  10500 full fuel 2 of us with about 75lbs baggage based on conditions (IAS OAT ALT) 147KTAS
My POH says at 10,000', standard day, standard plane, you have to run 2700 RPM (74.9% power) to get 142-146 kts.
What mods do you have?
My F model will do 169 KTAS. I have the cowl closure, gap seals, the 201 windshield and a fat lady in the trunk.
I also have proof. See the attached photo. Disregard that it appears I am in a 2.5 degree descent and that the VSI is showing 460 FPM and that you can't see the throttle and prop are firewalled.
I also have proof. See the attached photo. Disregard that it appears I am in a 2.5 degree descent and that the VSI is showing 460 FPM and that you can't see the throttle and prop are firewalled. emoji12.png
Is that a photograph of your attitude indicator showing you are pitched down? And -460fpm?
Yep
  Yep
so that begs my next question - how do you get the nose to pitch down with a 700 lb beauty in the back?
She was leaning forward. You have heard of Lean of Pitch before, right?
Put a cupcake on the glareshield.
  • Like 6
That would be a nose dive!
Could you please list all your speed mods, this seems significantly higher than any published data for stock "C's"
It's definitely not stock. I've got every speed mod Lasar has available except the one piece belly. (which isn't really a speed mod)  For what it's worth, Maxwell says it's the fastest C he's ever flown.
Where does the 430W display TAS? It's new to me ...
It has a function to calculate TAS by inputting pressure altitude, temp, etc.  it doesn't read it per se.  The best way to determine actual TAS is a 3 point ground speed check as that will remove any instrument error from the equation.
Did that @ 8000ft 148 knots true and the four heading same day same altitude yielded 149 knots true, 2 on board about 70% fuel
On the Garmin, go to the "Aux" main page (large right knob, clockwise).  Get to the Aux menu which is one before the "nearest" menu.  Then go to the "flight Planning" page which is the first page on that menu.  Push in the right knob to get the cursor, go to "Density Alt/TAS/Winds", hit enter, fill in the data on the next page (IAS, Altitude, Temp, etc), the Garmin with gonk the winds and your TAS.  I have compared it to the 3 and 4 way ground checks and found it to be within about 1 knot, however...
Using this function brings in the errors of your Airspeed Indicator, temp probe, and altimeter... my IAS was off by about 5kts at 140mph indicated.
The best way is really the 3 way groundspeed test.
Sorry to be off topic, but everyone knows Garmin has a free 430W/530W SIM on their website, right?  It's really good for learning all the tricks in that thing, especially if you are using it for IFR.
Rags
Rags
If you think your post is off topic, have I got some threads to show you!
The GTN series has a very easy to use version.
The Mooney wing seems to really be at home between 8-12K.  One advantage of flying that high is that there isn't much traffic up there unless you are in the mountain west.
I thought those numbers were for passenger weight.  I guess I have to clean my glasses.
On January 14, 2016 at 11:40 PM, Marauder said: If you think your post is off topic, have I got some threads to show you!
These are the real numbers for W&B. Not an issue, right?
To bring this thread back on track. Here is a cockpit shot in my M20C up at 15,500ft earlier today in level cruise. I just calculated the TAS, with 130mph (113kts) IAS, 30.13, and -10.5 degrees C... and came up with 145kts TAS.
Edited by xrs135
For those of you who suspect that your TAS is low, I had a situation where a leak in the pitot system scrubbed 5 knots off of my IAS.
Since I have 3 ASIs on board, I was convinced the speed was correct and that the plane's engine was at fault. Nothing showed on the engine analyzer data. I then realized that my religious checking of both the static and pitot drains during the pre-flight managed to create a pitot leak at the drain and it resulted in a 5 knot IAS loss. And since all 3 ASIs use the same pitot tube, it affected them all. I was due for a pitot static test and they found the leak at the drain.
2 hours ago, Jake35 said:
150 -155kts at 12,500 to 16,500 in a naturally aspirated C model is fantastic!
What's pulling or pushing it to get that kind of speed!
