59 minutes ago, aviatoreb said:
You got an IO720 hanging on the front of your M18?
Yes, and two seats.  Don't tell Transport Canada
I want an IO900 for the front of my M20 - no a TSIO900
Might I suggest a P&W 985 with the 2 blade Hamilton Standard?  Sure would sound cool.
2 hours ago, Danb said:
Hank just think if you hat didn't slow you down?
Nah, that's my winter hat. My summer hat is similar but ventilated for reduced drag. If I only had a good picture . . .  :D
5 hours ago, M20Doc said:
Just returned from the time to climb check.  Field 1050' ASL, baro 30.40"Hg, OAT 9 C.  80 gallons of fuel,  2 on board @ 420LBS.
From a standing start, climbed at 120KTS, (Vx= 80 KTS, Vy= 104KTS)  Could have climbed steeper but the sun was low and made it hard to see. I will have to do it again to improve the numbers
2000'  0:50
3000' 1:29
4000' 2:06
5000' 2:52
6000' 3:38  less than 5 NM from airport
7000' 4:22
8000' 5:10
9000' 5:54
10,000' 6:43
11,000 7:42.  12 NM from the airport
Fuel used:  72/80 gallons.
Sorry, Clarence, couldn't resist! :)
Interesting data. Have never done a time to climb test in my C. What I have done is climb at WOT and 2500 rpm and trimmed for 120 mph (my typical cruise climb with temps staying below 400) until she could climb no more. I was 400 under gross and she stopped climbing at 16000 (still showing 120 mph indicated). Temperature at departure airport (KCRG) was around 70 degrees F. Pretty sure if I had increased to full RPM and continued climbing at Vy (around 85 indicated at 16000 feet) she would have gone another couple of thousand. Pretty cool considering at 16000 feet and 2500 rpm an O-360 is making just a little over 60 BHP.
Itleaves enough fuel in its wake to run a C model.
2000'  0:50
3000' 1:29
4000' 2:06
5000' 2:52
7000' 4:22
8000' 5:10
9000' 5:54
10,000' 6:43
So it took you 7:42 to climb from 10000 to 11000 or it took you 59 secs? If you are climbing at 1000'/min at 10000', what kind of turbo do you have installed?
2000'  0:50
3000' 1:29
4000' 2:06
5000' 2:52
7000' 4:22
8000' 5:10
9000' 5:54
10,000' 6:43
run out of gas at 11k? :)
No turbo, his climb rates actually increase with altitude because the rate fuel burn making him some much lighter. His flight profile is more like a SR22 spy plane with a refueler waiting at the top of the climb.
Joking aside, impressive numbers!
59 seconds and Clarence gets his power the old fashion way through 400hp (PA-24-400) because Pug Piper thought turbo's would never take off.
"There's no replacement for displacement."  --Big Daddy Garlits (one of my childhood heroes, hope to see his museum one day)
The Learjet 28’s World Records
FAI Record #2652
Type: Time to climb to a height of 15,000 meters
Performance: 12:27 minutes
Sub-class: C-1e (landplanes, mtow 3,000 to 6,000 kg)
Claimant: Neil A. Armstrong
Date: Feb. 19, 1979
That is a bit over 3,900 feet per minute. Average. From sea level to nearly 50,000 feet.  Four guys on board.
2 hours ago, teejayevans said: So it took you 7:42 to climb from 10000 to 11000 or it took you 59 secs? If you are climbing at 1000'/min at 10000', what kind of turbo do you have installed?
My HP (200) divided by M20Doc's HP (400) times my 10K climb time (10:20) = 5:10 (adjusted for HP deficiency). I'm feeling better now.
Not out of fuel, a slow moving Mooney was in the way!!
FAI Record #2652
Date: Feb. 19, 1979
Very cool!  Ok - since we aren't talking Mooneys anymore (Clarence was still a piston at least)
I once was reading on barnstormers an experimental category modified aerobatic airplane for sale with a turboprop engine where the owner was claiming that it would climb from 0 to 18000ft in 2.5 min.
F16 Rate of Climb (wiki) 50,000fpm.
The jet powered Waco show plane (many of us) saw at Oshkosh and other air shows - I had the chance to ask him - he said he climbs at 8000fpm and is limited only by the redline on the airframe because it can climb straight up.
Space Shuttle: 31 sec to 10,000ft and 99sec to 100,000ft. (I thought a Mooney rocket was fast - but a real rocket is faster...)
http://www.nasa.gov/pdf/585035main_ALG_ST_SSA-Altitude.pdf
WAIT A MINUTE ! I'm sitting here watching Street outlaws and what better thread to re read than this and it occurs to me that Hank never posted his numbers. What's Up!
  • 3 months later...
Just returned from resetting the time to climb in the P brand airplane. 10,100 foot climb in 5:54.59. Vy plus 10 mph.
Edited by M20Doc
Was that a nitrous oxide bottle I saw in the back of your hangar yesterday ? .... just askin'
On 11/16/2015 at 5:21 PM, Mooneymite said:
Should we record the times in seconds, minutes, hours, or days....?  :lol:
NO, it should be in gallons :o
Good lord! Six hours to climb to the 10,000' step! Hope the glide back down was good. My C only carries fuel for 5:30:00 flying, but I've not tried timing it to the second. :D
