Pinecone Posted August 16, 2022 Report Posted August 16, 2022 On 8/15/2022 at 1:38 PM, goodyFAB said: this is how panel upgrades start... once you change on thing you start wondering about the future of your panel. I have had my eye on the av30 too, couple of those and you can ditch the vacuum system and they can stay if you ever upgrade further. In sport's car, it was called the radiator cap restoration. You start by needing a new radiator cap. While you are installing it you see something else that needs to be done, and so forth, until you have done a full restoration. Quote
Jerry 5TJ Posted August 17, 2022 Report Posted August 17, 2022 16 hours ago, geoffb said: don't think anyone's ever seen a big red X across a mechanical gyro's face..... Nope, that’s right. The spinning gyro winds down and leads you astray without any warning. 5 Quote
laytonl Posted August 20, 2022 Report Posted August 20, 2022 The AV20 is less than $1,000 and is a Very easy install if it’s just a backup AI. 2 hour install. Another 2 hours if you want OAT and TAS. As already mentioned the Av30 is good too and has battery backup up. Lee 1 Quote
LANCECASPER Posted August 20, 2022 Report Posted August 20, 2022 54 minutes ago, laytonl said: The AV20 is less than $1,000 and is a Very easy install if it’s just a backup AI. 2 hour install. Another 2 hours if you want OAT and TAS. As already mentioned the Av30 is good too and has battery backup up. Lee The OP @Yariv will need something that’s an approved backup for the G1000. The MidContinent that he has is, the MidContinent SAM is and I think the GI275 is, not sure what else is. 2 Quote
kortopates Posted August 21, 2022 Report Posted August 21, 2022 The GI-275 would be my choice for a G1000 backup, but i can see the installation hours add up since it’s would get connected to the Pitot-static system, garmin GPS, garmin magnetometer and garmin ADC, and perhaps more.In exchange for all that it would come with more capability. Sent from my iPhone using Tapatalk 2 Quote
