.
Has anyone verified that the seats are the same for the pre-66 (?) birds?
On the early applications, the O-ring is positioned on the Teflon valve seat (a la the OP's).fdd585df3f4c63ee488acede398b14c9.jpg
On the later models, maybe 66 and later the o-rings are positioned in machined grooves on the opposing pump half.
On 5/12/2024 at 10:18 AM, MB65E said:
Thanks John.
-Matt
John Breda
I couldn’t DM you either, but it would be awesome if I could get in on this for 4 as well?  Thanks so much for building these!
Drew
I'm interested in purchasing the teflon seals also. I sent a msg a few days ago.
Thanks Glenn
  • 11 months later...
I'm currently looking for these seals as well. If anyone has a source or knows what dimensions would work for owner manufactured, please let me know.
Thanks!
Michael
