HRM Posted May 18, 2018 Report Posted May 18, 2018 Can anybody tell me how they R&R exhaust stacks on an E? Particularly the inner nut? Do you just put an open-end wrench on it vertically and turn the wrench with pliers? The outer nut can be accessed by an open-end fairly easily, but both it and the inner will not accommodate a socket because of the clearance with the pipe. I ordered 'thin-wall' sockets off Amazon, but no joy. Quote
KSMooniac Posted May 18, 2018 Report Posted May 18, 2018 I use a 1/4" drive swivel socket on a long extension.Sent from my LG-US996 using Tapatalk Quote
Bob_Belville Posted May 18, 2018 Report Posted May 18, 2018 I ground thin wall socket down thinner. 1 Quote
MB65E Posted May 18, 2018 Report Posted May 18, 2018 Ground down 12pt wobble socket. It’s a challenge depending how much material is welded on the stack for repairs. -Matt 1 Quote
MARZ Posted May 18, 2018 Report Posted May 18, 2018 28 minutes ago, KSMooniac said: I use a 1/4" drive swivel socket on a long extension. Sent from my LG-US996 using Tapatalk +1 And when reinstalling - snug the inside nuts first - then the outside - and read long extension to mean past the bottom curve of the exhaust Pipe Quote
N201MKTurbo Posted May 18, 2018 Report Posted May 18, 2018 I use a 1/4 drive socket on the inside nut. It will bias the pipe enough that I can't get the socket on the outside one but it is easy to get to with am open end or a crow's foot. Quote
Guest Posted May 19, 2018 Report Posted May 19, 2018 A Snap On 1/4” drive 1/2” socket on a long extension works every time. Clarence Quote
RLCarter Posted May 19, 2018 Report Posted May 19, 2018 This what worked for me, but in a 12 point Quote
Andy95W Posted May 19, 2018 Report Posted May 19, 2018 1/4" drive 12-point socket, plus a 12" and 3" extension. And it has to be a 12-point socket. The 6-point has too much wall thickness, believe it or not. Quote
HRM Posted May 20, 2018 Author Report Posted May 20, 2018 19 hours ago, Andy95W said: 1/4" drive 12-point socket, plus a 12" and 3" extension. And it has to be a 12-point socket. The 6-point has too much wall thickness, believe it or not. Well, here is where I am with this. After reading the posts, I thought @M20Doc (Clarence) matter-of-fact suggestion of a Snap-On 12 pt, 1/2", 1/4" drive socket sounded best, so I ordered one off of eBay. I really do not want to grind anything down and I had looked at Snap-On sockets before at their storefront site and went into CB shock and had to run down to HF and browse just to calm down. A video by the PowerFlow exhaust guys showed a tech using a very long extension to just reach up in and tighten away. Given the cost of those systems I would guess all his tools are Snap-On Of course, the PF headers may have extra clearance. So, the 12 pt vs 6 pt makes sense to me, we'll see. I paid $11.50 with shipping for the socket and if it just slips right up there I'll do a MasterCard commercial. Harley 1 Quote
carusoam Posted May 20, 2018 Report Posted May 20, 2018 Watch the CEO of Snap-On on CNBC... their tools stand above the rest for quality, design, and purpose... or listen to Clarence...quality and purpose, by design... I got my first snap-on tool by working with my mechanic on the annual for my M20C... bought a pair of pliers that could grab the head of a screw that had been previously stripped.... that’s a pretty precise pair of pliers... I never took my own exhaust off before... but, is there much difference in R&R of the intake tubes? Aside from the added heat and oxidation issues... Looks like the weld material can be an individual challenge... Best regards, -a- Quote
Guest Posted May 20, 2018 Report Posted May 20, 2018 5 hours ago, HRM said: Well, here is where I am with this. After reading the posts, I thought @M20Doc (Clarence) matter-of-fact suggestion of a Snap-On 12 pt, 1/2", 1/4" drive socket sounded best, so I ordered one off of eBay. I really do not want to grind anything down and I had looked at Snap-On sockets before at their storefront site and went into CB shock and had to run down to HF and browse just to calm down. A video by the PowerFlow exhaust guys showed a tech using a very long extension to just reach up in and tighten away. Given the cost of those systems I would guess all his tools are Snap-On Of course, the PF headers may have extra clearance. So, the 12 pt vs 6 pt makes sense to me, we'll see. I paid $11.50 with shipping for the socket and if it just slips right up there I'll do a MasterCard commercial. Harley If you have to grind it down, you’re best to start with a Snap On as much as it hurts. They start off with better material so even thinned out they still work better. I have several $100 Snap On tools which I have ground down, life time warranty is now gone. Clarence Quote
HRM Posted May 21, 2018 Author Report Posted May 21, 2018 3 hours ago, M20Doc said: If you have to grind it down, you’re best to start with a Snap On as much as it hurts. They start off with better material so even thinned out they still work better. I have several $100 Snap On tools which I have ground down, life time warranty is now gone. Clarence Well, a Snap-On socket from eBay is probably not covered under their warranty and the .011 AMU that I paid is not going to cause me any heartburn if I do need to grind it down. Hope springs eternal, but just in case, I have a grinding wheel Harley Quote
Yetti Posted May 21, 2018 Report Posted May 21, 2018 The grumpy IA and the other A&P both have ground down sockets. the other place to use them is on the Electric gear actuator pulling it out. But I think that one is 7/16 Quote
Yetti Posted May 21, 2018 Report Posted May 21, 2018 Is it rumored that the Husky brand of wrenchs and sockets are built by snap-on. Their fit and finish makes if believable. Quote
HRM Posted May 23, 2018 Author Report Posted May 23, 2018 So happy---I really need to get a grip. Almost orgasmic when that socket just slipped up in there (see 1st photo). Summary: heed grumpy IAs, 12 pts are thinner walled than 6 pts, 1/4" drive are thinner than 3/8" drive from my limited data set. Apparently 0.6 mm made the difference. Oh yeah, let the cockpit humor commence. Quote
DonMuncy Posted May 23, 2018 Report Posted May 23, 2018 8 minutes ago, HRM said: So happy---I really need to get a grip. Almost orgasmic when that socket just slipped up in there (see 1st photo). Summary: heed grumpy IAs, 12 pts are thinner walled than 6 pts, 1/4" drive are thinner than 3/8" drive from my limited data set. Apparently 0.6 mm made the difference. Oh yeah, let the cockpit humor commence. You know these guys, don't you. 1 Quote
