AndreiC Posted July 29, 2024 Report Posted July 29, 2024 One of the few weak spots of my 1970 M20E is the ELT. It still has the original, yellow, portable ELT that was meant to be attached on the side wall behind the pilot seat. When I refurbished the interior I removed it from there, and it has been waiting to get reinstalled. I doubt that this ELT, even if it works perfectly, will allow anyone to find me in case of an accident. On the other hand, I’ve heard people say that *anyway* ELT’s don’t help much, even the newer 406 MHz ones, and upgrading the old ones is just throwing more money out the window. (I can stay legal with the existing one by spending about $40 for a new battery every 2 years; a new 406 MHz one will likely cost 2-3 AMU to install, and require an expensive battery replacement every 5 years). I should mention that I do have a portable non-aviation ELT finder (406 MHz) that is in the pocket by my feet; but that will require manual activation in case something goes wrong. What do you guys recommend to do?
N204TA Posted July 30, 2024 Report Posted July 30, 2024 As of July 2019, it became illegal to manufacture, import, or sell ELTs that only operate on 121.5 MHz in the USA so, if you are looking to replace your old one, you’ll need a 406 one. You can, however, still keep your certified 121.5 ELT (as long as it works) but the frequency is no longer monitored by satellite. So, I guess it all depends on if you just want to be legal or want the best SAR response. 1
Ragsf15e Posted July 30, 2024 Report Posted July 30, 2024 3 hours ago, AndreiC said: One of the few weak spots of my 1970 M20E is the ELT. It still has the original, yellow, portable ELT that was meant to be attached on the side wall behind the pilot seat. When I refurbished the interior I removed it from there, and it has been waiting to get reinstalled. I doubt that this ELT, even if it works perfectly, will allow anyone to find me in case of an accident. On the other hand, I’ve heard people say that *anyway* ELT’s don’t help much, even the newer 406 MHz ones, and upgrading the old ones is just throwing more money out the window. (I can stay legal with the existing one by spending about $40 for a new battery every 2 years; a new 406 MHz one will likely cost 2-3 AMU to install, and require an expensive battery replacement every 5 years). I should mention that I do have a portable non-aviation ELT finder (406 MHz) that is in the pocket by my feet; but that will require manual activation in case something goes wrong. What do you guys recommend to do? I don’t know why people would say a 406 elt won’t help/work? Even the non gps versions have pretty tight location ellipses from the satellites. Yes it will cost something to install, however you can probably do much of it under supervision. It also gives you the little red button on the panel that you can push (time allowing of course) to activate it prior to landing out somewhere. I think it’s a worthwhile investment that I hope I never need, however I do fly over a lot of very remote terrain. 2
PT20J Posted July 30, 2024 Report Posted July 30, 2024 I accidentally activated my ACK E-04 406 ELT in my metal hangar a while back. I shut it off when I discovered the error so it was on less than a minute. Within 10 minutes my mobile phone rang asking if I needed assistance. I asked them to confirm my location and they had my exact lat-long. They work pretty well. 4 1
EricJ Posted July 30, 2024 Report Posted July 30, 2024 10 minutes ago, PT20J said: I accidentally activated my ACK E-04 406 ELT in my metal hangar a while back. I shut it off when I discovered the error so it was on less than a minute. Within 10 minutes my mobile phone rang asking if I needed assistance. I asked them to confirm my location and they had my exact lat-long. They work pretty well. I've had similar experiences since mine has been accidentally set off a couple times. The first time the avionics shop set it off in their hangar and I got a call from a nice lady Sergeant at the AFRCC. The second time I was poking around under the panel during an annual and must have bumped something, and one of the airport staff guys came around in a truck just cruising through the hangars trying to find the ELT that was going off. The 406MHz ELTs are essentially the same technology that is used by PLBs (used by hikers or anybody in remote areas) and EPIRBs for marine applications. Many, but not all, have either self-contained GPS receivers or can be connected to GPS data like connecting an ELT to a GPS navigator. The GPS connection is not required for an ELT, so not all airplanes equipped with ELTs will have the benefit of transmitting GPS coordinates. The general expectations are that the 406MHz will provide initial alert and coarse location, since it is monitored, and the 121.5MHz may be needed for the final phase of the search to get exact location. In other words, the 406 alerts the good guys and provides a good idea of where to look, and if needed the 121.5 can provide the searchers the final location. Even with the 406MHz transmitting last known GPS coordinates, they may not wind up indicating where the final crash site is, but the 121.5 can be located if the searchers get close enough. Ideally the GPS coordinates transmitted by the 406 MHz signal will be accurate, but it isn't certain, if they're even transmitted at all. If you only have the 121.5 MHz ELT, you have to hope that somebody starts looking and gets close enough before the battery gets weak to find you. It's legal, but not the best strategy for maximizing the likelihood of a successful outcome. 1
Ryan ORL Posted July 30, 2024 Report Posted July 30, 2024 I would go for the 406 ELT. I just had one installed before my recent trip to/from Alaska. Especially if you ever plan to fly anywhere remote, it's a great idea.
Pinecone Posted July 30, 2024 Report Posted July 30, 2024 The 121.5 part is needed as the search teams only have direction finding capability on 121.5. These days, most finds are via cell phone triangulation. But you can't rely on that in remote or mountainous areas. 406 came out in boating many years before aviation. A friend has one of the new 406 EPRIBS on his sailboat. This was before GPS. They were moving his boat to the Caribbean hit a bad storm. It broke their mast. They activated the EPIRB and waiting. About an hour later, a USCG C-130 drops out of the low clouds and flies directly over the boat. They dropped a swimmer and a med kit, and fixed up the injuries and waited for a cutter to pick them up. 3
hubcap Posted July 30, 2024 Report Posted July 30, 2024 During Myrtle’s panel upgrade I upgraded the ELT to the 406. Had to add an external antenna but no complaints, and the battery life is significantly increased over the older ELT.
AndreiC Posted July 30, 2024 Author Report Posted July 30, 2024 OK, I'm convinced. Now the second question -- what product do you guys have that works well?
Pinecone Posted July 30, 2024 Report Posted July 30, 2024 Airtex 345 from ACR According to my avionics shop, the ACK is prone to accidental activations. Enough so they gave me a deal on switching to the Airtex. 1
philiplane Posted July 30, 2024 Report Posted July 30, 2024 At $821, the Artex 345 is the best value. The battery is less expensive and has a longer service life than others. As long as eight years. Don't buy an ACK ELT-04. Too many false activations. I'm sending yet another ELT-04 back to them this week for repair. They used to be cheap, but now they're $800. Even the retrofit kit that re-uses an existing ELT-01 installation parts only saves you $27. Which you'll need to send the new ELT back for repair at some point when it false alarms in flight. Google "ACK ELT-04 false alarms" or "-problems" to get a sense of how many people in all different types of planes are having problems with the ELT-04. Which is a continuation of the ELT-01, which was also famous for false activations. 1
BlueSky247 Posted July 30, 2024 Report Posted July 30, 2024 Good timing on this thread. I may be in the market myself.
EricJ Posted July 30, 2024 Report Posted July 30, 2024 If you have an ACK-01, upgrading to the ACK-04 reuses a lot of existing stuff in the installation. I have an ACK-04 and like it a lot. 1
kortopates Posted July 30, 2024 Report Posted July 30, 2024 (edited) The 406 isn't just for remote traveling over the US. My Mooney likes to travel and if you want to leave either of our borders you have to have one for Canada, Bahamas and Mexico for over a decade now. But since they're not 100% reliable I also fly with a Garmin InReach. Before that I had a ACR 406 PELB that I still carry as well. But I don't intend to camp out long if we go down in the middle of no where plus first responders will know what we need medical wise thanks to the InReach. As an early adopter I got the ACK-04, with never any problems with it. ACR is great company for this technology and if I was doing it over again I would likely go with their unit. Edited July 30, 2024 by kortopates 1
PT20J Posted July 30, 2024 Report Posted July 30, 2024 I've got a 406 ELT connected to the GPS for position, a PLB, an inReach, a cell phone, and a VHF handheld. If I get stuck in the bush, I really want to be able to call someone to come get me. 1 1
carusoam Posted Thursday at 09:09 PM Report Posted Thursday at 09:09 PM Hey all! Quick refresh on the topic… The O is in annual, needs ELT modernization. options are… 1) Artex 345 2) ACK E-04 3) Kannad Integra 4) want to have 406mhz, 121.5, and GPS data connected to it… - I believe the old one is an Artex. - there is a GDL52(?) mounted on the shelf in the tailcone. (GPS data for the older BK X-ponder) reusing old footprints would be nice if able. expecting to replace all of the 30yr old equipment. as usual… plane is 1kmi away from me, unable to look what’s there… expect Mooney standards for 1994… Thank you for the words of advice! Best regards, -a-
DXB Posted Thursday at 10:35 PM Report Posted Thursday at 10:35 PM 1 hour ago, carusoam said: Hey all! Quick refresh on the topic… The O is in annual, needs ELT modernization. options are… 1) Artex 345 2) ACK E-04 3) Kannad Integra 4) want to have 406mhz, 121.5, and GPS data connected to it… - I believe the old one is an Artex. - there is a GDL52(?) mounted on the shelf in the tailcone. (GPS data for the older BK X-ponder) reusing old footprints would be nice if able. expecting to replace all of the 30yr old equipment. as usual… plane is 1kmi away from me, unable to look what’s there… expect Mooney standards for 1994… Thank you for the words of advice! Best regards, -a- My #2 lasted 7 years before going crazy alarming whenever it wanted and not allowing me to silence it - this can lead to some in flight and post flight drama. It could not be remedied, and my avionics guy said this cheapest option often goes bad. I replaced with the slightly more expensive #1, which he recommended and has been problem free for the last 3.5 years. I hope it stays that way. 1
EricJ Posted Thursday at 11:24 PM Report Posted Thursday at 11:24 PM I replaced the ancient ACK-01 with an ACK-04, which does everything you mentioned. You'll need a different antenna, too, to support the 406MHz output. I've been very happy with it, and it works because I've gotten contacted after the 406MHz went off a couple times inadvertently during maintenance. 1
philiplane Posted Friday at 12:37 AM Report Posted Friday at 12:37 AM The ACK ELT-04 has a history of self-activation in flight. They are junk. They inherited the faulty G switches from the previous ELT-01 design. Zero stars, not recommended. I have six in the scrap pile so far. And another one to join it soon, as ACK has been unable to fix it after three tries. The best option is the Artex ELT 345. The battery lasts one year longer than the competition, saving you money. It's a solid piece of engineering too. 1 2
AndreiC Posted Friday at 01:41 AM Author Report Posted Friday at 01:41 AM As the OP of this post I should have said what I decided: I went with the Artex 345, and so far (1 year in) it’s all good. 2
PT20J Posted Friday at 03:34 AM Report Posted Friday at 03:34 AM The previous owner installed an ACK-04 before I bought the airplane in 2018. It’s coming up on ten yeas of flawless operation. Tests good at every annual and got me a call from the SAR folks when I set it off accidentally inside a metal hangar for only a few seconds. I’d buy it again. 2 1
Fly Boomer Posted Friday at 12:08 PM Report Posted Friday at 12:08 PM 14 hours ago, carusoam said: The O is in annual, needs ELT modernization. The ARTEX 345 8108 includes a compact 15-inch antenna, and a remote switch that fits in the same panel hole as the ACK and Ameriking switches (2.08 x 0.75), and doesn't require a battery. 1 1
