wburger1 Posted January 1, 2018 Report Posted January 1, 2018 I looked at a 67 M20C and it has a ring next to the fuel selector and my 63 M20C does not. What is it for. Also you need small hand to turn the selector in this Mooney fuel selector.. Is that normal? Quote
TWinter Posted January 1, 2018 Report Posted January 1, 2018 Pull ring is the tab for the fuel sump drain. Set left and pull and set right and pull. Some people just pull it once. "Pulling once is necessary, pulling twice is for pleasure"..opps, that what the military says. My bad. -Tom 1 Quote
cliffy Posted January 1, 2018 Report Posted January 1, 2018 That fuel selector also needs the required labels to pass an annual :-) Quote
HRM Posted January 1, 2018 Report Posted January 1, 2018 1 hour ago, wburger1 said: Also you need small hand to turn the selector in this Mooney fuel selector.. Is that normal? When I was six and a half gallons of AVgas heavier, I had a piece of PVC with a notch on one end to turn it with. Now I just reach down and flick it with a finger. 1 Quote
carusoam Posted January 1, 2018 Report Posted January 1, 2018 Prior to ‘65, The Glass fuel bowl/strainer is up by the engine. It is one of the many updates that came with the ‘65 model... Best regards, -a- 1 Quote
RLCarter Posted January 1, 2018 Report Posted January 1, 2018 58 minutes ago, HRM said: When I was six and a half gallons of AVgas heavier, I had a piece of PVC with a notch on one end to turn it with. Now I just reach down and flick it with a finger. 7.5 gallon makes it even tougher Quote
Andy95W Posted January 1, 2018 Report Posted January 1, 2018 The pull ring actually started in 1964, but the Mooney factory didn't always adhere strictly to years as they added and modified their finished airplanes. 1 Quote
FloridaMan Posted January 4, 2018 Report Posted January 4, 2018 I kindof wish you could sump the nose the same way. I can't tell you how many times I've been all strapped in and realized I needed to check the ring on the checklist so I have to pull it then hang out the door and look for the fuel spot and make sure it's not still dripping. A mirror on a stick or a bore scope would be very useful for this and checking the baggage door items. Quote
1964-M20E Posted January 4, 2018 Report Posted January 4, 2018 Mine has been modified to have a typical sump drain outside. Makes it nice when doing your pre-flight. Also when you forget to drain it before you are walking around my arm was never long enough to reach it trough the little window. One time while working on my E model can remember exactly why but need to pull the ring multiple times so I made a hook with a ling enough wire to reach the ring from the window. Quote
MARZ Posted January 10, 2018 Report Posted January 10, 2018 On 1/1/2018 at 11:43 AM, HRM said: When I was six and a half gallons of AVgas heavier, I had a piece of PVC with a notch on one end to turn it with. Now I just reach down and flick it with a finger. My version - Quote
RobertGary1 Posted January 10, 2018 Report Posted January 10, 2018 (edited) On 1/4/2018 at 1:41 PM, 1964-M20E said: Mine has been modified to have a typical sump drain outside. Makes it nice when doing your pre-flight. Also when you forget to drain it before you are walking around my arm was never long enough to reach it trough the little window. One time while working on my E model can remember exactly why but need to pull the ring multiple times so I made a hook with a ling enough wire to reach the ring from the window. Meaning you have a different selector / collator? Is this an stc for a selector from a different plane? -Robert Edited January 10, 2018 by RobertGary1 Quote
carusoam Posted January 10, 2018 Report Posted January 10, 2018 Mike is showing some really nice shiny paint skills! Best regards, -a- 1 Quote
Marauder Posted January 10, 2018 Report Posted January 10, 2018 I wish I could just bend over and reach it. Sent from my iPad using Tapatalk Pro Quote
HRM Posted January 11, 2018 Report Posted January 11, 2018 9 hours ago, Mike Ropers said: My version - Too pornographic for my taste. Quote
HRM Posted January 11, 2018 Report Posted January 11, 2018 6 hours ago, Marauder said: I wish I could just bend over and reach it. My point exactly. Each 6.01# you lose is another gallon of Avgas and puts you closer to reaching the selector without a stick. Quote
RLCarter Posted January 11, 2018 Report Posted January 11, 2018 6 hours ago, Marauder said: I wish I could just bend over and reach it. I can reach it, its just that yoke gets pushed to far forward and I exceed Vne 1 Quote
MARZ Posted January 11, 2018 Report Posted January 11, 2018 4 minutes ago, RLCarter said: I can reach it, its just that yoke gets pushed to far forward and I exceed Vne lol I'm the opposite - I have to pull on it so I can bend over to reach it 2 Quote
Marauder Posted January 11, 2018 Report Posted January 11, 2018 My point exactly. Each 6.01# you lose is another gallon of Avgas and puts you closer to reaching the selector without a stick. Oh, it ain’t the belly. It’s too many years of football. Sent from my iPhone using Tapatalk Pro Quote
Yetti Posted January 11, 2018 Report Posted January 11, 2018 Have yetti type arms.... no problem. Oh and technically do you have a STC for that key ring split ring.... :-) You have to bend the original ring to redo the carpet, but not a good way to bend back. The key split ring looks like a good idea Quote
Cyril Gibb Posted January 11, 2018 Report Posted January 11, 2018 On 2018-01-04 at 10:41 PM, 1964-M20E said: One time while working on my E model can remember exactly why but need to pull the ring multiple times so I made a hook with a ling enough wire to reach the ring from the window. My F POH preflight says to pull the sump drain selecting both the left and right tanks for 5 secs each. Then sump the 2 wing tanks. I’ve always worried that a slug of water in a tank would be drawn part way into the lines by sumping the selector first, so I wouldn’t see it there and then it also wouldn’t be visible when I sumped the tanks. So I sump the tanks first and then the selector. Mind you, I’ve never found even a drop of water... yet. 1 Quote
carusoam Posted January 11, 2018 Report Posted January 11, 2018 Cyril, I think the procedure takes into account, the worst case... 1) If leaky fuel caps allowed a gallon of water in each tank... 2) Sumping each tank would drain the water to below the fuel line pick-up... 3) draining the fuel separator twice for the proper time, changing the valve in between.... empties both lines This relies on the laws of physics to operate. The potential challenges you can run into Are... restriction of flow in the line that would take longer than usual to empty... human error like not draining all the water, or forgetting to flip the valve, or not draining for enough time... I had the mild steal fuel necks in my 65C. I learned a lot about metallurgy, metal forming, water intrusion, and icing in one year... Fun Stuff... remember by a PP, not a mechanic... Best regards, -a- Quote
