1ang Posted September 24, 2019 Report Posted September 24, 2019 He guys, first time owning an airplane, have a hanger and looking to stock it up. What are some of the essentials needed? Also have a hanger with skidding doors and a slight hill right in front of it. Do u think it will be easy to push it up and aver the “rails” solo by hand or will I need some alternative? Quote
Parker_Woodruff Posted September 24, 2019 Report Posted September 24, 2019 Engine oil and an air compressor for filling tires. 1 Quote
1ang Posted September 24, 2019 Author Report Posted September 24, 2019 Engine oil and an air compressor for filling tires. Any advice or resource on how to properly do engine oil filter safety wire? Quote
rbridges Posted September 24, 2019 Report Posted September 24, 2019 I have a large tow bar, and I can move my C model around pretty easy. I still have to have a little momentum to get them over the rails in front of the hangar. I don't know how much incline you have, but that could make it a lot harder, especially if you're using the standard size tow bar from the plane. 1 Quote
carusoam Posted September 24, 2019 Report Posted September 24, 2019 Getting your plane over the hump will depend on a few things... How full are the tanks, and how strong are your moccasins... Use the search to look up what MSers are using for powered tows... Get to know your mechanic... many things you can learn by working with those guys... Best regards, -a- 1 Quote
RLCarter Posted September 24, 2019 Report Posted September 24, 2019 Just now, 1ang said: Any advice or resource on how to properly do engine oil filter safety wire? Get with an A&P have him look over you shoulder 4 Quote
DonMuncy Posted September 24, 2019 Report Posted September 24, 2019 If you are having to move your plane by yourself, it gets a little tricky. If you would like my effort intensive technique, just ask. Quote
xavierde Posted September 24, 2019 Report Posted September 24, 2019 17 minutes ago, 1ang said: Also have a hanger with skidding doors and a slight hill right in front of it. Do u think it will be easy to push it up and aver the “rails” solo by hand or will I need some alternative? My hangar neighbor bought some rubber ramps for wheelchairs, that seems to work really well. Quote
BaldEagle Posted September 24, 2019 Report Posted September 24, 2019 51 minutes ago, 1ang said: Also have a hanger with skidding doors and a slight hill right in front of it. Do u think it will be easy to push it up and aver the “rails” solo by hand or will I need some alternative? I just got into a hangar after a rather long wait and hadn't considered this. I almost put my back out trying to get the thing into the hangar the first time. I was essentially grounded until I landed a good deal on a used Sidewinder from a forum member here. This was a very slight incline as well. I use the standard towbar to pull it out of the hangar and the Sidewinder to push it back in. A hangar neighbor uses the metal tow bar to position the airplane and a Harbor Freight winch to pull the last few feet into the hangar. That's probably the cheapest solution if you can bolt the winch down effectively. Other essential items to add to your list: sofa and kegerator (or mini fridge). Hangars make really good man caves... Quote
1ang Posted September 24, 2019 Author Report Posted September 24, 2019 I just got into a hangar after a rather long wait and hadn't considered this. I almost put my back out trying to get the thing into the hangar the first time. I was essentially grounded until I landed a good deal on a used Sidewinder from a forum member here. This was a very slight incline as well. I use the standard towbar to pull it out of the hangar and the Sidewinder to push it back in. A hangar neighbor uses the metal tow bar to position the airplane and a Harbor Freight winch to pull the last few feet into the hangar. That's probably the cheapest solution if you can bolt the winch down effectively. Other essential items to add to your list: sofa and kegerator (or mini fridge). Hangars make really good man caves... I was looking at the winch idea, power towbars are sooooo expensive. Quote
DonMuncy Posted September 24, 2019 Report Posted September 24, 2019 17 minutes ago, 1ang said: I was looking at the winch idea, power towbars are sooooo expensive. To a true CB, all power towbars are expensive, but they don't have to be that expensive. Take a look at mine on my album. 1 Quote
Guest Posted September 24, 2019 Report Posted September 24, 2019 2 hours ago, RLCarter said: Get with an A&P have him look over you shoulder Or just hire him/her to do it. They need to earn a living too. Clarence Quote
ArtVandelay Posted September 24, 2019 Report Posted September 24, 2019 Or just hire him/her to do it. They need to earn a living too. Clarence I do my own oil changes....trust me, he’s still earning a very good living.Tom 1 Quote
RLCarter Posted September 24, 2019 Report Posted September 24, 2019 11 minutes ago, M20Doc said: Or just hire him/her to do it. They need to earn a living too. Clarence As retired mechanic I agree 100%, my response was based on his statement below and by no means was I trying to push the A&P's out of the picture 2 hours ago, 1ang said: Any advice or resource on how to properly do engine oil filter safety wire? Quote
81X Posted September 25, 2019 Report Posted September 25, 2019 4 hours ago, 1ang said: He guys, first time owning an airplane, have a hanger and looking to stock it up. What are some of the essentials needed? Also have a hanger with skidding doors and a slight hill right in front of it. Do u think it will be easy to push it up and aver the “rails” solo by hand or will I need some alternative? First time owner, a Mooney and having a hangar, you have a very strong start, congratulations, you’re doing it right!! My hangar essentials are a fridge, old seating (couch or chairs), a grill and some choice beverages. Oil, cleaning supplies and some basic tools also help. I usually move my K model by hand, but I share a 4 airplane hangar and if the 340a is in front of me, an electric golf cart with front hitch and tow bar makes a nice setup, it just takes some practice to keep it within the steering tow limits. Quote
David_H Posted September 25, 2019 Report Posted September 25, 2019 A GOOD set of screwdrivers is helpful. Cheap screwdrivers and Mooneys do not go well together. 1 Quote
RLCarter Posted September 25, 2019 Report Posted September 25, 2019 1 hour ago, David_H said: A GOOD set of screwdrivers is helpful. Cheap screwdrivers and Mooneys do not go well together. Cheap screwdrivers dont go with anything 2 Quote
skydvrboy Posted September 25, 2019 Report Posted September 25, 2019 “He guys, first time owning an airplane,” Pictures, pictures, PICTURES!!! 2 Quote
1ang Posted September 25, 2019 Author Report Posted September 25, 2019 “He guys, first time owning an airplane,” Pictures, pictures, PICTURES!!! Soon gonna go pick it up Thursday/Friday Quote
SkyTrekker Posted September 25, 2019 Report Posted September 25, 2019 1) yes on the pictures. Bring it. 2) I have a similar slight hill and lip right at the threshold of my hangar. Tried to get it in on my own, but was unable. So bought a sidewinder and love it. 1 Quote
1ang Posted September 25, 2019 Author Report Posted September 25, 2019 2) I have a similar slight hill and lip right at the threshold of my hangar. Tried to get it in on my own, but was unable. So bought a sidewinder and love it. Gonna see if I can do it first before I open the wallet to that expense 1 Quote
Hank Posted September 25, 2019 Report Posted September 25, 2019 Pulling the plane in & out of the hangar is my exercise routine, plus the occasional waterless wash and wax. Need to stay strong enough to move the plane as required, and flexible enough to get in and out of the cockpit. Then everything else will take care of itself. oh, get yourself one of those nice double-ratcheting screwdrivers. It really makes annual inspection time nicer! And will still wear out the grip in both hands as well as all the other moving muscles in both forearms. You won't carry anything or write much for a few days. 1 Quote
Hank Posted September 25, 2019 Report Posted September 25, 2019 7 hours ago, 1ang said: He guys, first time owning an airplane, have a hanger and looking to stock it up. What are some of the essentials needed? You may want some of these: 1 Quote
jaylw314 Posted September 25, 2019 Report Posted September 25, 2019 1 hour ago, Hank said: Pulling the plane in & out of the hangar is my exercise routine, plus the occasional waterless wash and wax. Need to stay strong enough to move the plane as required, and flexible enough to get in and out of the cockpit. Then everything else will take care of itself. oh, get yourself one of those nice double-ratcheting screwdrivers. It really makes annual inspection time nicer! And will still wear out the grip in both hands as well as all the other moving muscles in both forearms. You won't carry anything or write much for a few days. I use a light duty cordless drill/driver to remove screws. If I have a bunch, I will fess up and admit I use it to install them, too, but only after starting them by hand and with the clutch at the lowest setting, and then I finish them off with a manual screwdriver. In terms of pulling the plane over a bump, you can often do it if you build up momentum first, but you do NOT want to do this solo the first few times--make sure you have a friend as a spotter to guide you. It's a good way to get hangar rash if you're not lined up correctly... Quote
ArtVandelay Posted September 25, 2019 Report Posted September 25, 2019 You may want some of these: Just don’t buy their screwdrivers. Their tools are designed only for light duty, Tom 1 Quote
