GaryP1007 Posted December 26, 2022 Report Posted December 26, 2022 Quick question- safe to fly if one battery indicating low but the other normal? Low is 22+/- Sent from my iPhone using Tapatalk Quote
Fly Boomer Posted December 26, 2022 Report Posted December 26, 2022 2 minutes ago, GaryP1007 said: Quick question- safe to fly if one battery indicating low but the other normal? Low is 22+/- Sent from my iPhone using Tapatalk That's not low -- that's dead. I'd be afraid to fly. If the alternator tries to bring that battery back up. it could cause a failure. Quote
Niko182 Posted December 26, 2022 Report Posted December 26, 2022 Fwiw ive had to bring 2 dead batteeies back up in truckee when it was -5 f outside and it ended up being fine. I have a 150 amp alternator if that makes a difference. I just idled a low rpm for a while to keep the amps from going too high. Quote
LANCECASPER Posted December 26, 2022 Report Posted December 26, 2022 32 minutes ago, GaryP1007 said: Quick question- safe to fly if one battery indicating low but the other normal? Low is 22+/- The Required Equipment list in your Ovation POH shows that two batteries are necessary for Day or Night VFR or IFR. Just having both batteries installed isn't what's necessary - they need to be functional. See if it will come back up with a charge on the ground. Electrical problems are no fun in the air. In theory each battery in your Ovation has a trickle charge circuit if you are using the opposite battery, but I still wouldn't take off with one dead battery. (I use BAT 1 on odd days that I fly and BAT 2 on even days just to have a procedure that reminds me to exercise both batteries.) 4 Quote
GeeBee Posted December 26, 2022 Report Posted December 26, 2022 Unbalanced batteries lead to trouble. Lancescaper is correct. 2 Quote
exM20K Posted December 26, 2022 Report Posted December 26, 2022 5 hours ago, LANCECASPER said: In theory each battery in your Ovation has a trickle charge circuit if you are using the opposite battery, but I still wouldn't take off with one dead battery. (I use BAT 1 on odd days that I fly and BAT 2 on even days just to have a procedure that reminds me to exercise both batteries.) Also, check that the trickle charger breaker is in. Just inside the left battery access door on my Acclaim. Mine was tripping all the time when the right side battery was dying. -dan 1 Quote
GaryP1007 Posted December 26, 2022 Author Report Posted December 26, 2022 The Required Equipment list in your Ovation POH shows that two batteries are necessary for Day or Night VFR or IFR. Just having both batteries installed isn't what's necessary - they need to be functional. See if it will come back up with a charge on the ground. Electrical problems are no fun in the air. In theory each battery in your Ovation has a trickle charge circuit if you are using the opposite battery, but I still wouldn't take off with one dead battery. (I use BAT 1 on odd days that I fly and BAT 2 on even days just to have a procedure that reminds me to exercise both batteries.)Thanks. Sent from my iPhone using Tapatalk Quote
rickseeman Posted December 26, 2022 Report Posted December 26, 2022 3 hours ago, GaryP1007 said: Quick question- safe to fly if one battery indicating low but the other normal? Low is 22+/- Sent from my iPhone using Tapatalk I'm from Arkansas. Do you really think that would bother me? 2 Quote
Jerry 5TJ Posted December 26, 2022 Report Posted December 26, 2022 It might be a good time to pull out the batteries, charge them to full, then run a battery capacity test. (Test is run at a constant current equal to the amp-hour rating). All you ever wanted to know about capacity testing your Concord aircraft batteries: https://batterymanagement.concordebattery.com/BatteryDocs/5-0171.pdf 2 Quote
GaryP1007 Posted December 26, 2022 Author Report Posted December 26, 2022 Tested both with a meter and got 25.8 on each. Sent from my iPhone using Tapatalk Quote
GaryP1007 Posted December 26, 2022 Author Report Posted December 26, 2022 Any suggestions for a good trickle charger?Sent from my iPhone using Tapatalk Quote
LANCECASPER Posted December 26, 2022 Report Posted December 26, 2022 7 minutes ago, GaryP1007 said: Tested both with a meter and got 25.8 on each. That's just a voltage reading - not a capacity test. A capacity test determines if the battery will deliver the required current. After receiving a full charge, the battery is subjected for one hour to a typical discharge current of 100% of its rating. A BatteryMinder specific to your battery is a good external trickle charger. https://www.aircraftspruce.com/catalog/elpages/batteryminder_24v.php 1 Quote
N201MKTurbo Posted December 26, 2022 Report Posted December 26, 2022 Are you going to be out at the airport tomorrow? Quote
GaryP1007 Posted December 26, 2022 Author Report Posted December 26, 2022 Are you going to be out at the airport tomorrow?I can. Sent from my iPhone using Tapatalk Quote
hais Posted December 26, 2022 Report Posted December 26, 2022 4 hours ago, exM20K said: Also, check that the trickle charger breaker is in. Just inside the left battery access door on my Acclaim. Mind was tripping all the time when the right side battery was dying. -dan Nice to know, thanks! Quote
N201MKTurbo Posted December 26, 2022 Report Posted December 26, 2022 18 minutes ago, GaryP1007 said: I can. Sent from my iPhone using Tapatalk I'll probably head out there about 9:00 AM. I can take a look at your batteries. 1 Quote
GaryP1007 Posted December 26, 2022 Author Report Posted December 26, 2022 I'll probably head out there about 9:00 AM. I can take a look at your batteries. Great. I just sent a DM to you Sent from my iPhone using Tapatalk Quote
exM20K Posted December 26, 2022 Report Posted December 26, 2022 1 hour ago, LANCECASPER said: That's just a voltage reading - not a capacity test. A capacity test determines if the battery will deliver the required current. After receiving a full charge, the battery is subjected for one hour to a typical discharge current of 100% of its rating. A BatteryMinder specific to your battery is a good external trickle charger. https://www.aircraftspruce.com/catalog/elpages/batteryminder_24v.php If you have a battery minder(s), how did you route the wires to the exterior? Also, I assume it one minder per battery, correct? -dan Edit…. Reading is fundamental. From the spruce product page…. Maintain up to 2 batteries at a time. (requires BatteryMINDer® Y-Connector Accessory 210-AY) Quote
LANCECASPER Posted December 27, 2022 Report Posted December 27, 2022 52 minutes ago, exM20K said: If you have a battery minder(s), how did you route the wires to the exterior? Also, I assume it one minder per battery, correct? -dan I've done it with one and a splitter (part number 210-AY) and with two battery minders. I use two presently only because I have them - one works fine. I run the cords from each battery and zip tie them along the way over to the oxygen filler door. When my airplane was in for service at the Mooney Service Center they were fine with it and said it made a lot more sense then having to leave the baggage door open to run the cord in. https://www.dropbox.com/s/ygbmo9l7w5rhkgv/IMG_4789.JPG?dl=0 https://www.dropbox.com/s/4a4ayjdwzxwatny/IMG_4787.JPG?dl=0 https://www.dropbox.com/s/0oo0v0ukergke8l/IMG_4786.JPG?dl=0 2 Quote
carusoam Posted December 27, 2022 Report Posted December 27, 2022 +1 for using the BatteryMinder…. Good quality, works as expected… it’s brain decides how to charge, full, trickle, desulfur…. It's expensive, but you are getting what you paid for… +1 if you want two…. The Y cord works… but can leave you wondering about how well…. Especially if your two batteries are of different ages or brands…. While you are at it… make sure the battery selector switch system is still working… relays don’t croak often, but… last time I wore out a battery, the relay for the other battery was no longer working… I don’t have an O2 door… but, the GPU door has plenty of wiggle room to get wire and connector in next to the big plug… PP thoughts as usual… Best regards, -a- Quote
Graf_Aviator Posted December 27, 2022 Report Posted December 27, 2022 Also, check that the trickle charger breaker is in. Just inside the left battery access door on my Acclaim. Mine was tripping all the time when the right side battery was dying. -danDan, could you please share a picture of this trickle charger breaker? Would love to find it but did not see it in my 06 Ovation 2GX. Thanks Sent from my iPhone using Tapatalk Quote
flysamo Posted December 27, 2022 Report Posted December 27, 2022 just went thru exact issue battery reading 23.5 volts, ordered new battery used to be 400 a battery latest battery was 815 delivered, old battery was 2013 install date. over the years have lost 2 alternators, dual battery's are really useful alt. goes south Quote
exM20K Posted December 27, 2022 Report Posted December 27, 2022 11 hours ago, Graf_Aviator said: Dan, could you please share a picture of this trickle charger breaker? Would love to find it but did not see it in my 06 Ovation 2GX. Thanks Sent from my iPhone using Tapatalk I can't get out to the hangar just now. If yours is set up like mine, just pop open the left side cover. It is sitting just inside and aft with a handful of breatkers. -dan Quote
atpdave Posted December 27, 2022 Report Posted December 27, 2022 13 hours ago, Graf_Aviator said: Dan, could you please share a picture of this trickle charger breaker? Would love to find it but did not see it in my 06 Ovation 2GX. Thanks Sent from my iPhone using Tapatalk I think M20R SNs before 29-0475 had inline fuse holders, not CBs for this. Look for a black inline fuse holder wired to the corresponding battery relay. 1 1 Quote
LANCECASPER Posted December 28, 2022 Report Posted December 28, 2022 4 hours ago, atpdave said: I think M20R SNs before 29-0475 had inline fuse holders, not CBs for this. Look for a black inline fuse holder wired to the corresponding battery relay. That's correct. They use a 10AG slo-blo fuse. Quote
