Skates97 Posted April 7, 2020 Report Share Posted April 7, 2020 11 minutes ago, hammdo said: Awesome work (I bought new hardware too)! So worth the effort -- way to go TEAM! Andersj and Sabremech fantastic job overall! Now, we know how we can do OPP for sure! -Don Part #'s and Qty? I know I could look it up, but trying the easy route first! 1 Quote Link to comment Share on other sites More sharing options...
Buckeyechuck Posted April 7, 2020 Report Share Posted April 7, 2020 5 hours ago, Jim Peace said: I just got a down block from LASAR....from phone call to in my hands just 2 days.....painless..... Did it include the locking mechanism? Do they have that available? My down lock block doesn’t have one. Quote Link to comment Share on other sites More sharing options...
hammdo Posted April 7, 2020 Author Report Share Posted April 7, 2020 10 minutes ago, Skates97 said: Part #'s and Qty? I know I could look it up, but trying the easy route first! Listed here: right from my manual aircraft spruce has them... -Don 1 Quote Link to comment Share on other sites More sharing options...
hammdo Posted April 7, 2020 Author Report Share Posted April 7, 2020 3 minutes ago, Buckeyechuck said: Did it include the locking mechanism? Do they have that available? My down lock block doesn’t have one. No, looks like an AN bolt they heated and manipulated to work. The original kit had them... may be able to locate one on eBay but, it’ll be expensive... -Don Quote Link to comment Share on other sites More sharing options...
Piotrekpdx Posted April 8, 2020 Report Share Posted April 8, 2020 Received mine today. Thank you very much!!! 1 Quote Link to comment Share on other sites More sharing options...
CWM20f Posted April 8, 2020 Report Share Posted April 8, 2020 Got mine in the mail today as well. Fantastic job. Thanks! Chuck 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted April 8, 2020 Report Share Posted April 8, 2020 For the down lock button... Consider using a used one from the regular sources... the locking bits probably won’t have the same wear challenge as the block itself does... @Alan Fox @Jerry Pressley Best regards, -a- Quote Link to comment Share on other sites More sharing options...
jwarren2 Posted April 8, 2020 Report Share Posted April 8, 2020 Got my uplock block today, looks awesome. Thank you guys for all your dedication to this project. 1 Quote Link to comment Share on other sites More sharing options...
Anders J Posted April 30, 2020 Report Share Posted April 30, 2020 On 4/1/2020 at 8:20 PM, Sabremech said: Orders getting boxed up with the paperwork. Shipping tomorrow! David Hi Guys, I unfortunately didn't need a set after my mishap, but I would love to see some pics of the blocks installed. It was so much fun to be a part of this community project. Thank you for letting me be a small part of it. AndersJ 3 Quote Link to comment Share on other sites More sharing options...
hammdo Posted May 1, 2020 Author Report Share Posted May 1, 2020 I'll have mine next week! Quote Link to comment Share on other sites More sharing options...
hammdo Posted May 8, 2020 Author Report Share Posted May 8, 2020 -Don 1 Quote Link to comment Share on other sites More sharing options...
Skates97 Posted May 12, 2020 Report Share Posted May 12, 2020 Thankful for all the effort that went into this and glad to have the new blocks for my plane. I replaced mine last week. I think the ones in the plane were the originals. The Up Lock was not in terrible shape. The Down Lock was a little egg shaped but had a good lip worn into it. The extra tiny bit that it moved locking forward in the new block changed the pre-load. Pre-loads were checked at the last annual and the mains were at the low end. After putting the new block in they were at the top end of the limits. The nose was pushed over the top limit so it had to be adjusted. In the process we found that the two tubes were not bearing the load evenly, the right tube was taking most of the pressure so we adjusted them to be balanced and put it back in limits. Up Lock Down Lock 2 Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted May 23, 2020 Report Share Posted May 23, 2020 1 hour ago, bluehighwayflyer said: Hey, guys. This thread seems as good a place as any to ask this question. Can anyone with experience in these things opine as to the condition of the down lock block in our ‘65C? The airframe is very low time but I have no idea how many hours are on it’s down lock block as we received it from Charlie Dugosh back in the mid 80s as part of a used parts kit when we converted our C back to manual from the electric gear that Charlie had installed in it for it’s original owner back in the 1960s. I can see some wear in the attached picture, but it doesn’t seem nearly as bad as some I have seen. How critical is my need for a new down lock block? Thank you! Jim Jim . From your photo and the angle of such, your block looks fine to me. Some wear on the outer edge from the bar head smashing into the block,!but the hole looks round to me. Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 23, 2020 Report Share Posted May 23, 2020 Showing the early signs of the ridge being cut in further down the hole... Far from the egg shape that will appear after a thousand more hours of ground operations.... PP thoughts only... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 23, 2020 Report Share Posted May 23, 2020 Jim, The perspective you are looking for... is in the first pic above your post... You will see the same ridge... but more of the hole has been worn away... making that ridge appear much larger... A lot of aluminum slowly wears away from the hole... Ultimately... enough aluminum gets worn... the ridge appears really large... and the hole looks egg shaped... all at the same time. When the J-bar shows signs that it doesn’t like to lock in place.... that is when it time to replace the block... Nice pic of the working end of the thumb lock, by the way...! -a- Quote Link to comment Share on other sites More sharing options...
dcrogers11 Posted May 23, 2020 Report Share Posted May 23, 2020 I'm late to the game, but will there be another run of block made in the future? Thanks, Don Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted May 23, 2020 Report Share Posted May 23, 2020 11 hours ago, bluehighwayflyer said: Excellent information. Thanks, Anthony. I can definitely see the difference you are referring to between mine and Richard’s OEM one above it. I try to be very gentle with it when I lock it into place. Thanks again, very much. This was just the information I was looking for. Such an ingenious mechanism. Jim Yes, gently. No slamming the bar into place. My technique......I do use some momentum during the process, but once the bar end gets near the blocks, I relax that. At that point, I gently push the bar into the block until it’s secure. We’ve discussed this previously........ I do use a twisting/rotating motion inserting/releasing the bar with the floor block. That seems to work well for me. Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted May 29, 2020 Report Share Posted May 29, 2020 has anyone had a issue of it being to difficult to get the gear in and out of the down block? I have a new LASAR block and its almost impossible to get it in and out...just flew it today for first time and not to happy.....how is it with your owner produced parts? Quote Link to comment Share on other sites More sharing options...
RLCarter Posted May 30, 2020 Report Share Posted May 30, 2020 10 minutes ago, Jim Peace said: has anyone had a issue of it being to difficult to get the gear in and out of the down block? I have a new LASAR block and its almost impossible to get it in and out...just flew it today for first time and not to happy.....how is it with your owner produced parts? Was the gear re-rigged after the block was replaced? Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted May 30, 2020 Report Share Posted May 30, 2020 41 minutes ago, RLCarter said: Was the gear re-rigged after the block was replaced? It went in during annual at a MSC,,,can only hope that it was done correctly...The bar moves just fine, it is just almost impossible to move in and out of the block....would that be an issue with it being rigged? Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted May 30, 2020 Report Share Posted May 30, 2020 37 minutes ago, RLCarter said: Was the gear re-rigged after the block was replaced? There is no rigging for the up position. The manual says to not rig it for up position. That being said, if the rigging is really screwed up, it could be jamming in the up position. I wouldn’t expect changing the up lock block would change the rigging in the slightest. One thing to consider is the Johnson bar is bent. I think most of y’all are fixing things that aren’t broke.... Give the new blocks a few hundred landings to break in and they should be smooth as silk... Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted May 30, 2020 Report Share Posted May 30, 2020 23 minutes ago, N201MKTurbo said: Give the new blocks a few hundred landings to break in and they should be smooth as silk... A few hundred landings? It took both of my hands to lock this in position today.....I dont want to do that anymore..... Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted May 30, 2020 Report Share Posted May 30, 2020 30 minutes ago, Jim Peace said: A few hundred landings? It took both of my hands to lock this in position today.....I dont want to do that anymore..... It won’t go into the unlock on the floor? Did it work when you tried it on jacks? Quote Link to comment Share on other sites More sharing options...
RLCarter Posted May 30, 2020 Report Share Posted May 30, 2020 57 minutes ago, N201MKTurbo said: There is no rigging for the up position. The manual says to not rig it for up position. That being said, if the rigging is really screwed up, it could be jamming in the up position. I wouldn’t expect changing the up lock block would change the rigging in the slightest. One thing to consider is the Johnson bar is bent. I think most of y’all are fixing things that aren’t broke.... Give the new blocks a few hundred landings to break in and they should be smooth as silk... But he replaced the “down block” which is where rigging starts Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted May 30, 2020 Report Share Posted May 30, 2020 34 minutes ago, Jim Peace said: A few hundred landings? It took both of my hands to lock this in position today.....I dont want to do that anymore..... I’m sorry, I thought we were talking about the up block. Yes, there a few things that will make that difficult. I just re-rigged one on Monday that was replaced. It was mis-rigged before the replacement. It is smooth as silk now. Quote Link to comment Share on other sites More sharing options...
