Guest Posted May 14, 2022 Report Posted May 14, 2022 I’ve circled the links in question for you. The SB kit includes everything required Quote
Jpravi8tor Posted May 14, 2022 Report Posted May 14, 2022 15 minutes ago, M20Doc said: I’ve circled the links in question for you. The SB kit includes everything required Thanks @M20doc I surmised that was the linkage in question always good to get a second opinion! Quote
N201MKTurbo Posted May 14, 2022 Report Posted May 14, 2022 56 minutes ago, Jpravi8tor said: Is the view looking up and forward? Does this picture show the aileron linkage? That is it. Quote
jamesm Posted May 15, 2022 Report Posted May 15, 2022 I can't remember who but someone once told me if you don't have washer between the bolt head or nut end of the rod end. it is possible for the ball of the rod end to pop out of rod end housing. that cause me to double check anytime I see a rod end to verify there is washer at very least nut and bolt end of the assembly. Quote
PT20J Posted May 15, 2022 Report Posted May 15, 2022 16 hours ago, jamesm said: I can't remember who but someone once told me if you don't have washer between the bolt head or nut end of the rod end. it is possible for the ball of the rod end to pop out of rod end housing. that cause me to double check anytime I see a rod end to verify there is washer at very least nut and bolt end of the assembly. I believe you are referring to the practice of installing a large planform washer on a rod end where there is a possibility that if the socket came off the ball it could slip over the the nut or bolt head and become disconnected. I know some experimental builders do this, but I don't know how prevalent it is on production aircraft. And I have no idea how often rod ends fail in this way. Skip Quote
Guest Posted May 15, 2022 Report Posted May 15, 2022 2 hours ago, PT20J said: I believe you are referring to the practice of installing a large planform washer on a rod end where there is a possibility that if the socket came off the ball it could slip over the the nut or bolt head and become disconnected. I know some experimental builders do this, but I don't know how prevalent it is on production aircraft. And I have no idea how often rod ends fail in this way. Skip It’s depends on manufacturer and models. Some add the penny washer and some don’t. I’ll often add one where it doesn’t interfere with the installation. Clarence Quote
EricJ Posted May 16, 2022 Report Posted May 16, 2022 22 hours ago, PT20J said: I believe you are referring to the practice of installing a large planform washer on a rod end where there is a possibility that if the socket came off the ball it could slip over the the nut or bolt head and become disconnected. I know some experimental builders do this, but I don't know how prevalent it is on production aircraft. And I have no idea how often rod ends fail in this way. Skip My engine control cables all have them but I think one of them is installed wrong (probably by me). Next time the cowl is off I'll probably fix it. I just finished my annual and I looked at these aileron links while the belly was off. Mine move quite a bit and there's a bare spot on the landing gear actuator tube where it's been rubbing, but it doesn't really seem to be problematic. I suspect it's been like that for a loooong time. I'll see what the kit costs and whether the local MSC has it or can get it and maybe put it in next year. 1 Quote
PT20J Posted May 16, 2022 Report Posted May 16, 2022 1 hour ago, EricJ said: My engine control cables all have them but I think one of them is installed wrong (probably by me). Next time the cowl is off I'll probably fix it. I just finished my annual and I looked at these aileron links while the belly was off. Mine move quite a bit and there's a bare spot on the landing gear actuator tube where it's been rubbing, but it doesn't really seem to be problematic. I suspect it's been like that for a loooong time. I'll see what the kit costs and whether the local MSC has it or can get it and maybe put it in next year. Since the kit give the dimesions of the spacers and the rest is common hardware, you could also just make the spacers. Quote
EricJ Posted May 16, 2022 Report Posted May 16, 2022 30 minutes ago, PT20J said: Since the kit give the dimesions of the spacers and the rest is common hardware, you could also just make the spacers. Yeah, was looking at that. Lasar lists the kit at $271 but says they don't have them. The spacer material isn't indicated, though. Nylon? Quote
PT20J Posted May 16, 2022 Report Posted May 16, 2022 Just now, EricJ said: Yeah, was looking at that. Lasar lists the kit at $271 but says they don't have them. The spacer material isn't indicated, though. Nylon? Pretty sure it’s steel or aluminum from the look of it. Mine was installed by the previous owner. Maybe @M20Doc knows. Quote
EricJ Posted May 16, 2022 Report Posted May 16, 2022 3 minutes ago, PT20J said: Pretty sure it’s steel or aluminum from the look of it. Mine was installed by the previous owner. Maybe @M20Doc knows. In Vance's vid in this thread from a year ago last April they look like plastic of some kind. Quote
RobertGary1 Posted May 16, 2022 Report Posted May 16, 2022 30 minutes ago, EricJ said: Yeah, was looking at that. Lasar lists the kit at $271 but says they don't have them. The spacer material isn't indicated, though. Nylon? Do you have a link to the kit on their website? Quote
EricJ Posted May 16, 2022 Report Posted May 16, 2022 24 minutes ago, RobertGary1 said: Do you have a link to the kit on their website? https://lasar.com/service-bulletin-kits/service-bulletin-kit-289-m20-289-000 Quote
Guest Posted May 16, 2022 Report Posted May 16, 2022 The three spacers are steel. If the kit is our of stock, see if the spacers are available individually. The bolt and nut are standard AN parts. Clarence Quote
EricJ Posted May 16, 2022 Report Posted May 16, 2022 21 minutes ago, M20Doc said: The three spacers are steel. If the kit is our of stock, see if the spacers are available individually. The bolt and nut are standard AN parts. Clarence Lasar shows the spacers individually as well but all out of stock. The I.D. seems to be much bigger than the bolt, too, so that seems to be an additional unknown. Quote
PT20J Posted May 16, 2022 Report Posted May 16, 2022 40 minutes ago, EricJ said: Lasar shows the spacers individually as well but all out of stock. The I.D. seems to be much bigger than the bolt, too, so that seems to be an additional unknown. Maybe Frank Crawford would share the details? Worth a call. Quote
Guest Posted May 16, 2022 Report Posted May 16, 2022 43 minutes ago, EricJ said: Lasar shows the spacers individually as well but all out of stock. The I.D. seems to be much bigger than the bolt, too, so that seems to be an additional unknown. The spacers are essentially a steel washer that fits around and over the steel ball of the rod end bearing. The centre spacer is twice as thick as the two outer spacers. Clarence Quote
lithium366 Posted December 14, 2024 Report Posted December 14, 2024 Anyone know where to source parts in 2024? Lazar is out of stock but when they do these washers are $120 each Quote
PT20J Posted December 14, 2024 Report Posted December 14, 2024 43 minutes ago, lithium366 said: Anyone know where to source parts in 2024? Lazar is out of stock but when they do these washers are $120 each Each MSC maintains it's own stock, so you could call around. You could probably have a machine shop make them cheaper than buying them from Mooney. Quote
lithium366 Posted December 15, 2024 Report Posted December 15, 2024 (edited) 20 hours ago, PT20J said: Each MSC maintains it's own stock, so you could call around. You could probably have a machine shop make them cheaper than buying them from Mooney. Do we know dimensions? I can create a cad file if dimensions known Edited December 15, 2024 by lithium366 Quote
Marauder Posted December 19, 2024 Report Posted December 19, 2024 Do we know what material is used? Quote
PT20J Posted December 19, 2024 Report Posted December 19, 2024 Pretty sure they are epoxy primed steel. The thickness is specified in the SB. The hole diameter is set by the bolt and would be the same as an AN960 washer. From Vance's video in the original post the function is clear (to restrict the twisting motion of the Heim bearings) and the outer diameter can be estimated. You could probably make them by modifying some AN970 washer to reduce diameter and thickness. 1 1 Quote
