NickG Posted August 17, 2024 Report Posted August 17, 2024 Took my O up to 16k on the way back from Amarillo last week. Wondering what sort of TAS everyone gets from say, 15k on up and FF (obviously WOT). Any info would be appreciated. 1 Quote
MatthiasArnold Posted August 20, 2024 Report Posted August 20, 2024 Typically 158KTAS on 10.2gals/h, close to max gross with TKS FIKI and A/C induced drag penalties at F150 - F160. 1 Quote
JimK Posted November 4, 2024 Report Posted November 4, 2024 I just flew N436PS, a 2008 3GX Ovation from KMHK to KJWN a few weeks ago at 15K. I was able to get slightly over 60% power (based on the 310hp tables), LOP, 13.5gph, WOT, 2,600RPM and 183kts TAS. 2 Quote
buddy Posted November 5, 2024 Report Posted November 5, 2024 2005 O2 has everything but TKS. Flying at 15K, OAT -1, ROP, WOT, 2,400RPM. 169 kts TAS Quote
Ragsf15e Posted November 6, 2024 Report Posted November 6, 2024 On 11/5/2024 at 1:24 PM, buddy said: 2005 O2 has everything but TKS. Flying at 15K, OAT -1, ROP, WOT, 2,400RPM. 169 kts TAS Expand What was your ff at that setting? thanks, drew Quote
buddy Posted November 6, 2024 Report Posted November 6, 2024 On 11/6/2024 at 3:06 AM, Ragsf15e said: What was your ff at that setting? thanks, drew Expand Sorry the screen shot was not clear but the FF was 11.6 1 Quote
FlyingScot Posted November 7, 2024 Report Posted November 7, 2024 Representative numbers at two power settings for 310 HP 2000 O2 w/TKS: 15000’ WOT 2500 176 TAS 16.5 gph 59% 15000’ WOT 2400 170 TAS 13.9 gph 56% Quote
Ragsf15e Posted November 7, 2024 Report Posted November 7, 2024 It’s interesting that there’s quite a wide variation in seemingly similar power settings at the same altitude. Quote
NickG Posted November 7, 2024 Author Report Posted November 7, 2024 Main difference is how lean and what RPM. I cruise at 2550, others 2500 or 2400. Quote
hais Posted November 9, 2024 Report Posted November 9, 2024 On 11/7/2024 at 3:31 AM, NickG said: WOT 14000 176KTAS 11.4GPH Expand Looking at your post-it makes me wish: wouldn't it be nice if the g3x had "power setting bugs"? 1 Quote
mike_elliott Posted November 9, 2024 Report Posted November 9, 2024 Personally, I like flying the O's under 12K, you really dont gain much higher up. Here is one burning a paultry 12.6 GPH bustin along at 179-180 TAS I flew from College Park to Fort Lauderdale a while back. Horsepower when flying LOP is determined by FF*13.9 in the higher compression non turbo's acc'd to Mike Busch, so if your a nerd for wanting a percent, you can build a chart. ROP, all bets are off, just fly it 100 ROP from first cyl to peak, and you will keep the aluminum stout for more than a few flights. 1 Quote
Jeff Uphoff Posted November 9, 2024 Report Posted November 9, 2024 I'm with @mike_elliott here. I've had my Ovation (originally Kerrville's first O2, now STC'd to an O3) ~2.5 years and 350+ hours now, and the only time I fly it over 11k is to top weather/bumps. It has a really great sweet spot flying WOT & LOP from 9-11k. This was WOT at 11k last year turning either 2500 or 2550 RPM (I can't recall). 182KTAS on 11.9GPH at about 50 LOP. 2 Quote
varlajo Posted November 10, 2024 Report Posted November 10, 2024 On 11/9/2024 at 7:01 PM, hais said: Looking at your post-it makes me wish: wouldn't it be nice if the g3x had "power setting bugs"? Expand Sure does!! Quote
hais Posted November 10, 2024 Report Posted November 10, 2024 On 11/10/2024 at 12:58 AM, varlajo said: Sure does!! Expand Neat, thanks! have to go read the manuals again. Quote
NewMoon Posted November 25, 2024 Report Posted November 25, 2024 On 11/4/2024 at 10:20 PM, JimK said: I just flew N436PS, a 2008 3GX Ovation from KMHK to KJWN a few weeks ago at 15K. I was able to get slightly over 60% power (based on the 310hp tables), LOP, 13.5gph, WOT, 2,600RPM and 183kts TAS. Expand That's pretty darn good Quote
NewMoon Posted November 25, 2024 Report Posted November 25, 2024 On 11/6/2024 at 12:56 PM, buddy said: Sorry the screen shot was not clear but the FF was 11.6 Expand Are you sure that is ROP? Seems low at WOT Quote
NewMoon Posted November 26, 2024 Report Posted November 26, 2024 On 11/7/2024 at 5:12 AM, Ragsf15e said: It’s interesting that there’s quite a wide variation in seemingly similar power settings at the same altitude. Expand I agree, I see a guy at 15k showing 16.3"mp, I would be high 17's Quote
Max Clark Posted November 26, 2024 Report Posted November 26, 2024 On 11/10/2024 at 12:58 AM, varlajo said: Sure does!! Expand Hard to read on my screen, what did you have printed here? Quote
varlajo Posted November 26, 2024 Report Posted November 26, 2024 On 11/26/2024 at 12:01 AM, Max Clark said: Hard to read on my screen, what did you have printed here? Expand Ah, we were talking about the user-defined ticks on manifold pressure gauge. Quote
Niko182 Posted November 26, 2024 Report Posted November 26, 2024 On 11/9/2024 at 7:56 PM, mike_elliott said: Personally, I like flying the O's under 12K, you really dont gain much higher up. Here is one burning a paultry 12.6 GPH bustin along at 179-180 TAS I flew from College Park to Fort Lauderdale a while back. Horsepower when flying LOP is determined by FF*13.9 in the higher compression non turbo's acc'd to Mike Busch, so if your a nerd for wanting a percent, you can build a chart. ROP, all bets are off, just fly it 100 ROP from first cyl to peak, and you will keep the aluminum stout for more than a few flights. Expand I believe its 14.9 for the non-turbos, and 13.7 for the turbos. On 11/7/2024 at 1:42 AM, FlyingScot said: Representative numbers at two power settings for 310 HP 2000 O2 w/TKS: 15000’ WOT 2500 176 TAS 16.5 gph 59% 15000’ WOT 2400 170 TAS 13.9 gph 56% Expand As an FYI, this is very ROP. Peak at 59% power is right around 12.2 GPH and 56% is 11.6GPH. You'd get some performance back running it a decent amount leaner and save some gas. If you want to keep running ROP, somewhere in between 12 and 13.5GPH would probably keep the engine a bit cleaner. Quote
Niko182 Posted November 26, 2024 Report Posted November 26, 2024 This was my eagle at 16500. If I knew I was living in Colorado, I would’ve probably considered an acclaim, but this will have to do. I’d agree flying them over 12 doesn’t really get you anything except not hitting a mountain. 1 Quote
mike_elliott Posted November 26, 2024 Report Posted November 26, 2024 On 11/26/2024 at 12:59 AM, Niko182 said: believe its 14.9 for the non-turbos, and 13.7 for the turbos. I stand corrected…. That’s what I meant to say thanks for fixing! Quote
Max Clark Posted November 26, 2024 Report Posted November 26, 2024 On 11/26/2024 at 12:44 AM, varlajo said: Ah, we were talking about the user-defined ticks on manifold pressure gauge. Expand Meant the Vx, Vy, etc... Quote
varlajo Posted November 26, 2024 Report Posted November 26, 2024 On 11/26/2024 at 3:04 PM, Max Clark said: Meant the Vx, Vy, etc... Expand Vr, Vx, Vy, Va, Vbg, Vfe, Vle, and touchdown speeds with and without flaps at MGW -200 and -600 lbs. Quote
