what is this light for, if this is a light?
M20F pilot footwell, looks like it is part of the airspeed switch (landing gear safety device, ie don't retract under a certain speed).
I believe it’s intended to simply illuminate to assist in viewing the fuel selector switch setting (on the floor under the pilot’s feet).
I don’t remember anything in the POH detailing the fuel selector light...
My M20C had one. I came across it while working on getting panel lights to dim properly... all the panel lights are grounded to a bolt near the fuel selector light.
Looks similar to the gear lights on the panel in construction... does it have an iris twist control for dimming?
Yes it does have an iris
If the 28 volt bulb is put in instead of the 14 volt it will be dim.  Found wrong bulb in my mag compass when I first got it.  Don’t know if that’s your problem.
mike
Yup, that's what it is. See @ragedracer1977 post with the POH excerpt.
21 hours ago, Pictreed said:
Actual panel lights or those hot bullets on the overhead?
If memory serves me well, panel lights were options. These are part of plastic overlays and controlled by rheostat overhead. My '67F has them...
