flyboy0681 Posted October 20, 2018 Report Posted October 20, 2018 Anybody know where I can get a replacement ashtray? Quote
Jerry Pressley Posted October 20, 2018 Report Posted October 20, 2018 jerry acpartswhse@aol.com Quote
Jerry Pressley Posted October 20, 2018 Report Posted October 20, 2018 was that an old shelly burman saying? Cigars, cigarettes, Tiparillos we don't have time for that we're doomed Quote
1964-M20E Posted October 21, 2018 Report Posted October 21, 2018 if you really want to keep the ashtrays go to a hot rod chrome shop and have them re-chromed. Quote
Pritch Posted October 21, 2018 Report Posted October 21, 2018 "Should a Gentleman offer a Lady a Tipparillo" Eddi Adams circa 1960,s Quote
LANCECASPER Posted October 21, 2018 Report Posted October 21, 2018 18 hours ago, flyboy0681 said: Anybody know where I can get a replacement ashtray? https://www.aircraftspruce.com/catalog/pspages/cigpen.php?clickkey=21049 Not sure if these would fit, but there are also lights made which replace the ashtray. Quote
flyboy0681 Posted October 21, 2018 Author Report Posted October 21, 2018 16 minutes ago, LANCECASPER said: https://www.aircraftspruce.com/catalog/pspages/cigpen.php?clickkey=21049 Not sure if these would fit, but there are also lights made which replace the ashtray. Has anybody here purchased on of these, and if so, was it an easy fit? Quote
Hank Posted October 21, 2018 Report Posted October 21, 2018 My ashtray is intomthe side rather than vertical like this picture. I replaced it with an Ashlight, four red LEDs. Does a pretty good job helping me see my kneeboard in the dark. I keep a pen clipped on both sides of the panel. Quote
ArtVandelay Posted October 21, 2018 Report Posted October 21, 2018 If you ever redo your interior, you might want to consider removing the ashtrays: 2 Quote
FloridaMan Posted October 22, 2018 Report Posted October 22, 2018 I like that I have a factory ashtray and built-in factory oxygen. 2 1 Quote
Marauder Posted October 22, 2018 Report Posted October 22, 2018 I like that I have a factory ashtray and built-in factory oxygen. Ah, those are fine together. It’s just when you have residual oil on your hands from your pre-flight and then go messing with your O2 that your new nickname might be “Human Torch”. Sent from my iPad using Tapatalk Pro Quote
carusoam Posted October 22, 2018 Report Posted October 22, 2018 A little lip balm with your O2 could result in your formator handle being ‘HotLips’... oxidation rates have a measurable change in high O2 environments... lower energy of ignition to the level of auto ignition is real... Best regards, -a- Quote
FloridaMan Posted October 22, 2018 Report Posted October 22, 2018 What's the mechanism? O2 increases oxidation enough to generate adequate heat for ignition? 1 Quote
jaylw314 Posted October 22, 2018 Report Posted October 22, 2018 7 minutes ago, Antares said: What's the mechanism? O2 increases oxidation enough to generate adequate heat for ignition? Yup. Kind of like how the oil-soaked rags will smoke for a while before they actually catch on fire. Edit: just looked up spontaneous combustion on Wikipedia. Today I learned it's not motor oil, but biologic oils such as linseed oil that are broken down by bacteria and fungi which produce heat that can autoignite. I also leanred pistachio nuts are prone to spontaneous combustion. Quote
carusoam Posted October 22, 2018 Report Posted October 22, 2018 Having a high concentration of O2 mixed with fuel that has a low energy requirement for oxidation, combined with high heat energy emitted by the reaction... Concentration increases the collisions between molecules until the right collision causes a chemical reaction... plenty of statistics involved... but adding heat and concentration makes the stats of flammability increase... Things that aren’t normally flammable become incredibly flammable under the right conditions... So keep your oils and greases away from your O2... Don’t allow an O2 leak go unchecked... Best regards, -a- 1 Quote
flyboy0681 Posted October 22, 2018 Author Report Posted October 22, 2018 And to think all I asked for was an ashtray. Quote
carusoam Posted October 22, 2018 Report Posted October 22, 2018 We haven’t heard from the chemists yet... Speaking of oxidation... Have you considered having your rusty ashtrays rechromed? Same conversation is concurrently going on regarding the Jbar... Lasar vs. local speed shop... seem to be a way to proceed.... Best regards, -a- Quote
flyboy0681 Posted October 22, 2018 Author Report Posted October 22, 2018 I'm looking into re-chroming but there may be too much corrosion to save it. Lasar couldn't help. Quote
carusoam Posted October 22, 2018 Report Posted October 22, 2018 Speed shop could be a real answer... They will have seen some pretty deep oxidation scars in the automotive world... Find a handy website for car fans of highly chromed cars from the 50s and 60s... Best regards, -a- Quote
LANCECASPER Posted October 23, 2018 Report Posted October 23, 2018 5 hours ago, flyboy0681 said: I'm looking into re-chroming but there may be too much corrosion to save it. Lasar couldn't help. Talk to a high volume upholstery shop. www.aerocomfort.com Call and talk to Hector Or take it and have it sandblasted and powdercoated whatever color or finish you want. Quote
Andy95W Posted October 23, 2018 Report Posted October 23, 2018 4 hours ago, flyboy0681 said: And to think all I asked for was an ashtray. We're really just trying to convince you to stop smoking. Quote
flyboy0681 Posted October 23, 2018 Author Report Posted October 23, 2018 2 minutes ago, Andy95W said: We're really just trying to convince you to stop smoking. Never as much took a single puff in my 58 years. I have absolutely no idea what it's about. Quote
Hank Posted October 23, 2018 Report Posted October 23, 2018 49 minutes ago, flyboy0681 said: Never as much took a single puff in my 58 years. I have absolutely no idea what it's about. It's about addicting people to a product known to be unhealthy, so that corporate earnings can stay high. Usage rates are inversely proportional to education levels, and are especially high in developing countries, whose education levels are usually also low . . . . Quote
Lance Link Posted October 23, 2018 Report Posted October 23, 2018 I would mask the plastic, then sand the chrome heavily with 320 grit production paper and spray paint it with Alum-Hide (sp?) paint in your choice of color from the Brownell's gunsmithing catalogue (or some other type of serious epoxy paint). Wear a good respirator the stuff will eat your lungs. It will out last us all. Probably not FAA certified though so there is that. Quote
